"D"- Man 827 #26 Posted April 22, 2020 Hitch assembled to the draft bars Share this post Link to post Share on other sites
"D"- Man 827 #27 Posted April 22, 2020 (edited) Leveler assembly attached to the draft bars Edited April 22, 2020 by "D"- Man Share this post Link to post Share on other sites
"D"- Man 827 #28 Posted April 22, 2020 Rear mounts attached Share this post Link to post Share on other sites
"D"- Man 827 #29 Posted April 22, 2020 Front mounts and shaft Share this post Link to post Share on other sites
"D"- Man 827 #30 Posted April 22, 2020 Does anyone have a picture of how the lift rod is attached to the leveler assembly that is the style with the 2 slotted holes in series, instead of the style with a slotted hole and a round hole? Share this post Link to post Share on other sites
"D"- Man 827 #31 Posted April 27, 2020 (edited) Not much of an update, I have the tensioner pulley spring done. I am waiting on parts to come in the Post. Edited April 27, 2020 by "D"- Man Share this post Link to post Share on other sites
"D"- Man 827 #32 Posted April 28, 2020 Had parts show up in the post today. The pulleys I already had, but decided to paint them. Gauge wheel bolts/nuts, height adjustment lever spring, the bushings for the idler pulley tensioner bar and the rubber bumpers. The rubber bumpers I already have look better than the PartsTree so called N.O.S. so I may try to sell them. The complete spindle assembly with blade. This came with an undersized pulley so it may be for sale as well. It is 3-1/4"s in diameter. Share this post Link to post Share on other sites
"D"- Man 827 #33 Posted April 28, 2020 Bolted on the gauge wheels, manual I have does not indicate that it requires washers but I added a couple anyways. It was just a bit too sloppy without them. 1 1 Share this post Link to post Share on other sites
"D"- Man 827 #34 Posted April 28, 2020 (edited) Gave the deck 2 coats of primer and a couple coats of color, but had some serious runs. After sanding them out I primered the bare metal areas and when I went to check if it was dry, I noticed it had cracked in the direct sun. So sanded out the cracks and reprinted. Finally I was able to shoot a couple coats of Red. Turned out near flawless except one or two areas that had minor runs. So I waited till the paint had a bit of a chance to flash dry prior to taking it in the garage for the reminder of drying. A bug happened to try and get a "closer" look. I just left it in thinking I would have a go at removing it once the paint dried. Came back to find it was not only gone but, I had to do a bit of looking before I found where it was. VID_20200428_164850492.mp4 Edited April 29, 2020 by "D"- Man 2 Share this post Link to post Share on other sites
ebinmaine 81,048 #35 Posted April 29, 2020 Lookin' good! 1 Share this post Link to post Share on other sites
"D"- Man 827 #36 Posted April 29, 2020 Over deck support bolted.on. Share this post Link to post Share on other sites
"D"- Man 827 #37 Posted April 29, 2020 Idler pulley and tensioner bar assembly with the slider bushings. 1 Share this post Link to post Share on other sites
"D"- Man 827 #38 Posted April 29, 2020 5 hours ago, ebinmaine said: Lookin' good! Thanks E B more to come. 1 Share this post Link to post Share on other sites
"D"- Man 827 #39 Posted April 29, 2020 Tensioner spring 1 Share this post Link to post Share on other sites
"D"- Man 827 #40 Posted April 29, 2020 Height adjustment quadrant 1 Share this post Link to post Share on other sites
"D"- Man 827 #41 Posted May 3, 2020 (edited) Gauge wheel support bar and pivot brackets with backing plates. Edited May 3, 2020 by "D"- Man 2 Share this post Link to post Share on other sites
"D"- Man 827 #42 Posted May 3, 2020 Height adjustment lever with spring. Still needing decal part # 105205 2 Share this post Link to post Share on other sites
"D"- Man 827 #43 Posted May 3, 2020 Rear carriage mounts. 2 Share this post Link to post Share on other sites
ebinmaine 81,048 #44 Posted May 3, 2020 4 hours ago, "D"- Man said: decal @Vinylguy could help you there. It's all looking very nice. 1 Share this post Link to post Share on other sites
"D"- Man 827 #45 Posted May 3, 2020 3 hours ago, ebinmaine said: @Vinylguy could help you there. It's all looking very nice. Thanks, I have talked with Terry and he doesn't have a copy of this decal. He is willing to make them, but only if he has a picture or a decal to go off of. 1 Share this post Link to post Share on other sites
ebinmaine 81,048 #46 Posted May 3, 2020 3 minutes ago, "D"- Man said: Thanks, I have talked with Terry and he doesn't have a copy of this decal. He is willing to make them, but only if he has a picture or a decal to go off of. Likely another member could get a decent snap shot of that. 1 Share this post Link to post Share on other sites
"D"- Man 827 #47 Posted May 3, 2020 28 minutes ago, ebinmaine said: Likely another member could get a decent snap shot of that. I am hoping so. Share this post Link to post Share on other sites
"D"- Man 827 #48 Posted May 3, 2020 Spindle, blade and outer pulley assembly. 1 Share this post Link to post Share on other sites
"D"- Man 827 #49 Posted May 3, 2020 Spindle installed. 1 Share this post Link to post Share on other sites
"D"- Man 827 #50 Posted May 3, 2020 Outer pulley installed. 1 Share this post Link to post Share on other sites
