Handy Don 17,358 #9901 Posted August 1 (edited) 3 hours ago, ohiofarmer said: After I sent the screws through to mark the drywall behind the wall, we had to mount a hardwood board inletted into the drywall so the screws could have a solid bite. Planning ahead for solid mounting points for grab bars is an often-neglected step. I hope you are placiing a vertical one on the near wall for stepping in and out as well as one on the “far” wall for stability while getting up or down in the tub. Edited August 1 by Handy Don 1 Share this post Link to post Share on other sites
davem1111 2,320 #9902 Posted August 2 On 7/27/2026 at 4:13 PM, davem1111 said: So, this is not a "today" thing but ongoing work for the last few weeks. We had a torrential downpour (we seem to be having more of those lately) and discovered that a large quantity of water was being re-routed into the corner of the house due to a badly constructed gutter. Had to remove a built-in bookshelf and start tearing out walls and floor. This apparently had been happening for years - there was a lot of rot, and the waferboard subfloor was like pudding. Interestingly, we discovered a floor-to-ceiling window in the wall to the left, that a previous owner had just cover over for some reason. This is between the house and an aluminum screened/glass porch. We've decided to open it up again, it lets in lots of light. There are streaks between the panes so we'll probably put some vinyl adhesive frosted pattern on it to hide that: I'm in the "sanding spackle", "patching in tongue-groove flooring", and "re-framing the window" stage now. I painted everything that won't be seen under the flooring or bookshelf with mold killer primer. I used Rock Wool insulation - that stuff is cool (but expensive). Outside is done. Inside work is all done except putting the shelves and books/knickknacks back in place. 4 Share this post Link to post Share on other sites
ohiofarmer 3,473 #9903 Posted August 2 1 hour ago, Handy Don said: Planning ahead for solid mounting points for grab bars is an often-neglected step. I hope you are placiing a vertical one on the near wall for stepping in and out as well as one on the “far” wall for stability while getting up or down in the tub. Absolutely.We bought three grab bars and will install at least two. The wall I was dealing with is an outside wall so i left it intact as possible and used hardwood for maximum hold. Drilling an undersize hole so the threads grab without splitting. The other walls will get solid blocking and a block for a third grab bar in case there is need for a caretaker within the shower. this house was bought in case we would have to take care of a parent, but its only two miles from here and the need for an easier property for us is a possibility. It is a step in shower that fits a five foot opening. Its nice and rigid and solid Vickerel where the cplor goes all the way through 3 1 Share this post Link to post Share on other sites
8ntruck 9,239 #9904 Posted August 2 We slept in, went over to Crystal Lake Diner for brunch, walked the dog, and finished several small projects that were cluttering up my bench - there is actually a fair sized empty spot on it now. One of the projects was finishing reassembling my Red Ryder. Last fall it quit shooting. When I did get it to shoot once, the barrel plug/sight and shot tube came out and landed about 8 feet away. Total tear down and search for parts. Ended up with a new shot tube, barrel plug (with a 'fiber optic sight'!), new air tube, new plunger seal. Once I figured out how to make a dependable spring compressor, it went together. It did shoot bb's - at a very low velocity. It was not producing an air pulse when fired. Took it back apart and compared the new plunger seal to the old one. Was about 1/16" smaller in diameter. Put the old seal back in and it is working like it should. Needs to be sighted back in, probably due to the new shot tube and front sight. 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,215 #9905 Posted August 2 @8ntruck be careful!!! 3 Share this post Link to post Share on other sites
953 nut 68,661 #9906 Posted August 2 On 8/1/2026 at 3:35 PM, ohiofarmer said: shower wall and just no way to hold anything to messure When I built our house I put in a LOT of blocking in all the shower walls. When it came time to install the grab bars I used foam double stick tape to hold them in place while drilling and mounting. 2 2 Share this post Link to post Share on other sites
Ed Kennell 47,054 #9907 Posted August 9 Made the 4 hour trip back to my birthplace to attend a family reunion. Back in one of the hollers surrounded by the Appalachian Mts. 4 5 Share this post Link to post Share on other sites
adsm08 5,035 #9908 Posted August 9 11 hours ago, Ed Kennell said: my birthplace You were born at the sportmans' club? That's way cooler than at the hospital. 5 Share this post Link to post Share on other sites
Sparky-(Admin) 26,233 #9909 Posted August 9 Finished up this shed today. Still need to get a ramp setup for it but no rush on that. Yes it’s plastic and yes it was a kit (one million pieces!!) But it all fit together well and I already had the pressure treated base built and leveled, so that’s how the size was determined. It’s 10’9” x 7’xx” with a door plenty wide enough to get a tractor in if need be. 9 Share this post Link to post Share on other sites
ebinmaine 80,426 #9910 Posted August 9 2 hours ago, Sparky said: this shed New & larger coffee storage space? 4 Share this post Link to post Share on other sites
Ed Kennell 47,054 #9911 Posted August 9 5 hours ago, adsm08 said: You were born at the sportmans' club? Sorry, I was a 19yo when the club was formed in 1963. 1 Share this post Link to post Share on other sites
Blue Chips 834 #9912 Posted August 12 On 8/2/2026 at 6:07 PM, 8ntruck said: We slept in, went over to Crystal Lake Diner for brunch, walked the dog, and finished several small projects that were cluttering up my bench - there is actually a fair sized empty spot on it now. An empty spot on a workbench is an open invitation to buy more tools. In my workshop a bare spot on a bench is a rare enough event that I take a photo of it to show my friends before covering it with more stuff. Otherwise they might not believe it happened. 2 Share this post Link to post Share on other sites
Blue Chips 834 #9913 Posted August 12 (edited) Well, I finally tore into the transmission for my M37. Here it is after the first round of degreasing and pressure washing: It looked good when I first opened it up, but after disassembling it, I experienced a sudden pain in my wallet. I'm guessing that a snap ring must have come loose and got wedged between two components, which broke the ends off all but one spline where it formed the groove to contain the snap ring. At least that's my take on it. I found most of the broken pieces of the spline and snap ring at the bottom of the case, but it looks like one or two broken bits managed to circulate with the oil and do some damage to several components. There were also some rust pits on some of the bearing surfaces. The upshot of all this is that I'll be replacing almost every moving part of the transmission. I've ordered a ton of NOS parts, which are starting to arrive now. It will be a pricey repair, but should be like new when I'm done. On the plus side, it looks like all of the parts are still available, either NOS or new manufacture. More pictures coming as the work progresses. Edited August 12 by Blue Chips 1 1 3 Share this post Link to post Share on other sites
ohiofarmer 3,473 #9914 Posted August 12 On 8/1/2026 at 7:30 PM, Handy Don said: Planning ahead for solid mounting points for grab bars is an often-neglected step. I hope you are placiing a vertical one on the near wall for stepping in and out as well as one on the “far” wall for stability while getting up or down in the tub. Yes a vertical one is going on solid blocking. I will show the complete thing when finished as ordering parts for the various plumbing fixtures and stuff has stalled the completion. Here is some eye candy with many coats of Danish oil finally sealing down the wood of an enemy battle implement. What three coats will do on some fine grain walnut takes twenty on this stuff. 1 1 Share this post Link to post Share on other sites
c-series don 12,374 #9915 Posted August 13 (edited) Today I became a grandpa for the second time! My granddaughter is four and my grandson was born at 2:03 today. 10lbs 6oz ! Praise god everyone is doing great ❤️ We are going to meet him in the morning ❤️ Edited August 13 by c-series don 5 4 10 Share this post Link to post Share on other sites
wallfish 20,532 #9916 Posted August 13 25 minutes ago, c-series don said: Today I became a grandpa for the second time! My granddaughter is four and my grandson was born at 2:03 today. 10lbs 6oz ! Praise god everyone is doing great ❤️ We are going to meet him in the morning ❤️ CONGRATULATIONS!!!!!!!!!! Being a grandparent has got to be the best thing ever! I bought a 2 family house with my daughter and her husband so seeing the grand kids everyday from the time they were born and being a huge part of their life is a wonderful thing. No responsibilities as far as parenting goes, they act up, send'em home. My wife got to babysit everyday which she loved doing. If my daughter gave me any lip, I just threaten her "I'll just buy them dart guns and drum sets. Maybe even a clarinet to really punish you!" LOL Well, what seems like such a VERY short time they're all grown up.( I still see them as little kids sometimes ). My Granddaughter is now working on her masters degree (24) and the Grandson is going to start his 3rd of college soon (20). My threats have come back to haunt me as now I'm getting older. So if I give my daughter any lip, she threatens me that she just won't wipe my a$$ ! LOL Touche' to her as she has learned well. Enjoy the time with them kids Don, it goes by too quickly 2 3 Share this post Link to post Share on other sites
Ed Kennell 47,054 #9917 Posted August 13 2 hours ago, c-series don said: Praise god everyone is doing great Grandkids has to be the best chapter in our life book. Enjoy every moment Don. 4 Share this post Link to post Share on other sites
JCM 11,402 #9919 Posted August 13 That about sums it up EB. 1 Share this post Link to post Share on other sites
CRF857 618 #9920 Posted August 13 18 hours ago, Ed Kennell said: Grandkids has to be the best chapter in our life book. Grandkids are your reward for allowing your kids to live. 1 1 3 Share this post Link to post Share on other sites
ebinmaine 80,426 #9921 Posted August 13 19 minutes ago, CRF857 said: Grandkids are your reward for allowing your kids to live. 1 Share this post Link to post Share on other sites
Ed Kennell 47,054 #9922 Posted August 13 Son Mark and I went crabbing to a new spot. Left at 5AM for Fort Smallwood State Park on the upper Chesapeake Bay. Beautiful park on the bay. Caught a half bushel and back home and in the steamer by noon. 7 4 Share this post Link to post Share on other sites
MainelyWheelhorse 3,057 #9923 Posted August 14 The day began with a trip to Home Depot and Sam’s club where I picked up some groceries, and two wide totes to put my clothes I couldn’t hang like pants, shorts etc… in. I helped my father load some furniture of which some I donated along with him and my mother to a local Fireman’s Auction. I then did some organizing and made a spot for my projects with some small parts. I then started to work on with a Kohler 23 hp Command engine I got from my brother that would run but lose power eventually stalling when hot. I’m going to look up how it comes apart as it’s a bit more intricate than our old Kohlers. Everything but the valves have been gone through and checked by my brother, who researches known issues/problems before he throws a parts cannon at something. so I thought I’d start with the valves as they haven’t been touched yet. The C-85 project may have a heart if I can figure out the issue. Now, I’m done for the night and I’m going to go relax. 2 3 Share this post Link to post Share on other sites
Handy Don 17,358 #9924 Posted August 14 16 hours ago, CRF857 said: Grandkids are your reward for allowing your kids to live. I often reflect that I was a major PITA to my folks with a dangerous temper. Yet they let me live and supported an undeserving me. 1 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,215 #9925 Posted August 14 (edited) Woodward Avenue Dream Cruise is tomorrow... Goodyear blimp arrived for the festivities and flew over our park... https://www.woodwarddreamcruise.com Edited August 14 by SylvanLakeWH 5 Share this post Link to post Share on other sites
