seven 202 #1 Posted April 12, 2020 Has anyone ever worked on these it has old style magneto behind flywheel from what I'm finding out parts are real hard to come by ? Share this post Link to post Share on other sites
ebinmaine 81,003 #2 Posted April 12, 2020 @Stepney might have a bit of knowledge. I've not messed with one. I understand some of the ignition pieces can be changed to a more easy to get module. Share this post Link to post Share on other sites
Stepney 2,356 #3 Posted April 12, 2020 Ignition pieces are quite universal. Most every Teccy from the late 50s into the 80s used the same mag or very close. What are you looking for exactly? I have the Master Book. I can take it out later to cross numbers. 1 Share this post Link to post Share on other sites
seven 202 #4 Posted April 12, 2020 Well from what I've found it should be Tecumseh part number 610759 I may let this project go anyway now but if you want to check it out that would be great thxs Share this post Link to post Share on other sites
Stepney 2,356 #5 Posted April 12, 2020 (edited) OH. You mean a solid state ignition HH80? I thought you were talking about a points ignition engine. There are a series of tests to prove those parts faulty.. usually it's the external coil on the flywheel that gives trouble. This piece here? Edited April 12, 2020 by Stepney Share this post Link to post Share on other sites
seven 202 #6 Posted April 13, 2020 Yes that's what I'm looking for . Share this post Link to post Share on other sites
