Blue Chips 843 #10051 Posted September 21 (edited) I did some more work on the full-flow oil filtration conversion on my Dodge M37's engine. I decided to slightly revise the external filter plumbing---just some minor adjustments to get a better fit. (BTW, just as an explanatory note, the way the original bypass filtration worked in the old MoPar flathead six in my Dodge M37, only a small percentage of the oil was diverted through the filter; the bulk of the oil was delivered to the bearings, etc., with no filtration whatsoever. Eventually, all of the oil would pass through the filter, but if there was any dirt/debris in the oil, it would typically loop through the system many times before it all got filtered out. The later versions of this engine went to a full-flow system, so that all of the oil is filtered before it reaches the bearings. The original bypass filter media was very fine and could trap very small particles, but I think that a modern spin-on oil filter in a full-flow system should do a very adequate job of filtering, while eliminating the possibility of major damage/wear from any larger particles.) First, I bored the NPT end of a male 1/4" NPT-to-JIC AN-8 adapter so that the NPT end has the same ID as the JIC end of the adapter, and also matches the standard (almost 3/8") ID of the 1/4" schedule 40 pipe. This will still allow me to maintain that full inside diameter all the way from the oil pump to the filter and back. I turned down part of the hex area of a 1/4" female NPT-to-JIC AN-8 adapter to provide more clearance from an adjacent adapter: The net effect of the adapter changes will be to lower everything just enough to allow me to pull the valve compartment cover straight out, without having to maneuver it over the tubing, and it will also move the tubing a little farther away from the exhaust manifold. Here's a loose/dry fit-up just to get a general idea of how the fittings should work with each other: I'm about halfway through reassembling the transmission, which I'm totally rebuilding, but I'm waiting for a snap ring to arrive. It can be a little frustrating to get hung up by such a seemingly minor part, but the groove width and diameter are kind of unusual, so 'standard' inch sizes wouldn't work properly. I finally found a metric heavy-duty retaining ring that should be a good fit, both in terms of diameter and thickness. I'm also still in the process of making a couple of upgrades to the engine valves and connecting rods, beyond what the machine shop did for me. More on that later. Edited September 21 by Blue Chips 4 4 Share this post Link to post Share on other sites
Handy Don 17,412 #10052 Posted Tuesday at 04:35 PM (edited) Over the last several days I’ve been moving trailer loads of wood chips to cover our now-sunlit hillside. Goal is to prevent an explosion of weed growth on an un-mowable slope left by the arborists when we removed a bunch of invasive Norway Maple trees . I carved out a temporary level “notch” in the hillside to park the tractor and loaded trailer on the trips up the hill. I need the tire chains for traction (visible tracks in the pic) and I keep the mower deck and front weights mounted for extra confidence. (The trailer attaches to the below-rear-axle standard drawbar--also good.) Going down, I walk the empty trailer and drive the tractor in 1st with my foot holding the clutch pedal up firmly. Progress has been slow and exhausting so I’ll be hiring some workers to help me finish it off. Edited Tuesday at 04:37 PM by Handy Don 1 6 Share this post Link to post Share on other sites
CasaytheMann 262 #10053 Posted Wednesday at 02:09 AM (edited) On 9/21/2026 at 4:37 AM, ebinmaine said: Got pics? I'll post some tomorrow. I was too busy changing out the upper radiator hose on the wife's 2013 Dodge Dart. What a chore! Edited Wednesday at 02:09 AM by CasaytheMann Share this post Link to post Share on other sites
ebinmaine 80,496 #10054 Posted Wednesday at 09:34 PM My excavator company owner called this morning. They are getting done with a job a little sooner than they thought and he wants to try to send his operator over to our place soon. Maybe next week. I was hoping to be there so I can help cut some trees but at least this way we should be able to get the flat spot for the new metal camper storage building all set up. Here's a couple pics of the approximate new building location from the house front. The red tape stripe is the CLOSE side to the road. We've marked that stripe 80 feet from centerline. 75 ft is minimum. The new building will be to the left of the red tape. The new flat spot will be approximately 24 feet square. Obviously several loads of good fill will be added. Orange X trees will be removed. Any trees with a RED tape are 99% NO touch. BLUE tape is: leave if possible but no worries if they're in the way. There are several other trees in other yard areas marked as such. 4 1 Share this post Link to post Share on other sites
CasaytheMann 262 #10055 Posted Wednesday at 11:23 PM Here's the pics I promised. 1 2 Share this post Link to post Share on other sites
ebinmaine 80,496 #10056 Posted Wednesday at 11:29 PM 5 minutes ago, CasaytheMann said: Here's the Like the real bike stand! 1 Share this post Link to post Share on other sites
CasaytheMann 262 #10057 Posted Wednesday at 11:48 PM Lol. It's the cheapest one on Amazon. 1 Share this post Link to post Share on other sites
8ntruck 9,262 #10058 Posted Friday at 03:24 AM I remade a chipboard/melamine shelf into a narrower shelf to fit between the Murphy bed and wall at the lake house. This will be the 3rd or 4th life for that shelving unit. 4 Share this post Link to post Share on other sites
Beap52 2,448 #10059 Posted Friday at 10:17 PM Spent the day with a friend after he asked me if I could sit with him while his wife went to work. Marty fell 2 1/2 years ago on a construction site pretty much destroying both of his ankles. He had (what seems like his umpteenth surgery) this week and his wife wanted someone to keep an eye on him. He is hoping one more surgery will patch him up as best as he will ever be sometime early next year. Interesting that a fellow learns about another fellow if you have six hours of just sitting and talking. 7 Share this post Link to post Share on other sites
ebinmaine 80,496 #10060 Posted Friday at 10:34 PM 19 hours ago, 8ntruck said: 3rd or 4th life for that shelving unit. Nicely done. Trina would be happy with you. Share this post Link to post Share on other sites
953 nut 68,953 #10061 Posted Friday at 11:19 PM 59 minutes ago, Beap52 said: could sit with him May God bless you for your loving care for a friend. 1 1 3 Share this post Link to post Share on other sites
CasaytheMann 262 #10062 Posted Saturday at 12:37 AM (edited) I've almost finished the wife's bicycle. Just waiting on parts for the rear brakes. Edited Saturday at 12:37 AM by CasaytheMann 1 7 Share this post Link to post Share on other sites
Ed Kennell 47,183 #10063 Posted Saturday at 02:16 PM Mountain Man breakfast this AM. Eggs, deer scrapple, home fries and onions. 4 6 1 Share this post Link to post Share on other sites
ebinmaine 80,496 #10064 Posted Saturday at 02:44 PM I rolled my left ankle at work yesterday so I'm spending the weekend with it off the ground. 😬 8 Share this post Link to post Share on other sites
SylvanLakeWH 32,373 #10065 Posted Saturday at 03:12 PM 25 minutes ago, ebinmaine said: I rolled my left ankle at work yesterday so I'm spending the weekend with it off the ground. 😬 That sucks... Take it easy!!! Make sure BBT gets all your work done... 4 Share this post Link to post Share on other sites
ebinmaine 80,496 #10066 Posted Saturday at 03:38 PM 25 minutes ago, SylvanLakeWH said: That sucks... Take it easy!!! Make sure BBT gets all your work done... She already did. And she also drove all the way to my mom's house to help throw her an 80th birthday party 🎈 3 Share this post Link to post Share on other sites
adsm08 5,098 #10067 Posted Saturday at 09:39 PM (edited) I actually got to some of my own work today, since no one else was home. I finished installing the last of the planned outlets in the garage, but now my need two more some something else being added to the plan, then I got the 220 outlet for the welder moved onto the lift, and added the drain pipe to the sink on the work bench. The actual work, plus the trip to Lowe's, took about 5 hours, a lot longer than it should have, but a few of the outlets I was working with are deeper than normal and thus required some non-standard solutions to fitment. In regular English, everything got installed sideways so the stress relievers could be installed at the "top" and "bottom" of the outlets, while still allowing for the run to be horizontal. Edited Saturday at 09:40 PM by adsm08 4 Share this post Link to post Share on other sites
8ntruck 9,262 #10068 Posted 23 hours ago We took a drive down to Lansing to attend the 2026 Lansing Sexton High School Athletic Hall of Fame inductions. My wife's dad and uncle were inductees for their performance on the wrestling team. Her dad in 1954 and her uncle in 1957. 6 Share this post Link to post Share on other sites
ebinmaine 80,496 #10069 Posted 10 hours ago Some good ankle color. 6 Share this post Link to post Share on other sites
Handy Don 17,412 #10070 Posted 9 hours ago 16 minutes ago, ebinmaine said: Some good ankle color. Ouch! 1 Share this post Link to post Share on other sites
cleat 9,312 #10071 Posted 9 hours ago 40 minutes ago, ebinmaine said: Some good ankle color. Looks very sore. What did you do ? 1 Share this post Link to post Share on other sites
ebinmaine 80,496 #10072 Posted 9 hours ago 3 minutes ago, cleat said: Looks very sore. What did you do ? Friday morning I rolled my left ankle. Stepped in a hole in the grass that wasn't clearly visible. Feels quite a fair amount better today. Share this post Link to post Share on other sites
Handy Don 17,412 #10073 Posted 9 hours ago 15 minutes ago, ebinmaine said: Feels quite a fair amount better today. Just the time when you’re tempted to shortcut your recovery! 🤨 1 Share this post Link to post Share on other sites
ebinmaine 80,496 #10074 Posted 8 hours ago 6 minutes ago, Handy Don said: Just the time when you’re tempted to shortcut your recovery! 🤨 Yepp. I've definitely done that in the past. As I've dealt with the body pain over the years I've learned NOT to shorten that. Share this post Link to post Share on other sites
squonk 48,020 #10075 Posted 8 hours ago New bucket cylinders on Elvis. 2 3 Share this post Link to post Share on other sites
