ebinmaine 79,502 #9276 Posted January 19 11 minutes ago, adsm08 said: help a friend and his son do exhaust manifolds on the son's 5.4 F150. That's an "if you know, you know" thing I know I wouldn't touch one o' them with a 39 1/2 foot pole... 1 Share this post Link to post Share on other sites
c-series don 12,045 #9277 Posted January 19 Well it’s not what I did today, but this past week. Myself and another guy dug the hole for a foundation of a new house. Mostly I push material to the guy in the excavator who bales it out of the hole. Then I finish grade the bottom of the hole with the dozer +/- 2” for the masons. The hole is almost but not finished in the picture, I just snapped it after lunch one day. This is in one of the most expensive zip codes in the country. 1.9 acre lot- 7 million dollars. Spec house that will probably list for around 23 million! This whole area used to be nothing but farmland mostly potatoes and corn. From this point you used to look across approximately a mile of fields and see the ocean. Now it’s mostly houses with some occasional fields. It’s sad really. 9 Share this post Link to post Share on other sites
Blue Chips 798 #9278 Posted January 19 12 hours ago, adsm08 said: I went home to help a friend and his son do exhaust manifolds on the son's 5.4 F150. That's an "if you know, you know" thing. They worked on it almost all day yesterday, and a good chunk of today, I was only around for about 6 hours. We just finished up about 8 PM. I remember a couple of long sessions with Ford Triton exhaust manifolds on my previous pickup (fF250 with the V10 version of the Triton). There were several exhaust manifold studs that needed to be replaced. It was a great truck and engine, but it had a tendency to snap exhaust manifold studs. I managed to replace several studs without removing very much in the way of hardware by welding nuts onto the ends of the broken studs so that I could remove them. It was very tedious and fussy to weld in such an awkward position. I had to use a mirror for one of them so that I could see where I was welding. If I were going to do it over again, I think I'd bite the bullet and remove whatever was in the way. 1 Share this post Link to post Share on other sites
Ed Kennell 46,462 #9279 Posted January 19 1 hour ago, Blue Chips said: I had to use a mirror for one of them Reminds me of using a periscope for some welding in tight spaces. 2 Share this post Link to post Share on other sites
Treepep 1,137 #9280 Posted January 19 On 6/21/2025 at 10:02 PM, Ed Kennell said: Got home from the Big Show Friday night and reloaded to head West or my Sisters 80th buirthday party this morning. Four hours out, five at the party, and four hours return. A quality day with the family, but I'm pooped. Handsome family! N ot certain that dog house in the last picture is going to work.. Each their own and stuff 2 Share this post Link to post Share on other sites
Ed Kennell 46,462 #9281 Posted January 19 55 minutes ago, Treepep said: Not certain that dog house in the last picture is going to work. The bear proof bird feeder. 1 1 2 Share this post Link to post Share on other sites
adsm08 4,747 #9282 Posted January 19 8 hours ago, Blue Chips said: I remember a couple of long sessions with Ford Triton exhaust manifolds on my previous pickup (fF250 with the V10 version of the Triton). There were several exhaust manifold studs that needed to be replaced. It was a great truck and engine, but it had a tendency to snap exhaust manifold studs. I managed to replace several studs without removing very much in the way of hardware by welding nuts onto the ends of the broken studs so that I could remove them. It was very tedious and fussy to weld in such an awkward position. I had to use a mirror for one of them so that I could see where I was welding. If I were going to do it over again, I think I'd bite the bullet and remove whatever was in the way. I would rather have been doing that job on that particular truck. The shock towers unbolt from the frame leaving the whole thing out in the open, and the metal the 2V studs were made of drilled much nicer. Some idiot at Ford thought using hardened metal on the studs for the 3V would make them less likely to snap. It just makes them less likely to drill. 2 Share this post Link to post Share on other sites
adsm08 4,747 #9283 Posted January 19 21 hours ago, ebinmaine said: I know I wouldn't touch one o' them with a 39 1/2 foot pole... I did more than that. I stopped playing nice. 3 1 Share this post Link to post Share on other sites
Blue Chips 798 #9284 Posted January 20 2 hours ago, adsm08 said: The shock towers unbolt from the frame leaving the whole thing out in the open, and the metal the 2V studs were made of drilled much nicer. Some idiot at Ford thought using hardened metal on the studs for the 3V would make them less likely to snap. It just makes them less likely to drill. My F250 4x4 had the earlier 2V version of the V10, which was simpler and probably more reliable than the later 3V version, which seemed to have a reputation for valve timing related issues. Share this post Link to post Share on other sites
Beap52 2,337 #9285 Posted January 20 22 hours ago, c-series don said: This whole area used to be nothing but farmland mostly potatoes and corn. From this point you used to look across approximately a mile of fields and see the ocean. Now it’s mostly houses with some occasional fields. It’s sad really. I was telling my wife a couple of days ago that it saddens me to see our farmlands being busted up into small acreages. Minimum lot size in rural areas in Missouri are one to three acres dependent upon soil condition and perking for septic systems and wells. Our subdivision started out with lot size of about 1 1/4 acres. Then when the law changed, the remaining lots became 2 1/2 acres. 2 1/2 acres is a lot to mow, In my opinion, they certainly don't need that much land for septic system and well. Land here in south Missouri isn't THAT productive but these overly-large lots are NOT productive. We've got several farms being broken into 5 to ten acres. I understand housing needs and I wouldn't want to give my 1 1/4 acres for a 1/3 acre lot in town. On the other hand, some of the lots in town a person can barely ride a mower along side of the house. There's 400 acres just down the road with a gravel road through it and homes being built. Progress I suppose. Our family farm is pretty safe from "development". It already has three oil lines and two overhead power lines and a oil pumping station on it. 1 1 Share this post Link to post Share on other sites
Beap52 2,337 #9286 Posted January 31 Earlier this week I posted that we were scanning slides. Well, we moved to pictures. There were three footlockers full of albums of pictures. We removed all pictures, assigned them to a person, or topic or happening in our life. Below is five piles of pictures and we had at least five or six more piles. When I scanned our son's pictures it came to more than 150 pictures. I'm estimating over 1,500 pictures and we omitted pictures of rocks, trees, mountains most anything that didn't include a family member. We are planning on keeping just a few actual pictures--the rest burned. When we moved mom into assisted living, we burned boxes and boxes of pictures simply because no one had or was willing to take the time to save them. 4 Share this post Link to post Share on other sites
c-series don 12,045 #9287 Posted January 31 (edited) @Beap52 I seem to be the one in my family who now has all that kind of stuff. Other family members keep dropping off pictures, old newspaper clippings etc off and it’s driving my wife nuts! She keeps saying what are we going to do with all this stuff? And when are we going to properly sort it out and/or even look at it? I’m hoping to have a night with my relatives so we can look at old slides soon. Seems like it would be a nice way to spend a cold winter’s night. Edited January 31 by c-series don 5 Share this post Link to post Share on other sites
ebinmaine 79,502 #9288 Posted January 31 12 below zero this morning!! Definitely a good day to be inside working on models. 1 Share this post Link to post Share on other sites
Ed Kennell 46,462 #9289 Posted January 31 1 minute ago, ebinmaine said: 12 below zero this morning!! A balmy +7 here. I may have to venture out to bring in a trailer load of wood this morning. 2 Share this post Link to post Share on other sites
ebinmaine 79,502 #9290 Posted January 31 1 minute ago, Ed Kennell said: A balmy +7 here. I may have to venture out to bring in a trailer load of wood this morning. We will too but wait til it's warm. Like 9 above. Share this post Link to post Share on other sites
adsm08 4,747 #9291 Posted January 31 This is my plan for most of the day: https://www.autoshowharrisburg.com/ We get free tickets most years, so we go up, get breakfast, and go to the show for a few hours. The kids like that they can get in and touch the cars, I like that they aren't in front of a screen and that we are inside. 1 1 Share this post Link to post Share on other sites
76c12091520h 4,236 #9292 Posted January 31 Spending a cold, dreary Saturday at the office: 5 5 1 Share this post Link to post Share on other sites
ebinmaine 79,502 #9293 Posted February 7 Pretty busy indoor work day around here. I got some more work done on my new scale model building setup. Trina bought herself a new computer desk for her home office. It's functional but could be bigger and the keyboard holder didn't fit between the table legs. We made this larger top out of plywood. She painted it to match and got it all set up. The BBT aka Paint Department has been itching to get the one dark wall of the kitchen redone. She's never been fond of that color. Today she got some darker gray and combined that with white we had here to make a medium gray. 1 2 Share this post Link to post Share on other sites
Bill D 2,976 #9294 Posted February 7 6 minutes ago, ebinmaine said: Pretty busy indoor work day around here. I got some more work done on my new scale model building setup. Trina bought herself a new computer desk for her home office. It's functional but could be bigger and the keyboard holder didn't fit between the table legs. We made this larger top out of plywood. She painted it to match and got it all set up. The BBT aka Paint Department has been itching to get the one dark wall of the kitchen redone. She's never been fond of that color. Today she got some darker gray and combined that with white we had here to make a medium gray. The original color reminds me of my Dad's old 1962 Willys Wagon. Very similar color. 1 Share this post Link to post Share on other sites
ebinmaine 79,502 #9295 Posted February 8 Last year I lost 30 lbs. Went "off the wagon" and gained 20. Net loss 10. This year my food cravings have been absolutely uncontrollable on some days. Can't keep that pattern. At 10 AM, I'm around 39 hours into a fast, not counting half n half for coffee & tea. Feel good. 4 lbs down since Friday morning. 10 lbs down in about 2 weeks. I don't have a specific time length goal. Just going until I feel a serious energy drop. Hoping for sometime this afternoon but IF I feel tolerable I'll keep going. 1 Share this post Link to post Share on other sites
Blue Chips 798 #9296 Posted February 13 (edited) On 1/19/2026 at 8:41 PM, Beap52 said: On 1/18/2026 at 9:21 PM, c-series don said: This whole area used to be nothing but farmland mostly potatoes and corn. From this point you used to look across approximately a mile of fields and see the ocean. Now it’s mostly houses with some occasional fields. It’s sad really. I was telling my wife a couple of days ago that it saddens me to see our farmlands being busted up into small acreages. Minimum lot size in rural areas in Missouri are one to three acres dependent upon soil condition and perking for septic systems and wells. Our subdivision started out with lot size of about 1 1/4 acres. Then when the law changed, the remaining lots became 2 1/2 acres. 2 1/2 acres is a lot to mow, In my opinion, they certainly don't need that much land for septic system and well. Land here in south Missouri isn't THAT productive but these overly-large lots are NOT productive. We've got several farms being broken into 5 to ten acres. I understand housing needs and I wouldn't want to give my 1 1/4 acres for a 1/3 acre lot in town. On the other hand, some of the lots in town a person can barely ride a mower along side of the house. There's 400 acres just down the road with a gravel road through it and homes being built. Progress I suppose. Our family farm is pretty safe from "development". It already has three oil lines and two overhead power lines and a oil pumping station on it. I know what you mean about farmland disappearing to feed urban and suburban development, as a combination of factors can make it more desirable to an owner or an owner's family to sell instead of keep farming. A couple of years ago, we sold our 42-acre 'project' house and property. Fortunately, the people who bought that property don't seem interested in subdividing, and I'm hoping that they will set up a conservation easement or some kind of restrictive covenant that would prevent subdivision and allow its use as farmland. Its location was quite far from areas of significant suburban development (probably too far to interest the typical developer), and Maine's population growth rate is pretty slow, but you never know how things might change over the years. Even though we weren't 'farming,' I did continue to maintain its 20 acres of fields with regular mowing over the 17 years that we owned it to prevent the forest from taking over (which can happen very rapidly) and to gradually build up the soil with 'green manure.' Below is a photo of one of the fields, taken when I was mowing it several years ago. We are down to one property now, where we have been living for about 12 years, and I must say that since we are now only maintaining one property instead of two, we have quite a bit more free time to pursue other interests. Our current residence is on a 2-1/4 acre lot, which is mostly wooded and large enough to give us pretty decent privacy. Minimum lot size in our zoning district is 1-1/2 acres. To be honest, I wouldn't mind having a bit of extra land, at least on one side of our lot, but I'm not complaining. One thing that helps is that we're on a large river, and the visible island is town-owned land and is not buildable, so our view and privacy in that direction is protected. On 2/7/2026 at 6:49 PM, ebinmaine said: Today she got some darker gray and combined that with white we had here to make a medium gray. I like the new color! Edited February 13 by Blue Chips 4 1 Share this post Link to post Share on other sites
Ed Kennell 46,462 #9297 Posted February 14 6 hours ago, Blue Chips said: it saddens me to see our farmlands being busted up I'm thankful the Amish have deep pockets i my area. 3 Share this post Link to post Share on other sites
Blue Chips 798 #9298 Posted February 14 13 minutes ago, Ed Kennell said: 6 hours ago, Blue Chips said: it saddens me to see our farmlands being busted up I'm thankful the Amish have deep pockets i my area. Ed, that was actually a quote from @Beap52, not me, but I agree with him. 2 1 Share this post Link to post Share on other sites
19richie66 17,922 #9299 Posted February 14 Same here and where I moved from in Florida. Land is farmed and handed down through generations. Today it’s easier to make a lot of money at one time selling it off than farming it. All the orange groves I grew up around in central Florida are gone. Loved the smell of orange blossoms when they were in full bloom. Houses and apartment buildings don’t have the same aroma. 3 4 Share this post Link to post Share on other sites
8ntruck 9,021 #9300 Posted February 14 The robotics team finally got the development robot together yesterday. The initial systems testing is encouraging. That machine will now be turned over to the programming group so they can assemble the various bits of code they have been working on so we can get into serious software development and tuning. A big sign that spring is coming has appeared - Mac Donald's is now selling their green milk shakes! Mrs 8n and I have picked up a volunteer project at the KATY Depot museum here. Part of the museum is the REA freight building. Years ago, we were involved with developing an area in that building where model trains could be displayed and where kids programs could be held. 5 or 6 years ago, we passed that on to others. We stopped by the museum the other day to see what was going on. Turns out that there is a new person volunteering to work on that project. We have offered to help with that transition until we go back to Michigan later this spring. 2 1 Share this post Link to post Share on other sites
