pfrederi 20,994 #26 Posted April 29, 2020 (edited) 12 minutes ago, Achto said: This must have involved a special solenoid. I'm not familiar with any newer solenoid coil functioning that way. 12 minutes ago, Achto said: This must have involved a special solenoid. I'm not familiar with any newer solenoid coil functioning that way. Knowing WH maybe that got a good deal on that style. Still make them used by Western on their plows... Edited April 29, 2020 by pfrederi 1 1 Share this post Link to post Share on other sites
squonk 47,748 #27 Posted April 29, 2020 There are about 50 different solenoids made. Depending on how they are grounded, type of contacts, duty cycle ect. I have an Echlin book that would keep Jim entertained for hours. I used to sell those “snowplow “ solenoids all the time 1 1 Share this post Link to post Share on other sites
Lane Ranger 12,071 #28 Posted April 29, 2020 (edited) 14 hours ago, pfrederi said: Read back through this Why did you replace the solenoid you talked about switches but I didn't see solenoid. Do you have the old one? Test it?? Richard may be on to something. Paul The original solenoid was long gone. My understanding is the original 701 (and as Richard says the 550 and 551 also) had a solenoid that was what I would call a negative ground one that when the push button switch would be pressed it became grounded. Dan's rewiring suggestion is proably the way to best wire a positive grounded solenoid -like the one I bought. As the package on the solenoid says it is chassis grounded -so grounded upon placing it on the wheel horse frame metal. Edited April 29, 2020 by Lane Ranger Share this post Link to post Share on other sites
pfrederi 20,994 #29 Posted April 29, 2020 Or for 9 bucks by the original type.. either way could work... 1 Share this post Link to post Share on other sites
Lane Ranger 12,071 #30 Posted April 29, 2020 13 hours ago, Achto said: @Lane Ranger Looking at the wire diagram I think that it is wrong, or at least it won't work with the solenoid that you have. I have never seen a solenoid wired the way it is on the diagram. Here is the fix - Run a hot "+" wire to one side of the start button, run a wire from the other side of the start button to the small post on the solenoid. The body of the solenoid will serve as your ground for the coil in the solenoid. Connect a large "10ga at least" wire from the battery to one of the large terminals on the solenoid. Connect a large wire from the other large term on the solenoid to the starter gen "+" terminal. Your start system should work with the above set up. Dan: When you say attach the the second large terminal on the solenoid to the + positive terminal on the starter/generator exactly which one? I thought they are all positive on the S/G as it is grounded by the housing and bolts to the frame. Are you talking about the A or F post on the S/G or the ACC positive on the regulator? Share this post Link to post Share on other sites
squonk 47,748 #31 Posted April 29, 2020 I like the starter button grounding the solenoid. All the juice stays at the solenoid where it belongs 1 Share this post Link to post Share on other sites
Achto 32,254 #32 Posted April 29, 2020 17 minutes ago, Lane Ranger said: Are you talking about the A or F post on the S/G or the ACC positive on the regulator Sorry Lane I should have said A terminal. I always consider A "armature" as + and F "field" as -. When dealing with a Neg ground system. 1 Share this post Link to post Share on other sites
Lane Ranger 12,071 #33 Posted April 29, 2020 (edited) I thought it was A but wanted to make sure. So the only real changes in wiring on a Grounded Solenoid is one wire to Positive + Battery post wire to the Push Button Starter switch, Plus a heavier 10 gauge or so wire from Positive Battery Terminal to one of the Big Posts on the Solenoid. Or do like Paul indicated and buy a new snowplow type solenoid which duplicated the basic function of the original 701. 550 and 551 solenoid used in those wiring systems. Edited April 29, 2020 by Lane Ranger 1 1 Share this post Link to post Share on other sites
WHX?? 57,644 #34 Posted April 29, 2020 2 hours ago, Lane Ranger said: Or do like Paul indicated and buy a new snowplow type solenoid which duplicated the basic function of the original 701. 550 and 551 solenoid used in those wiring systems. The stay original guys in MN would prefer that! Mike's got a good point about keeping the juice at the solenoid. Share this post Link to post Share on other sites
Lane Ranger 12,071 #35 Posted April 30, 2020 The 701 was back at it today! Finally, running with vigor again! Carrying a cut up walnut tree to my neighbor for winter 🔥 wood! 2 Share this post Link to post Share on other sites
WHX?? 57,644 #36 Posted April 30, 2020 (edited) Crap. .. ther goes my 701 right out the window! ... oh well guess I'll just have to get seat time on Dan's! What did you settle on for the wiring/solenoid Lane? Edited April 30, 2020 by WHX24 1 Share this post Link to post Share on other sites
Lane Ranger 12,071 #37 Posted April 30, 2020 The one I had but I may order the correct one Jim! 2 Share this post Link to post Share on other sites
