Blue Chips 881 #9851 Posted July 16 On 7/11/2026 at 8:08 PM, ebinmaine said: We'll keep the search going for the next few weeks and see what pops up. What are your "ideal" property characteristics? I keep fairly close tabs on the real estate market---not because we're looking, but just because it's an interest of mine. If I hear of something that might fit the bill, I'd be happy to pass it on to you. Feel free to PM me. 1 Share this post Link to post Share on other sites
Blue Chips 881 #9852 Posted July 16 (edited) I've been tuning up the oil pump for my Dodge M37, per some recommendations from Tony Smith, a gentleman who is well versed in rebuilding and modifying these flathead sixes. I have an NOS oil pump and the original oil pump, which has VERY low miles on it. I compared several parameters, and found that the original pump was in great shape and actually had even better measurements/clearances than the NOS pump. Here's a photo comparing them (BTW, they are not clamped in the vise. I always use copper or aluminum jaw covers when clamping things like this.) This pump has the cloverleaf-style rotors, which should put out about 10% more volume than the star-type rotors for this engine, according to what I've read. I purchased a custom oil pump cover plate from Tony Smith that is flat within .0002" and thicker and more rigid than the original plate (original plate shown to the left of the new plate), along with a set of ARP bolts and washers of the appropriate length for use with the thicker plate. I gave the rotors and the end of the pump a very light dressing with a diamond hone plate, just to remove any high spots, and I ended up with .002" of end play, which should be about right. As with almost anything that I assemble, I cleaned the threads in the pump casting with a thread-chasing tool, solvent, and compressed air. You can see that the new cover plate is at least twice as thick as the original plate: I'm also considering drilling an oil hole near the top of the casting to improve lubrication to the shaft. I'll try it first on the NOS pump to make sure it goes smoothly before doing it to the pump that I'll be installing. As mentioned, I'm also planning to convert the engine to full-flow oil filtration, and I'll be using the 'green' (heavy) spring in the pressure relief valve. I might even consider converting the pressure relief valve to an adjustable version, which I've done with a couple of antique tractor engines. The pump will be completely filled/flooded with lubricant prior to final assembly, as it's a bad idea to run these pumps dry, even for a few seconds. Edited July 16 by Blue Chips 1 Share this post Link to post Share on other sites
adsm08 5,243 #9853 Posted July 16 I don't really remember what I did today, but I got paid for 14 hours for it. 2 1 4 Share this post Link to post Share on other sites
ebinmaine 81,159 #9854 Posted July 16 Crane work this morning. Flatbed with demountable forklift after. I managed to stay low carb today. Now we'll see how tomorrow goes... 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,202 #9855 Posted July 17 It was a short 5 hr shift at work today that about halfway through, we had a freak rainstorm that was snapping trees off and moving anything that wasn’t bolted down. Then, I mowed the fire station lawn, and my lawn as well. The new lock tited mule drive knob worked like a charm with no issues. Now just relaxing and browsing the internet. The next two days I have off and I have a bathroom that needs to have tile that needs to be finished up being taken out. At least it is supposed to get cooler. 1 Share this post Link to post Share on other sites
Brockport Bill 2,519 #9856 Posted July 17 came across a couple oldies today -- inlcuding an old horse - I have little knowledge of the early era models - What is this Tractor? - - Also found this belly grader under a 416 horse - is grader OEM ? Hopefully, I will get a better view in the future of both the oldie model tractor as well as the grader blade -- but in the mean time, any preliminary info would be appreciated ? Also, hoping to establish their approximate value ? thanks, Bill 2 Share this post Link to post Share on other sites
8ntruck 9,387 #9857 Posted July 17 We got home Monday evening from the driving tour we took the family of the Finnish exchange student we hosted at the turn of the century. They were here for 2 weeks. We traveled just over 1800 miles with stops in Chicago (Art and Field museums), our lake house here in MI. to celebrate July 4, Dayton, Oh. for the Air Force Museum, Williamstown, Ky. for the Ark Encouter, Bowling Green, Ky. to show his family where he stayed with us, then back to Chicago. Yesterday was a down day. Today, we started picking up and getting ready for more guests we are expecting this weekend. Many loads for the washing machine with bedding and towels. While I was working on our travel trailer, the smoke alarm went off - courtesy of the smoke cloud from forest fires in Canada that has settled on us. Also got my new grease gun assembled and loaded up. When I went to grease the spindles on my 42" SD deck, I discovered I will need a flexible hose to grease the center and LH spindles. Share this post Link to post Share on other sites
ebinmaine 81,159 #9858 Posted July 17 13 hours ago, Blue Chips said: What are your "ideal" property characteristics? I keep fairly close tabs on the real estate market---not because we're looking, but just because it's an interest of mine. If I hear of something that might fit the bill, I'd be happy to pass it on to you. Feel free to PM me. Very much appreciated. I'll talk to Trina about a list of wants/needs etc. 1 Share this post Link to post Share on other sites
ebinmaine 81,159 #9859 Posted July 17 6 hours ago, Brockport Bill said: the oldie model tractor Engine has bee swapped. Tractor appears to be late 60s/ early 70s like a Raider or Charger. 6 hours ago, Brockport Bill said: the grader blade Looks original. Obviously needs a clean up but has value. A LOT of value. Share this post Link to post Share on other sites
ebinmaine 81,159 #9860 Posted July 19 Reasonably productive weekend here. Saturday we set out to look at two pieces of land. 28 acres with very limited access. No cars. Larger 4WD trucks or ATV only. Nice. Very nice... but the access is an issue. Another piece is 10 acres. Good road access but very hilly where the driveway needs to be. HUGE expense to have a road put in because of super rocky mountain terrain. After that we had a great dinner with friends. Sunday morning Trina got our friend @Natejc_98's tractor all together ..then set to firewood production. I got my Echo CS490 saw chain sharpened and reinstalled. Tested that on some red oak. Went great. This saw has now had the adjuster caps removed and a muffler modification done. Excellent difference. I've ordered an aftermarket air filter set up for it as well. After that I cut some beech wood to 14 ish length amd tossed it towards the splitter. Trina and her momma processed that and stacked it. This afternoon I went out to the forest looking for a Peavey. Trina found that. I found a cable and two chains. Win! 2 Share this post Link to post Share on other sites
8ntruck 9,387 #9861 Posted July 19 (edited) Peavey, cable, and 2 chains - yours, or found items left by previous workers? I've noticed a langth of 5/8 or maybe 3/4 cable out in our Ky. property. One end is broken. I'll assume it was left by whoever logged the property maybe 10 or 15 years ago. Our series of guests have all gone now. Will be a week before the next batch arrive. I've been futzing around doing small projects today. Sat down for a brief water break and the dog climbed into my lap. Guess he was making sure I took a proper length break. Edited July 19 by 8ntruck 2 Share this post Link to post Share on other sites
ebinmaine 81,159 #9862 Posted July 19 20 minutes ago, 8ntruck said: Peavey, cable, and 2 chains - yours, or found items left by previous workers? All ours. Items we've inherited or accumulated over the years. Quite an assortment of log/tree pulling tools here. 3 Peavey brand cant hooks. 1 with a foot. Several chains of various lengths and capacities. Same for cables. 3 or 4 hand winches. A rope winch. 200 feet of thick rope. Tractors make great ballast occasionally but we usually try to tie off any winches to another tree. 1 Share this post Link to post Share on other sites
8ntruck 9,387 #9863 Posted July 22 What did I do? Not much. Walked the dog, filled the truck with gas, and cleared a couple of small projects off of my bench. One of those small projects was assembling a Milwaukee cultivator head. Of course, I had to go out and try it. Wouldn't want to break sod or do the initial springtilling with it, but it works pretty well. Since I had that power head out, I swapped over to the string trimmer and did the lake shore. 1 Share this post Link to post Share on other sites
ebinmaine 81,159 #9864 Posted July 22 Wiener mobile!!! This is one of the trucks I've piloted recently. We're taking some old scrap metal racks to recycling. 7 Share this post Link to post Share on other sites
ohiofarmer 3,529 #9865 Posted July 23 Worst piece of wood I ever tried to finish It was constantly fuzzy trying to sand it and possibly contaminated veith oil or Cosmoline. I used gel stain on it but it looked too much like paint . I used Danish oil on it and that made it some better but still not great. Finally after a couple of coats dried in I applied more and used 800 grit to take off the high and fill in the low. At least it's reasonably smooth and is sealing up well. Wood like this stains like a photo negative with the grain light and the field dark. Chinese Sks stock . 4 Share this post Link to post Share on other sites
ohiofarmer 3,529 #9866 Posted July 23 Finally I can load pictures again. Pictured here are two Pittsburgh Harbor Freight hammers. One has been heavily modified to reduce weight. The hickory handle they come with is hidden under some kind of ccc lacquer so I let the wood out to breathe in some Danish Oil. Big improvement.. I can drive nails faster with the aprox. eighteen ounce head than with the original 24. Both hammers bought new were only fourteen dollars combined so I can afford having a little fun with them. 2 Share this post Link to post Share on other sites
8ntruck 9,387 #9867 Posted July 23 The Generac standby generator has been whining about an oil change for about 6 weeks. No power outages in that time and we've been really busy with guests, besides, it only runs 10 minutes a week for exercise. Finally got to that job this afternoon. Checked the air filter and spark plugs while I was in there. Air filter OK, plugs were looking tired. It cranked over for 15 or 20 seconds when I started it to warm up the oil. With the new plugs, it went over maybe twice and caught. 2 Share this post Link to post Share on other sites
Beap52 2,523 #9868 Posted July 23 23 hours ago, ebinmaine said: Wiener mobile!!! You've seen one of six of them! We saw one a couple years ago here in SW Missouri. Big Boy would have been more exciting. 23 hours ago, ebinmaine said: 1 Share this post Link to post Share on other sites
953 nut 70,374 #9869 Posted July 24 On 7/22/2026 at 7:06 PM, ebinmaine said: Wiener mobile!!! Just one, how about all six of them on the Indianapolis Speedway. Can you say speedy sausages? 1 1 1 Share this post Link to post Share on other sites
ebinmaine 81,159 #9870 Posted July 25 Down to Massachusetts helping my mom for a day. Trina pressure washed the entire back deck. Scraped the old paint off. Repeat. Repeat. Then... Removed the chicken wire that stapled all over the inside to keep the former dog in. I added a few screws to the ballusters. We replaced a post off the back steps. Then Trina painted ALL of the vertical parts and rails and ballusters. Inside. Outside. Steps. New. Old. Completed, not like it used to be - half covered. Tomorrow morning she's intending to paint the deck surface. 2 3 1 Share this post Link to post Share on other sites
Bar Nuthin 3,524 #9871 Posted July 25 On 7/22/2026 at 7:06 PM, ebinmaine said: Wiener mobile!!! Well that's just nuts! 6 Share this post Link to post Share on other sites
adsm08 5,243 #9872 Posted July 25 This morning the boy and went and cut up, and hauled home, a walnut that fell down in a windstorm last weekend over at his girlfriend's house. I got a look at what is left of the tree, which is about 6/5-7 ft high, and a few feet around, standing dead. It isn't where it will do any damage, but I've got half a mind to go back and get the rest of it down and bring it back too. 3 Share this post Link to post Share on other sites
ebinmaine 81,159 #9873 Posted July 25 1 hour ago, adsm08 said: , standing dead. It isn't where it will do any damage, but I've got half a mind to go back and get the rest of it down and bring it back too. This is the time to harvest for firewood. Standing dead is good for wildlife too but we normally take em to burn. Share this post Link to post Share on other sites
adsm08 5,243 #9874 Posted July 25 55 minutes ago, ebinmaine said: This is the time to harvest for firewood. Standing dead is good for wildlife too but we normally take em to burn. I usually try to have my wood ready before now. I try to keep a year ahead, but I'm off the pace this year, and that tree would go a long way towards making up the difference. We are going to her grandson's birthday party another 20 minutes up the road next Saturday. I may go up and work on that in the morning, catch a ride with up with Kristin, go home after the party, and then come back for it Sunday, as she lives about 5 minutes from our church. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,202 #9875 Posted July 26 Today was a day off so I enjoyed it and did some straightening up around the house in the morning. Then in the afternoon I went to a friend’s annual Summer party that he has at his house/party area. Here’s some pics. The local band Rapid Transit did 70’s -90’s well done covers of some popular songs as the party wound down. The majority of the band is friends with my friend and a significant chunk of the attendees that they had known for years. The view as my father and I left for home. This is where the party was. 6 Share this post Link to post Share on other sites
