C_hasbeen 249 #1 Posted April 23, 2020 I bought this at an auction last year because it looked handy and only cost $8. I found it handy several times but don't know what it is called. 4 1 Share this post Link to post Share on other sites
ebinmaine 78,408 #2 Posted April 23, 2020 That's a wicked interesting piece. Not sure I've seen anything like it. 1 Share this post Link to post Share on other sites
Stepney 2,357 #3 Posted April 23, 2020 I had an old Vermette like that. I was told it was used in a railyard. Had a massive foot on it but otherwise looked identical. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #4 Posted April 23, 2020 I was thinking it might be a post puller or similar. 2 1 Share this post Link to post Share on other sites
857 horse 2,588 #5 Posted April 23, 2020 10 minutes ago, Dan.gerous said: I was thinking it might be a post puller or similar. 1 Share this post Link to post Share on other sites
C_hasbeen 249 #6 Posted April 23, 2020 Well I can call it a railway jack for pulling posts. 1 1 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #7 Posted April 23, 2020 3 minutes ago, C_hasbeen said: Well I can call it a railway jack for pulling posts. Railways have fences that need replacing from time to time, mystery solved 🤗 1 Share this post Link to post Share on other sites
Stormin 9,987 #8 Posted April 23, 2020 I'd go for an early version of high lift jack. Google Hi Lift Jack for the modern version. Farm Jack is another make. I've a Hi Lift that I used when off roading Land Rovers. Very handy but can be lethal if not used carefully. 3 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #9 Posted April 23, 2020 2 minutes ago, Stormin said: I'd go for an early version of high lift jack. Google Hi Lift Jack for the modern version. Farm Jack is another make. I've a Hi Lift that I used when off roading Land Rovers. Very handy but can be lethal if not used carefully. Yeah had a few close calls with those jack's and land rovers, used to use them all the time when we lived in the Falklands. When your off road nothing else is good enough, could get yourself out of some pretty sticky situations. 3 Share this post Link to post Share on other sites
WHX?? 56,203 #10 Posted April 24, 2020 (edited) Early day version of this . Off road rock crawlers often have them mounted on the hood of their Jeeps/Rovers to get them out of a bind. They can be very dangerous to use as they are not very stable even lifting just a little. Edited April 24, 2020 by WHX24 Share this post Link to post Share on other sites
Stormin 9,987 #11 Posted April 24, 2020 They can be used for more than lifting. Fit a shackle to each end and you can use them like a winch. Share this post Link to post Share on other sites
