giteup 2 #1 Posted April 30, 2020 New to the forum and just received a 520h with some wiring issues. Anyone know what the switch mounted to the inside of the rubber hood strap on the left side is? 1 Share this post Link to post Share on other sites
1995 520H+96+97 937 #2 Posted April 30, 2020 Air filter restriction. to 1 Share this post Link to post Share on other sites
953 nut 63,003 #4 Posted April 30, 2020 37 minutes ago, giteup said: just received a 520h We have a lot of members here willing to help you get to know your and we would like to know you better too. 2 Share this post Link to post Share on other sites
lynnmor 8,254 #5 Posted April 30, 2020 That switch has a hose that attaches to the underside of the air filter housing. The nipple on the switch often breaks off, so use a lighter weigh hose supported in a way that takes the load off the nipple. If yours is already broken, at least plug the hose. I have repaired the switches with an aluminum part with a nipple screwed over the broken side. Source for switch. Share this post Link to post Share on other sites
giteup 2 #6 Posted April 30, 2020 Thanks a lot , I have got it running but someone has been in to the wiring. It appears the fuse block has been removed and two red and two white wires are twisted all together. Share this post Link to post Share on other sites
lynnmor 8,254 #10 Posted May 1, 2020 A Dorman 85668 fuse block is available many places. Rockauto has them for $2.88. Fuse block A fuse block cover is available from one of our vendors. There should be a white 9 pin connector near the battery. This connector is often a source of electrical problems, especially the heavier battery charge wire that heats a less than perfect connection. There are three relays behind the battery that have issues with corrosion particularly if stored outdoors. Download a manual with a wiring diagram in our manuals section, all too often wiring is attacked by folks that somehow think they have a better idea. Share this post Link to post Share on other sites
JuneBuggyWuggy 2 #11 Posted June 2, 2020 On 4/30/2020 at 6:34 PM, 1995 520H+96+97 said: Air filter restriction. to Just joined today. I've had my 1992, 520h, for 6 years. No problems til now. Been yal feedback. I down to checking the starter relay. Thanks for your help. Share this post Link to post Share on other sites
953 nut 63,003 #12 Posted June 2, 2020 22 hours ago, JuneBuggyWuggy said: Just joined today With any electrical problem use this advice. Share this post Link to post Share on other sites
Digger91 2 #13 Posted June 4, 2020 Boat owners creed. 👍 Share this post Link to post Share on other sites
squonk 44,860 #14 Posted June 4, 2020 (edited) That 9 pin connector is a Molex plug. Anyone who works on a lot of electrical stuff knows that "Molex" is the American version of Lucas Electric from Europe. Google Joseph Lucas Prince of darkness. If you want some laughs: http://www.mez.co.uk/lucas.html When I had a 520 I tore out that connector and used 2 trailer connector sets to make up the 9 pins. Never had an issue after that. Edited June 4, 2020 by squonk Share this post Link to post Share on other sites
Guest 88vic #15 Posted June 4, 2020 6 hours ago, squonk said: That 9 pin connector is a Molex plug. Anyone who works on a lot of electrical stuff knows that "Molex" is the American version of Lucas Electric from Europe. Google Joseph Lucas Prince of darkness. If you want some laughs: http://www.mez.co.uk/lucas.html When I had a 520 I tore out that connector and used 2 trailer connector sets to make up the 9 pins. Never had an issue after that. That explains the trailer plugs on my 520, I wondered who did that. Been a good tractor to me so far. Share this post Link to post Share on other sites
Guest 88vic #16 Posted June 4, 2020 @squonk I have added a rear reciever hitch from wheelhorseparts and more, a genuine wheel horse cup holder and flashing hazard lamps. Share this post Link to post Share on other sites
squonk 44,860 #17 Posted June 5, 2020 49 minutes ago, WHEELHORSEFAN*19 said: @squonk I have added a rear reciever hitch from wheelhorseparts and more, a genuine wheel horse cup holder and flashing hazard lamps. Mine already had the cupholder. I think someone else did the same thing as me. I sold mine at the show a couple years ago Share this post Link to post Share on other sites
Guest 88vic #18 Posted June 5, 2020 I got the 520 from the guy who bought It from you at the show. This tractors been around, ha ha. Share this post Link to post Share on other sites
