Mickwhitt
What did you do today?
ebinmaine
24 minutes ago, adsm08 said:
Yesterday I started into replacing the valve cover gaskets, plugs/wires, and thermostat on the Explorer. When I got the passenger side cover off I found the rear timing guide was broken (A known issue with this engine).
Today I started removing the engine to replace the timing cassettes. The front one isn't bad. The rear one requires removal of a bolt, that is behind an oil plug, that sits inside the footprint of the transmission bell.
Yeeeeesh.
adsm08
2 minutes ago, ebinmaine said:
Yeeeeesh.
Well, this is what happens when you take a reasonable, reliable, pushrod engine and give it to the Germans and ask them to make it OHC.
  • Sad 1
cleat
What year and engine is your explorer.
cleat
ineedanother
That sounds like a chapter in a day of my life :lol:
adsm08
Its an 04 with the 4.0 SOHC. This was a known issue with these engines which Ford didn't really get nailed down until 2005 or 2006.
I've owned this vehicle for 7 years and put 55 or 60k miles on it and have kind of suspected this guide was broken the whole time, but it hasn't been causing real issues, so I left it alone. I inspected it while doing valve cover gaskets and disturbed it. Now my technician brain won't let me put it back together broken.
I am also going to look at a Flex that's about 10 years newer next weekend to replace the Explorer. If I buy that I know two people in need of a vehicle right now who may either be given the Explorer outright or sell it to them very cheap, and I want to make sure its right if that happens.
  • Excellent 2
  • Heart 1
SylvanLakeWH
Another ski bench finished up...
Trash picked skis and bench sides / back...
Edited by SylvanLakeWH
  • Excellent 2
adsm08
Well after being yelled at over nothing by a psychotic co-worker, and then running out of gas on a test drive, I decided I did not hate my life enough yet today, sooooo....
Engine is out. I forgot the flexplate bolts are e-torx, so it can't go on the stand yet, because I didn't bring the right sockets home.
