Razorback 1,358 #9726 Posted June 7 10 minutes ago, Blue Chips said: I'm making slow but steady progress on the M37 engine overhaul. The new pistons and exhaust valves just arrived. The valves are 21-4N stainless steel, and I've asked the machine shop to install new hardened exhaust valve seat inserts to pair with the new exhaust valves (we haven't decided what kind of inserts yet, maybe sintered metal), so the engine will be properly set up for using unleaded fuel. The shop will be boring the cylinders .020" to pair with the .020 Silv-O-Lite pistons, which are a hypereutectic aluminum-silicon alloy that expands less when heated, so they are sized for a closer fit in the bore, and the silicon helps keep combustion heat in the chamber. They came with new piston pins (floating type), and I'll check the piston pin bushings in the connecting rods and replace the bushings if necessary. I just ordered a set of .020" oversize Grant piston rings. I'm also gradually moving ahead on the chassis and cab work. After removing the cab with my engine hoist, I rolled the chassis out of the garage and lifted out the transfer case with my front-end loader, since my engine hoist is still hooked up to the cab. The transfer case was covered with a thick layer of decades-old hardened dirt and oil that was about as tough as epoxy (or so it seemed at the time). Here's how it looked after SIX cycles of de-greasing and pressure washing. Not too bad, but there is still some dirt left to be removed, and of course I'll make sure it's spotless before opening it up to see how things look internally. Hopefully it will be in good shape, but I'll replace anything that may be needed. At the bare minimum I would be replacing all six seals and all gaskets. I still have to finish cleaning up the portion of the frame hat was under the cab. As mentioned, the frame is actually in pretty nice shape. I just need to sand a few small areas of light surface rust, de-grease it again, pressure wash it again, let it dry thoroughly for a few days, and then prime and paint it, followed by all-new grease fittings and a thorough lube job. BTW, the olive drab paint you can see on the part of the frame that was under the cab is the original paint. Not bad for 72 years old. It's raining off and on today, and I'm taking a bit of a break. Should be nice weather tomorrow, and I hope to get moving again on the frame cleanup. This looks like an awesome project, on a vehicle I wish I had!!!! 2 1 Share this post Link to post Share on other sites
Blue Chips 806 #9727 Posted June 7 1 minute ago, Razorback said: This looks like an awesome project, on a vehicle I wish I had!!!! It's a fun vehicle to work on, and there are still a lot of them around if you're ready for a new project . 2 Share this post Link to post Share on other sites
Razorback 1,358 #9728 Posted June 7 4 minutes ago, Blue Chips said: It's a fun vehicle to work on, and there are still a lot of them around if you're ready for a new project . I'll have to force myself to fight that urge..... 2 Share this post Link to post Share on other sites
adsm08 4,779 #9729 Posted June 7 I set the cab back down on the Ranger today. Not hooked up by any stretch, but at least it is sitting back on the frame. Then I spent my afternoon reading and chilling. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,650 #9730 Posted June 7 1 hour ago, adsm08 said: Then I spent my afternoon reading and chilling. Same. Been lookin at F250 parts and info. Also rejoined the Fordsix forum. Share this post Link to post Share on other sites
8ntruck 9,042 #9731 Posted June 7 I took a bit of time to install the Stens carb on my Troy Built Bronco (2000 vintage) roto tiller. Surging issue gone. I dropped the bowl of the original carb - lots of corrosion blooms in there. Not sure if it will be worth the trouble to rebuild it. 1 Share this post Link to post Share on other sites
Ed Kennell 46,557 #9732 Posted June 8 One more strawberry/rhubarb pie. The strawberries are just starting to ripen. 1 3 3 Share this post Link to post Share on other sites
adsm08 4,779 #9733 Posted June 8 Today I got the cab actually back on the Ranger. Everything is done except 1 wire I had to cut, two cab bolts that won't be in until tomorrow (one broke, but they are sold in 2-packs) and coolant. 2 Share this post Link to post Share on other sites
Blue Chips 806 #9734 Posted June 11 (edited) I did some more work on cleaning up the mid-section of the frame under the cab. I sanded the small areas of light surface rust and any flaking spots (there weren't many), blew off the dust, de-greased and pressure washed the area (twice), immediately blew it dry, and then allowed it to dry completely in direct sun and low humidity for two days before priming it. Painting the rest of the frame in Marine Corps green will have to wait until we have a forecast for sunny weather for at least four days in a row. I have lots of other things to work on in the meantime. Edited June 11 by Blue Chips 2 2 Share this post Link to post Share on other sites
adsm08 4,779 #9735 Posted June 13 Today was a marathon on the wife's car. I took the turbo out to replace it the other night. Starting at 8 this morning I finished the turbo, replaced the timing belt, and did the water pump and all the oil seals behind the timing belt since I was there, and I have never seen one of these vehicles hit the mileage that hers has. I worked on it about 10 hours today, and I still have to put the valve cover back on, because I am missing an o-ring that goes under it, and I can't get that until Monday. 2 Share this post Link to post Share on other sites
sqrlgtr 3,243 #9736 Posted June 13 9 minutes ago, adsm08 said: Today was a marathon on the wife's car. I took the turbo out to replace it the other night. Starting at 8 this morning I finished the turbo, replaced the timing belt, and did the water pump and all the oil seals behind the timing belt since I was there, and I have never seen one of these vehicles hit the mileage that hers has. I worked on it about 10 hours today, and I still have to put the valve cover back on, because I am missing an o-ring that goes under it, and I can't get that until Monday. that does sound like a day 1 Share this post Link to post Share on other sites
8ntruck 9,042 #9737 Posted June 14 I scrubbed the front porch on the lake house - wall, ceiling, and slab. The slab is going to need the pressure washer to get it where I want it. Then, for grins and giggles, I started raking the leaf muck out of the lake - gave up after a while and leaved some more for another day. Late last week, we bought a Milwaukee battery powered string trimmer. While we were at the store, Mrs 8n spies the battery powered 8" chain saw. She gave it the can I work the handle and switches with her small hand test. It passed, and we bought it. After dinner, I continued working on trimming a tree that fell out of the woods and over the lot line. Most of the crown of the tree is in the yard. I'm cutting it back to where the branches are 4 maybe 5 inches in diameter. I chop the brush off where it is about broomstick size, then make firewood sized pieces of the rest. Been doing that for 3 nights now. Same 8 ah battery. Still has 3/4 charge on it. Used 3 tanks of oil, though. I'm impressed with the Milwaukee Hatchet saw. 10 times the saw compared to my 10" B&D battery saw. 3 Share this post Link to post Share on other sites
adsm08 4,779 #9738 Posted June 14 9 minutes ago, sqrlgtr said: that does sound like a day Oh, I forgot, at 6 this morning I boxed up my son and shipped him off to Tennessee. 2 Share this post Link to post Share on other sites
Razorback 1,358 #9739 Posted June 14 We got the yard mowed, and I got the garden cultivated….. I had my fun mowing with the C160! 1 1 Share this post Link to post Share on other sites
ebinmaine 79,650 #9740 Posted June 14 17 minutes ago, adsm08 said: Oh, I forgot, at 6 this morning I boxed up my son and shipped him off to Tennessee. Some folks use cars trains etc. You ship 'im fedex or sumpin? 4 Share this post Link to post Share on other sites
Razorback 1,358 #9741 Posted June 14 (edited) Oh…. Made one of my famous pizzas for dinner! (I’ll have to admit, it’s stinkin’ AWESOME!) Edited June 14 by Razorback 5 Share this post Link to post Share on other sites
adsm08 4,779 #9742 Posted June 14 5 minutes ago, ebinmaine said: Some folks use cars trains etc. You ship 'im fedex or sumpin? Actually, I just left him in a parking lot with a chair, a backpack, and a tub full of supplies. I'm expecting he will end up in TN, and just show up back here about a week from tomorrow. It's his summer camping trip for scouts. My understanding is that the particular event they are heading to is this organization's equivalent of BSA's Jamboree. I think they were going to a town called Copperhill. 1 1 Share this post Link to post Share on other sites
rjg854 13,180 #9743 Posted June 14 11 hours ago, ebinmaine said: Some folks use cars trains etc. You ship 'im fedex or sumpin? My first thought was USPS flat rate box. 1 Share this post Link to post Share on other sites
adsm08 4,779 #9744 Posted June 14 38 minutes ago, rjg854 said: My first thought was USPS flat rate box. He doesn't fit in a flat rate box anymore 6 Share this post Link to post Share on other sites
8ntruck 9,042 #9745 Posted June 15 We slept in today. However, we did manage to get some stuff done - finished setting up the lake house porch, and did some other general rearranging. After dinner, I went searching for the lake house septic tank clean out hatch. Ever see the movie Holes? Actually, it only took 4 holes. Amazingly, the cover was about the same place I started probing the ground. I misunderstood the results of my probing - false readings on rocks and roots, I guess. 4 Share this post Link to post Share on other sites
Razorback 1,358 #9746 Posted June 15 Spent the day today reinstalling one of the air conditioners on our 1987 Avion travel trailer. It originally had only one, installed over the center of the trailer. It always did real well, but because our travels usually take us to Baton Rouge (an upcoming trip in mid July), we would really be in a pickle if our only air conditioner pooped out. So, I ordered a new one and installed it in the center, then wanted to install the old one over the rear bedroom where a roof vent already was. So today, I removed the vent, which was a Hammond vent with a two-speed fan. These Hammond vents had radiused corners as opposed to square. The opening in the roof was already 14", so I had to use some snips to sqare up the opening, then installed the air conditioner. Then, ran some romex and connected it to a breaker. Checked it out and it works well. So, It will be available if we need it! I still need to enclose about three feet of romex in some stick-on cover that I can get at Lowes. My next project will be to convert this trailer from 30A service to 50A service..... maybe this Fall when it's cool. 4 Share this post Link to post Share on other sites
8ntruck 9,042 #9747 Posted June 15 We've got a small Coleman. The a/c is a through the wall unit over the bed. Noise is an issue. We got the bright idea that a roof top unit would be quieter - maybe. Also, a heat pump would give us the option of heat. Not gonna happen until later this year, though. I'm wondering about roof framing considerations. Ought to figure that out before chopping a hole in the roof. 2 Share this post Link to post Share on other sites
ebinmaine 79,650 #9748 Posted June 15 11 hours ago, Razorback said: already 14", Are roof top AC units that small? Share this post Link to post Share on other sites
Razorback 1,358 #9749 Posted June 15 4 hours ago, ebinmaine said: Are roof top AC units that small? The opening through the roof is pretty much a standard 14”. The entire unit is much larger, but the opening is only 14”. 1 Share this post Link to post Share on other sites
ebinmaine 79,650 #9750 Posted June 15 4 hours ago, Razorback said: The opening through the roof is pretty much a standard 14”. The entire unit is much larger, but the opening is only 14”. Gotcha. I ask because I've seen pickups and semis with what appears to be RV style AC units on the roof. If that's a feasible option id consider it for my Ford. A very small one..... Done right... they look ok. Share this post Link to post Share on other sites
