Marv 994 #1 Posted April 30, 2020 What do you use for a cleaner in your ultrasonic cleaner? Marv Share this post Link to post Share on other sites
cafoose 3,638 #2 Posted April 30, 2020 I used this and it did an excellent job followed by your favorite carburetor spray cleaner I also replaced the throttle shaft bushing and it's like a new carburetor Share this post Link to post Share on other sites
squonk 45,645 #4 Posted April 30, 2020 My Harbor Freight ultrasonic say do not use flammable liquids in the cleaner. Berrymans or Gunk carb cleaner is extremly flammable. These cleaners have electric heaters in them. I use Simple Green also. Share this post Link to post Share on other sites
Marv 994 #5 Posted May 1, 2020 Thanks for your response y'all. Are you using simple green full strength and does it remove corrosion? Marv Share this post Link to post Share on other sites
RandyLittrell 3,944 #6 Posted May 1, 2020 Check out this video, he has some really great tips on using one. Randy Share this post Link to post Share on other sites
RandyLittrell 3,944 #7 Posted May 1, 2020 4 minutes ago, Marv said: Thanks for your response y'all. Are you using simple green full strength and does it remove corrosion? Marv My understanding is regular simple green will etch aluminum, I guess there is a different kind of simple green that will not. I havn't seen it though. Randy Share this post Link to post Share on other sites
pabird 40 #8 Posted May 1, 2020 Yes I use simple green straight out of the bottle. I've only used it on plastic and pot metal/aluminum carbs. Works fine. Share this post Link to post Share on other sites
