Parke1 0 #1 Posted April 30, 2009 I'm going to be bringing this home tomorrow evening. I haven't been able to go look at it myself yet, but I was wondering what model it might be. I don't recognize the hood from any of the archive pictures I browsed through. Thanks for any help! -Parke1 Share this post Link to post Share on other sites
CasualObserver 3,416 #2 Posted April 30, 2009 I'd guess a 701 from the hood lines and the clutch pedal. Share this post Link to post Share on other sites
linen beige 16 #3 Posted April 30, 2009 I'd guess a 701 from the hood lines and the clutch pedal. Typo Jason? It has the same foot rests and clutch pedal as my 702. The 701 also had the starter buttons on a white, not red, dash instead of the hood stand. This one also has the bent shifter that was brought out in mid '62 to clear the HY-2 pump. I'd say it's a 552 or 702 that at one time was repowered. It could have been a 502, but it looks like it has a starter button on the hood stand. Not only has the hood been modified, but there has been something added to the front of the frame, and the seat pan and steering wheel, among other things, are not original. Share this post Link to post Share on other sites
CasualObserver 3,416 #4 Posted April 30, 2009 Whoops.. yep. :omg: Share this post Link to post Share on other sites
BPjunk 184 #5 Posted April 30, 2009 The tractor pictured is a 1962 and to say which model I would need to see what is left of the wiring. Now when you do pick up this tractor could please post pictures of the hood from all angles exspecialy the left side. Thanks Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
wheel horse 1045 2 #6 Posted April 30, 2009 looks kinda like a 702 with an oddball hood and steeringwheel Share this post Link to post Share on other sites
buckrancher 2,697 #7 Posted May 1, 2009 It's a 702 with the red painted steel bolt on dash. The 701 is off white plastic and the key and start button are mounted on it also ( hard to see bad angle ) 702 key and start button are on the hoodstand in front of the shift lever. front axle also looks 702 :omg: Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #8 Posted May 1, 2009 A 701 doesn't have a parking brake or the cover on the left side of the hoodstand. The rear fender tips come to a sharper point than the 1962 to 1964 models and there are diagonal fender braces (strap steel) attached from one of the bottom seat spring bolts to each fender. A 701 should have the oblong cast iron footrests - not stirrups like the later models and the starter circuit uses a relay (solenoid) instead of the "dimmer switch" looking push button or the newer high-amp, 3 post switch (P/N 4988). Share this post Link to post Share on other sites
linen beige 16 #9 Posted May 1, 2009 It's a 702 with the red painted steel bolt on dash. The 701 is off white plastic and the key and start button are mounted on it also ( hard to see bad angle ) 702 key and start button are on the hoodstand in front of the shift lever. front axle also looks 702 The 502, 552, and 702 all used the same dash and front axle. The 502 being a recoil start would not have had a starter button. The mounting hole would be there for one and it would likely be covered with the shift pattern/serial # decal. As Wild Bill said, the best way to determine what model this is would be to check the wiring harness. The 552 would have been wired for a Techy, the 702 for a Kohler. Share this post Link to post Share on other sites
Kelly 1,038 #10 Posted May 1, 2009 I vote 702 as it looks like the regulator for the start/gen. setting in the batt. tray. Share this post Link to post Share on other sites
