1990Onan520-H 15 #1 Posted April 6, 2020 Hey all, I have searched now for almost an hour and cannot find this so am hoping someone can help. I know a member installed a ball bearing in their upper steering tower and there was a specific bearing with a cutout in it I thought that they used. Does anyone have the link to that thread? TIA Share this post Link to post Share on other sites
WHX?? 57,930 #2 Posted April 6, 2020 Pretty sure @cleat has done it. If I remember right it was just a standard pillow block style bearing. Share this post Link to post Share on other sites
peter lena 10,031 #3 Posted April 6, 2020 can,t find my thread, but i have done this on my 3 horses , that ball bearing threw me off, i used this , a 3/4" bore 2 bolt flange , https://www.google.com/search?q=2+bolt+flange+bearing+3/4+bore&sxsrf=ALeKk02SkGzgvTMDbce6Ut9o5lO5OUPq6A:1586191894032&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwjbu46jodToAhXxlHIEHRPFARQQsxh6BAgNECw&biw=1024&bih=625 this is a very strong cast flange , the only thing you will have to make up is a transition piece from your existing mount to the new bearing mount. you will be removing your dash console to do this, but its so worth it . bearing is cheap ,under 10 $ . while i was in there i also shimmed up my , PTO LEVER START MOUNT POINT , lower edge of battery tray , lever is sloppy , fill the gap with washers and grease it, snug and smooth movement. i will send you my link to that , good luck with it , pete 1 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #4 Posted April 6, 2020 (edited) https://www.wheelhorseforum.com/topic/62446-upgraded-steering-shaft-bearings-on-520s/?tab=comments#comment-584578 Edited April 6, 2020 by 1995 520H+96+97 1 3 Share this post Link to post Share on other sites
peter lena 10,031 #5 Posted April 6, 2020 1990onan520-h, here is the link to the pto lever improvement, looking at first picture ,you can see the lever point washer build up to secure lever at bottom of battery tray , you can also see a 3/8" elastic lock nut to the left , holding one side of my flange bearing to the steering column . https://www.google.com/search?q=2+bolt+flange+bearing+3/4+bore&sxsrf=ALeKk02SkGzgvTMDbce6Ut9o5lO5OUPq6A:1586191894032&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwjbu46jodToAhXxlHIEHRPFARQQsxh6BAgNECw&biw=1024&bih=625 done this on my 3 horses , worth the change for the better , pete 1 Share this post Link to post Share on other sites
1990Onan520-H 15 #6 Posted April 6, 2020 10 minutes ago, peter lena said: can,t find my thread, but i have done this on my 3 horses , that ball bearing threw me off, i used this , a 3/4" bore 2 bolt flange , https://www.google.com/search?q=2+bolt+flange+bearing+3/4+bore&sxsrf=ALeKk02SkGzgvTMDbce6Ut9o5lO5OUPq6A:1586191894032&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwjbu46jodToAhXxlHIEHRPFARQQsxh6BAgNECw&biw=1024&bih=625 this is a very strong cast flange , the only thing you will have to make up is a transition piece from your existing mount to the new bearing mount. you will be removing your dash console to do this, but its so worth it . bearing is cheap ,under 10 $ . while i was in there i also shimmed up my , PTO LEVER START MOUNT POINT , lower edge of battery tray , lever is sloppy , fill the gap with washers and grease it, snug and smooth movement. i will send you my link to that , good luck with it , pete Thanks Pete. I was thinking of getting the foot pedal conversion too and doing the pedal conversion, bearing and upgrading to gear reduction steering all in one shot. Probably throwing on the rock shaft and cable setup too. Engine is already currently off the machine due to a chucked rod so should make this easier. This is all for my 1990 520-H. Once all this is completed it will be time to find a new engine. ha! 1 Share this post Link to post Share on other sites
1990Onan520-H 15 #7 Posted April 6, 2020 4 minutes ago, peter lena said: 1990onan520-h, here is the link to the pto lever improvement, looking at first picture ,you can see the lever point washer build up to secure lever at bottom of battery tray , you can also see a 3/8" elastic lock nut to the left , holding one side of my flange bearing to the steering column . https://www.google.com/search?q=2+bolt+flange+bearing+3/4+bore&sxsrf=ALeKk02SkGzgvTMDbce6Ut9o5lO5OUPq6A:1586191894032&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwjbu46jodToAhXxlHIEHRPFARQQsxh6BAgNECw&biw=1024&bih=625 done this on my 3 horses , worth the change for the better , pete Looks like this is the flange link again. Share this post Link to post Share on other sites
peter lena 10,031 #8 Posted April 6, 2020 sorry about that , look up IMPROVE PTO LEVER ACTION , pete 1 Share this post Link to post Share on other sites
1990Onan520-H 15 #9 Posted April 6, 2020 (edited) 1 hour ago, peter lena said: can,t find my thread, but i have done this on my 3 horses , that ball bearing threw me off, i used this , a 3/4" bore 2 bolt flange , https://www.google.com/search?q=2+bolt+flange+bearing+3/4+bore&sxsrf=ALeKk02SkGzgvTMDbce6Ut9o5lO5OUPq6A:1586191894032&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwjbu46jodToAhXxlHIEHRPFARQQsxh6BAgNECw&biw=1024&bih=625 this is a very strong cast flange , the only thing you will have to make up is a transition piece from your existing mount to the new bearing mount. you will be removing your dash console to do this, but its so worth it . bearing is cheap ,under 10 $ . while i was in there i also shimmed up my , PTO LEVER START MOUNT POINT , lower edge of battery tray , lever is sloppy , fill the gap with washers and grease it, snug and smooth movement. i will send you my link to that , good luck with it , pete What year machines did you do this on? I am looking at my 90 and there is only a 2 inch gap between the column shifters so those flanges won't fit. It looks like it will work just fine on my 88 though. Edited April 6, 2020 by 1990Onan520-H Share this post Link to post Share on other sites
peter lena 10,031 #10 Posted April 6, 2020 sorry about that , look up IMPROVE PTO LEVER ACTION , pete Share this post Link to post Share on other sites
peter lena 10,031 #11 Posted April 6, 2020 installed in years 91-93-82 , added a piece of angle steel , spanned between sides of consol . i did not have column shifters , pete Share this post Link to post Share on other sites
1990Onan520-H 15 #12 Posted April 6, 2020 4 hours ago, peter lena said: installed in years 91-93-82 , added a piece of angle steel , spanned between sides of consol . i did not have column shifters , pete Ah. Ok yeah not going to work for my 520. I'll have to figure something else out. Thanks for the info. Share this post Link to post Share on other sites
peter lena 10,031 #13 Posted April 6, 2020 good luck with it , keep us informed when you can , pete 1 Share this post Link to post Share on other sites
