Mickwhitt
What did you do today?
ebinmaine
11 minutes ago, adsm08 said:
help a friend and his son do exhaust manifolds on the son's 5.4 F150. That's an "if you know, you know" thing
I know I wouldn't touch one o' them with a 39 1/2 foot pole...
  • Haha 1
c-series don
Well it’s not what I did today, but this past week. Myself and another guy dug the hole for a foundation of a new house. Mostly I push material to the guy in the excavator who bales it out of the hole. Then I finish grade the bottom of the hole with the dozer +/- 2” for the masons. The hole is almost but not finished in the picture, I just snapped it after lunch one day. This is in one of the most expensive zip codes in the country. 1.9 acre lot- 7 million dollars. Spec house that will probably list for around 23 million! This whole area used to be nothing but farmland mostly potatoes and corn. From this point you used to look across approximately a mile of fields and see the ocean. Now it’s mostly houses with some occasional fields. It’s sad really.
  • Like 9
Blue Chips
12 hours ago, adsm08 said:
I went home to help a friend and his son do exhaust manifolds on the son's 5.4 F150. That's an "if you know, you know" thing. They worked on it almost all day yesterday, and a good chunk of today, I was only around for about 6 hours. We just finished up about 8 PM.
I remember a couple of long sessions with Ford Triton exhaust manifolds on my previous pickup (fF250 with the V10 version of the Triton). There were several exhaust manifold studs that needed to be replaced.
It was a great truck and engine, but it had a tendency to snap exhaust manifold studs. I managed to replace several studs without removing very much in the way of hardware by welding nuts onto the ends of the broken studs so that I could remove them. It was very tedious and fussy to weld in such an awkward position. I had to use a mirror for one of them so that I could see where I was welding. If I were going to do it over again, I think I'd bite the bullet and remove whatever was in the way.
Ed Kennell
Reminds me of using a periscope for some welding in tight spaces.
Treepep
On 6/21/2025 at 10:02 PM, Ed Kennell said:
Got home from the Big Show Friday night and reloaded to head West or my Sisters 80th buirthday party this morning.   Four hours out, five at the party, and four hours return.   A quality day with the family, but I'm pooped.
105_1181.JPG.9a9547c8f33a851abce5a89cea948d4e.JPG105_1161.JPG.74b75f14f8077c9404e099af60932566.JPG105_1159.JPG.22a1574e021faae3d9ddf9e8a0b10577.JPG105_1167.JPG.5fea76ebfd0ce53e9d5d6c7b99231853.JPG105_1169.JPG.e7e387c2e52e40d69632002ffa0caf94.JPG
Handsome family!  N ot certain that dog house in the last picture is going to work..:lol:  Each their own and stuff:D
Ed Kennell
55 minutes ago, Treepep said:
  Not certain that dog house in the last picture is going to work.
The bear proof bird feeder.
  • Haha 2
adsm08
I would rather have been doing that job on that particular truck.
The shock towers unbolt from the frame leaving the whole thing out in the open, and the metal the 2V studs were made of drilled much nicer. Some idiot at Ford thought using hardened metal on the studs for the 3V would make them less likely to snap. It just makes them less likely to drill.
adsm08
I did more than that.
I stopped playing nice.
Blue Chips
My F250 4x4 had the earlier 2V version of the V10, which was simpler and probably more reliable than the later 3V version, which seemed to have a reputation for valve timing related issues.
Beap52
I was telling my  wife a couple of days ago that it saddens me to see our farmlands being busted up into small acreages.  Minimum lot size in rural areas in Missouri are one to three acres dependent upon soil condition and perking for septic systems and wells.  Our subdivision started out with lot size of about 1 1/4 acres.  Then when the law changed, the remaining lots became 2 1/2 acres.  2 1/2 acres is a lot to mow, In my opinion, they certainly don't need that much land for septic system and well.  Land here in south Missouri isn't THAT productive but these overly-large lots are NOT productive.  We've got several farms being broken into 5 to ten acres.  I understand housing needs and I wouldn't want to give my 1 1/4 acres for a 1/3 acre lot in town.  On the other hand, some of the lots in town a person can barely ride a mower along side of the house.   There's 400 acres just down the road with a gravel road through it and homes being built.  Progress I suppose.
Our family farm is pretty safe from "development".   It already has three oil lines and two overhead power lines and a oil pumping station on it.
  • Sad 1
Beap52
Earlier this week I posted that we were scanning slides.  Well, we moved to pictures.  There were three footlockers full of albums of pictures.  We removed all pictures, assigned them to a person, or topic or happening in our life.   Below is five piles of pictures and we had at least five or six more piles.  When I scanned our son's pictures it came to more than 150 pictures.  I'm estimating over 1,500 pictures and we omitted pictures of rocks, trees, mountains most anything  that didn't include a family member.  We are planning on keeping just a few actual pictures--the rest burned.  When we moved  mom into assisted living, we burned boxes and boxes of pictures simply because no one had or was willing to take the time to save them.
c-series don
@Beap52 I seem to be the one in my family who now has all that kind of stuff. Other family members keep dropping off pictures, old newspaper clippings etc off and it’s driving my wife nuts! She keeps saying what are we going to do with all this stuff? And when are we going to properly sort it out and/or even look at it? I’m hoping to have a night with my relatives so we can look at old slides soon. Seems like it would be a nice way to spend a cold winter’s night.
Edited by c-series don
  • Like 4
ebinmaine
12 below zero this morning!! Definitely a good day to be inside working on models.
Ed Kennell
A balmy +7 here.   I may have to venture out to bring in a trailer load of wood this morning.
ebinmaine
We will too but wait til it's warm. Like 9 above.
adsm08
This is my plan for most of the day:
https://www.autoshowharrisburg.com/
We get free tickets most years, so we go up, get breakfast, and go to the show for a few hours. The kids like that they can get in and touch the cars, I like that they aren't in front of a screen and that we are inside.
76c12091520h
Spending a cold, dreary Saturday at the office:
  • Excellent 4
  • Haha 1
ebinmaine
Pretty busy indoor work day around here.
I got some more work done on my new scale model building setup.
Trina bought herself a new computer desk for her home office. It's functional but could be bigger and the keyboard holder didn't fit between the table legs.
We made this larger top out of plywood. She painted it to match and got it all set up.
The BBT aka Paint Department has been itching to get the one dark wall of the kitchen redone. She's never been fond of that color.
Today she got some darker gray and combined that with white we had here to make a medium gray.
Bill D
The original color reminds me of my Dad's old 1962 Willys Wagon.  Very similar color.
ebinmaine
Last year I lost 30 lbs.
Went "off the wagon" and gained 20.
Net loss 10.
This year my food cravings have been absolutely uncontrollable on some days.
Can't keep that pattern.
At 10 AM, I'm around 39 hours into a fast, not counting half n half for coffee & tea. Feel good.
4 lbs down since Friday morning.
10 lbs down in about 2 weeks.
I don't have a specific time length goal. Just going until I feel a serious energy drop.
Hoping for sometime this afternoon but IF I feel tolerable I'll keep going.
