Shaker 6.6 5 #1 Posted April 2, 2020 Anyone know how to remove the fuel shut off out of my fuel tank I want to replace it because the old one is clogged up not sure if I just take a pair of pliers and pull it out from the bottom or does it come out through the tank or what is my best option of getting it removed without damaging the fuel tank Share this post Link to post Share on other sites
ebinmaine 77,332 #2 Posted April 2, 2020 Can't help you with the answer but Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted April 2, 2020 Comes out from the bottom. Spray it with liquid wrench, crc, wd40 or whatever you have on hand... 2 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #4 Posted April 2, 2020 (edited) You can replace it and the grommet for about $10 or so. Getting ready to do that to my 310-8 myself. I think I bought mine on Amazon, but it was last fall and I don't remember right now. And yes just pull it out then put the new grommet in first, then lube the valve and push it in while turning. Randy Edited April 2, 2020 by RandyLittrell 1 Share this post Link to post Share on other sites
Shaker 6.6 5 #5 Posted April 2, 2020 2 hours ago, ebinmaine said: Can't help you with the answer but Thank you 2 Share this post Link to post Share on other sites
Shaker 6.6 5 #6 Posted April 2, 2020 27 minutes ago, RandyLittrell said: You can replace it and the grommet for about $10 or so. Getting ready to do that to my 310-8 myself. I think I bought mine on Amazon, but it was last fall and I don't remember right now. And yes just pull it out then put the new grommet in first, then lube the valve and push it in while turning. Randy Awesome thank you for your help I will give it a shot! 2 Share this post Link to post Share on other sites
Shaker 6.6 5 #7 Posted April 2, 2020 1 hour ago, roadapples said: Comes out from the bottom. Spray it with liquid wrench, crc, wd40 or whatever you have on hand... Thank you! 1 Share this post Link to post Share on other sites
JCM 10,764 #9 Posted April 3, 2020 To 310-8 Nice tractor. Good Luck with it. Share this post Link to post Share on other sites
953 nut 64,115 #11 Posted April 3, 2020 A pair of visegrips and a stout pull will get the old one out. I think @rmaynard has new valves and bushings for sale, that is where I bought mine last year. They do need to be well lubricated going in. 1 Share this post Link to post Share on other sites
Pullstart 68,882 #13 Posted April 3, 2020 Looks like you’re all fixed up on the fix, so I’ll say Share this post Link to post Share on other sites
Lane Ranger 11,790 #14 Posted April 3, 2020 Caution: Look carefully at the grommet and the bottom of the tank before removing the valve and grommet. These older plastic tanks can crack or break and the grommet can be dry rotted . As noted by others spraying wd40 or some lubricating spray can help loosen up the rubber in the grommet. 2 Share this post Link to post Share on other sites
rmaynard 16,866 #15 Posted April 3, 2020 1 hour ago, 953 nut said: A pair of visegrips and a stout pull will get the old one out. I think @rmaynard has new valves and bushings for sale, that is where I bought mine last year. They do need to be well lubricated going in. I have the rubber bushings, but no valves. Share this post Link to post Share on other sites
Rob R 981 #16 Posted April 3, 2020 What Lawn Ranger said have the new on hand, since you will probably need it, if you can gently heat the area a little with a hair dryer helps along with the wd40 to pop it out. 1 Share this post Link to post Share on other sites
