Handy Don 17,735 #8776 Posted August 28, 2025 1 hour ago, 8ntruck said: Yup. You need 1/16 or 1/8 per side on the larger bits to prevent snagging the bit. So 1/8th pilot, then 3/8ths, then 5/8ths? Share this post Link to post Share on other sites
Lane Ranger 12,167 #8777 Posted August 28, 2025 (edited) Today i bought something I could not refuse! Lots of original parts in great shape ( and a few not that great like wheels but still with original tires and frint still loaded ). The seller was mowing with it when i went to look ( but i took my trailer) . I drove in third gear and accidentally hit the kill switch - still working! The Schnacke recoil, the rear hitch attachment connector, the showerhead muffler , an oil bath air cleaner with original decal, all the guards ( and belt guard had the original spacers with it) with no rust holes, a pretty early seat cushion, tight steering and a very good operating transmission snd motor! Somehow this survived 67 years. No crack on hood around gas tank. Gas tank very clean! yes the wheels have some rust and a few holes but tires all appear original to me. I think the decal ar back and the frame decal with # 12510 may be replaced decals but maybe that was the original #. I need a sixth RJ like a hole in the head but i got this on west side if Indianapolis near Raceway Road today! I am happy to have gone after it! Edited August 28, 2025 by Lane Ranger 2 10 Share this post Link to post Share on other sites
8ntruck 9,420 #8778 Posted August 28, 2025 49 minutes ago, Handy Don said: So 1/8th pilot, then 3/8ths, then 5/8ths? It would be worth a try. What kind of drill are you using? Trick is to keep all of the drills purpundicular to the surface. If you are drilling steel, oil while drilling helps reduce chatter. I had Marvel Mystery Oil handy, so that is what I used with the 3/4" holes saw today. 1 Share this post Link to post Share on other sites
953 nut 70,649 #8779 Posted August 28, 2025 12 hours ago, 8ntruck said: I did bend a pilot drill in the hole saw. The pilot drill broke through the material suddenly, then one side of the hole saw caught, pushing everything sideways. I drill a 1/4" hole first then go to the hole saw now. I bent/broke a few pilot bits before I figured that out. 2 Share this post Link to post Share on other sites
Handy Don 17,735 #8780 Posted August 28, 2025 12 hours ago, 8ntruck said: It would be worth a try. What kind of drill are you using? Trick is to keep all of the drills purpundicular to the surface. If you are drilling steel, oil while drilling helps reduce chatter. I had Marvel Mystery Oil handy, so that is what I used with the 3/4" holes saw today. 2 hours ago, 953 nut said: I drill a 1/4" hole first then go to the hole saw now. I bent/broke a few pilot bits before I figured that out. I didn’t have my hole saws with me or I would for sure have gone with one of those instead. I did have, and always use, cutting fluid or oil for lubrication, cooling, and to contain the metal cuttings. Keeping the heat down, iMHO, helps extend the life of the drill bits. (Always the tradeoff between drill speed and feed pressure, of course!) 1 1 Share this post Link to post Share on other sites
Handy Don 17,735 #8781 Posted August 28, 2025 On 8/26/2025 at 5:50 PM, Beap52 said: the movie "Bridge over the River Kwai" I first saw that movie as a pre-teen. It was the beginning of my realization that not all choices of actions in life would be simple. A phrase my Dad often used was “Any child can distinguish black and white. Adults have to discern among shades of gray." 1 1 Share this post Link to post Share on other sites
ranger 1,871 #8782 Posted August 28, 2025 3 hours ago, Handy Don said: I didn’t have my hole saws with me or I would for sure have gone with one of those instead. I did have, and always use, cutting fluid or oil for lubrication, cooling, and to contain the metal cuttings. Keeping the heat down, iMHO, helps extend the life of the drill bits. (Always the tradeoff between drill speed and feed pressure, of course!) When I use a hole saw, I drill a 1/4” hole first and have a piece of 1/4” plain rod in the hole saw arbour in place of the drill bit. I’ve found that using the hole saw with the drill bit in the arbour, the flutes of the drill bit can cause the saw to chatter and wander until the cut has started. Using a plain rod instead of the bit prevents this from occurring 1 4 1 Share this post Link to post Share on other sites
Beap52 2,536 #8783 Posted August 28, 2025 22 hours ago, Lane Ranger said: I have never seen a set of blades like that! I saw and learned something new today. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #8784 Posted August 29, 2025 6 hours ago, ranger said: When I use a hole saw, I drill a 1/4” hole first and have a piece of 1/4” plain rod in the hole saw arbour in place of the drill bit. I’ve found that using the hole saw with the drill bit in the arbour, the flutes of the drill bit can cause the saw to chatter and wander until the cut has started. Using a plain rod instead of the bit prevents this from occurring Thanks, Ranger, this is a trick I’ll try to remember! 1 Share this post Link to post Share on other sites
wallfish 20,744 #8785 Posted August 29, 2025 23 hours ago, Lane Ranger said: I am happy to have gone after it! Very Nice score Lane! It's got ALL the goodies and that's a rare find in itself 1 Share this post Link to post Share on other sites
Lane Ranger 12,167 #8786 Posted August 29, 2025 17 minutes ago, wallfish said: Very Nice score Lane! It's got ALL the goodies and that's a rare find in itself This is the first time i ever saw or came across this bar with two holes that is used on the lift hitch. No drawing in the RJ manuals or part number! Share this post Link to post Share on other sites
Handy Don 17,735 #8787 Posted August 29, 2025 5 minutes ago, Lane Ranger said: This is the first time i ever saw or came across this bar with two holes that is used on the lift hitch. No drawing in the RJ manuals or part number! Certainly not an RJ expert, but I’m looking at how it’s not snug in the slot hitch and thinking “nice bit of fabrication by a PO" 2 Share this post Link to post Share on other sites
ranger 1,871 #8788 Posted August 29, 2025 (edited) 17 hours ago, Handy Don said: Thanks, Ranger, this is a trick I’ll try to remember! You can, at a pinch, reverse the drill bit in the arbour after drilling the hole, if you don’t have any 1/4” rod? I’ve found that this “trick” goes a long way in preventing oversized and out of round holes, especially in thin steel sheet. Edited August 29, 2025 by ranger 1 Share this post Link to post Share on other sites
wallfish 20,744 #8789 Posted August 29, 2025 8 hours ago, Lane Ranger said: This is the first time i ever saw or came across this bar with two holes that is used on the lift hitch. No drawing in the RJ manuals or part number! That tow bar is probably original too. They did fit in there pretty loose and the original pin was an eye bolt like that. Most of the time that eye bolt has been long gone and replaced by a standard bolt. Even the eye bolt looks old. Of coarse a piece of bar and an eye bolt can always be replaced pretty easily. Probably find it in a drawing for a trailer or towed attachment 3 Share this post Link to post Share on other sites
Lane Ranger 12,167 #8790 Posted August 29, 2025 (edited) 9 hours ago, Handy Don said: Certainly not an RJ expert, but I’m looking at how it’s not snug in the slot hitch and thinking “nice bit of fabrication by a PO" don i think it is an original. I have several homemade type myself but this just has the feel and look of original. i just was surprised as i took it out of the rear fender tool box! Edited August 29, 2025 by Lane Ranger 1 Share this post Link to post Share on other sites
Lane Ranger 12,167 #8791 Posted August 29, 2025 Ok this is some more detail on the RJ slot hitch connector bar that came with the RJ I bought the other day. I think it is an original Wheel Horse part although I have never seen or owned a similar one. I own several homemade versions and a made a couple myself but this came with an RJ that was well loved for 67 years as it has almost o all of its original parts. But I am posting pics and measurements for those that would like to make one. width in first oic is 1 3/4 inch length is 7 inches holes on each end are 3/4 centered from each end. Holes are 9/16ths thickness is 1/2 inches 2 Share this post Link to post Share on other sites
Ed Kennell 47,942 #8792 Posted August 29, 2025 Took Mrs. K to lunch at one of our favorite restaurants, Lee's Landing on the Susquehanna river in Port deposit, Md. This is a couple mile down river from the Conowingo Hydro Dam where I fish for striped bass early in the spring. Then went to the other side of the river to the boat launch. That black roof between the white is the restuarant. 5 Share this post Link to post Share on other sites
nylyon-(Admin) 9,196 #8793 Posted August 29, 2025 Neighbor stopped by with his skid steer and really helped me clean up some of the debris piles and overgrown brush I had. Awesome neighbors! Just need a small excavator to finish up (anyone near by with a mini excavator want to help ) It was all fun and games until we disturbed a big bee nest, little guys got me 11 times, good thing I am not allergic! 7 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #8794 Posted August 30, 2025 Coffee. I'm drinking lovely cowboy coffee. 🤠 1 Share this post Link to post Share on other sites
Handy Don 17,735 #8795 Posted August 30, 2025 1 hour ago, ebinmaine said: Coffee. I'm drinking lovely cowboy coffee. 🤠 Drinking or chewing (or both)? 😉 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #8796 Posted August 30, 2025 18 minutes ago, Handy Don said: Drinking or chewing (or both)? 😉 Mostly drinking.... Share this post Link to post Share on other sites
nylyon-(Admin) 9,196 #8797 Posted August 30, 2025 Cleared up more of the yard, found another bee;s nest, got another sting, even dozen now. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #8798 Posted August 30, 2025 Did more edging around the new shed (almost a year old so maybe not new). 5 Share this post Link to post Share on other sites
ebinmaine 81,281 #8799 Posted August 31, 2025 1 hour ago, nylyon said: Cleared up more of the yard, found another bee;s nest, got another sting, even dozen now. 😬 Share this post Link to post Share on other sites
adsm08 5,247 #8800 Posted August 31, 2025 I finally got some good news on the Escape today. I pulled the outer rocker off, and the inner is solid in front of the the door jamb. Got a light in through a factory hole and inspected, the inside of the rocker and torque box up there look brand new. That means a lot less work overall. Gonna hit the inside of the box with cavity wax, or maybe some linseed oil, and start piecing the back of the inner back together. 2 Share this post Link to post Share on other sites
