partsman86 3 #1 Posted April 13, 2020 im in need of a complete wiring harness for this tractor. mine went up in smoke and have very little to go by any used or new ones around? any help appreciated. 1 Share this post Link to post Share on other sites
rjg854 12,626 #2 Posted April 13, 2020 Check with AZ tractor, his phone number is in the vendors section 1 Share this post Link to post Share on other sites
oliver2-44 11,062 #3 Posted April 13, 2020 The wiring on the C Series is fairly simple to make a new one. Someone will be along with a wiring diagram to help if you wanted to go that way. 4 Share this post Link to post Share on other sites
ebinmaine 75,769 #4 Posted April 13, 2020 6 hours ago, oliver2-44 said: The wiring on the C Series is fairly simple to make a new one. Someone will be along with a wiring diagram to help if you wanted to go that way. That's about what I was thinking. Try to figure out exactly why it burned. Carefully check the ammeter. I use a voltmeter instead. Making a harness for that would be the best way to go. All fresh new wiring. 1 Share this post Link to post Share on other sites
JoeM 9,319 #5 Posted April 13, 2020 Here is a service manual has the C wiring on page 6-4, i may have a harness will check today. Tractor_1978_B-C-D-SeriesServiceManual_810063Rl.pdf 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #6 Posted April 13, 2020 Very simple Garry Share this post Link to post Share on other sites
BOB ELLISON 2,981 #7 Posted April 13, 2020 Welcome to REDSQUARE first off. You'll have a hard time trying to find a wiring harness for any tractor that old. @953 nut made this post just for guys that have wiring problem the colored diagrams help a lot. Use the old connector if possible . If you have any skills you can replace all the old wires very easily one at a time. Share this post Link to post Share on other sites
JoeM 9,319 #9 Posted April 13, 2020 No can find the harness, I know it is up there somewhere. Sorry 1 Share this post Link to post Share on other sites
partsman86 3 #10 Posted April 13, 2020 12 hours ago, ebinmaine said: That's about what I was thinking. Try to figure out exactly why it burned. Carefully check the ammeter. I use a voltmeter instead. Making a harness for that would be the best way to go. All fresh new wiring. Share this post Link to post Share on other sites
partsman86 3 #11 Posted April 13, 2020 I suspect that is what happened. ammeter was toasted thanks for the info 1 Share this post Link to post Share on other sites
ebinmaine 75,769 #12 Posted April 14, 2020 3 hours ago, partsman86 said: I suspect that is what happened. ammeter was toasted thanks for the info Ammeters have a place in the world... But not on my herd. Share this post Link to post Share on other sites
partsman86 3 #13 Posted April 20, 2020 I was Able to obtain an original wheelhouse harness. I installed that my lights and everything work but it won’t turn over with the key. I can jump solenoid to get to turn over but I have no power at the coil. Any help thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #14 Posted April 20, 2020 These diagrams should help Garry Share this post Link to post Share on other sites
