midpack 1,148 #1 Posted April 7, 2020 Not even sure what a new set of Tie Rods goes for, but I like the idea of using Heim Joints for them. these cost me about $45 plus some time at work to make the shafts. I thought of making them "turnbuckle" style but I don't have a left hand tap a sharp eye might notice it took me a couple tries to get the shaft length I wanted. lol 5 11 Share this post Link to post Share on other sites
Pollack Pete 2,273 #3 Posted April 7, 2020 Look good to me..Adjustable…..and they're going to last a long time. 1 Share this post Link to post Share on other sites
peter lena 10,047 #4 Posted April 7, 2020 midpack, nice job on those ! being a heim joint nut myself , i can relate on their use and function , your transition picture says it all . what ever linkage issue you have , you could add a heim joint if you want to, find the difference in linkage function , almost effortless , pete Share this post Link to post Share on other sites
Achto 32,630 #5 Posted April 7, 2020 5 hours ago, midpack said: Awesome job on those!! I recently redid a set. I used the original tie rods, cut the ball end off, turned the ends down to 3/8" and threaded them at 24 pitch. If the ends ever need to be replaced again I think that I will use Heim joints like you did. 5 2 Share this post Link to post Share on other sites
bds1984 1,519 #6 Posted April 7, 2020 Hey that shorter tie rod can help you turn left! 2 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #7 Posted April 8, 2020 midpack. Good job. Let us know how the work out. Share this post Link to post Share on other sites
