c-series don 12,168 #1 Posted March 21, 2020 I have a C-161 8 speed that appears to be leaking at the break drum shaft. Can I change the seal from the outside or is this something that needs to be done internally? I don’t recall it leaking and when I put it up on my roll around table to mount my ez Rake I noticed it. It’s not terrible but while I have it up there I’d like to address the problem. The oil you see has taken about a week or so to drip that much. Thanks in advance to anyone who can help me 👍 2 1 Share this post Link to post Share on other sites
pfrederi 20,924 #3 Posted March 21, 2020 Remove the 3/8" bolt holding the drum on. It should slide off pretty easy if it has leaked for awhile. Can be done from outside. Dig out the seal with a pick. screw driver or put a small screw into it an pull that. 4 1 Share this post Link to post Share on other sites
rjg854 13,215 #4 Posted March 21, 2020 Yes, you can change that seal from the outside, good luck getting that brake drum off. The one on my 854 was a bear to remove. Share this post Link to post Share on other sites
stevasaurus 23,763 #5 Posted March 21, 2020 The brake shaft seal is SKF-#7410...it is only 1/8" deep, so don't dig too deep. 5 1 Share this post Link to post Share on other sites
Lee1977 7,720 #6 Posted March 21, 2020 (edited) With it leaking that bad I think you need to replace thr bearings on that shaft before putting in a new seal. I have a C=120 that has been leaking for at least 4 or 5 years and never enough to drop on the floor. Edited March 21, 2020 by Lee1977 Share this post Link to post Share on other sites
c-series don 12,168 #7 Posted March 21, 2020 Thank you everyone for your help. I’ll try just the seal before I get into the bearing. The seal alone can’t be that much money and hopefully an easy fix. I’ll post some pictures when I get into it. You guys are the best 👍👍 3 Share this post Link to post Share on other sites
lynnmor 8,927 #8 Posted March 21, 2020 1 hour ago, c-series don said: It’s not terrible but while I have it up there I’d like to address the problem. No, that is terrible, it is peeing like a race horse. 1 Share this post Link to post Share on other sites
troutbum70 858 #9 Posted March 22, 2020 Like others said good luck getting drum off, made out of cast and easily broken. Don't ask how I know 1 Share this post Link to post Share on other sites
c-series don 12,168 #10 Posted March 22, 2020 I ordered the seal, it will be here on Tuesday. In the meantime I’ll keep soaking it with Kroil and tapping it lightly. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #11 Posted March 22, 2020 19 hours ago, stevasaurus said: The brake shaft seal is SKF-#7410...it is only 1/8" deep, so don't dig too deep. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #12 Posted March 22, 2020 When you get that drum off check the shaft to see if there's any play up and down or forward or backward. in and out is OK. But if there's movement up-and-down on the shaft could be a bearing problem as well. Share this post Link to post Share on other sites
c-series don 12,168 #13 Posted March 25, 2020 The seal came in yesterday (National Seal #312518) The brake drum slid right off luckily! The old seal came out relatively easy, I checked for play in the shaft and there’s none. Installed the new seal and topped off the transmission oil. Reassembled everything and no more leak!👍Thanks again for those who chimed in to help. 2 1 Share this post Link to post Share on other sites
WHX?? 57,502 #14 Posted March 25, 2020 That is one fine lookin tractor & setup there Mr. Oliver 1 Share this post Link to post Share on other sites
c-series don 12,168 #15 Posted March 25, 2020 Thank you very much! The tractor I restored a number of years ago and the EZ RAKE I just restored over the winter. Now that the leak is fixed and the tractor is serviced I can’t wait to go use it! 2 Share this post Link to post Share on other sites
peter lena 9,972 #16 Posted March 25, 2020 terrific response to c-series don question / problem , from seal # and type to don getting after it ! i also agree with the condition of your horse , nice job ! glad you found your help here , pete 1 Share this post Link to post Share on other sites
troutbum70 858 #17 Posted March 25, 2020 You or some one else must have had that drum off a couple times and put some anti rust on or you are just blessed with good luck. And as others have already said its a very good looking horse. 1 Share this post Link to post Share on other sites
c-series don 12,168 #18 Posted March 26, 2020 Honestly I think that the oil leaking onto the shaft helped it from being seized on the shaft. Share this post Link to post Share on other sites
WHX?? 57,502 #19 Posted March 26, 2020 I guess I can't relate to why you guys are sayin that drum comes off hard? Mine ALWAYS slide right off. 'Course mine are all pre 70s tractors with the snap ring so thats all I know. Thinking the the oil leaks keep them lubed? Always crudded up with crap behind them. Given the low RPM those turn wouldn't guess you have a bearing problem unless a PO was hard on the brakes or liked his women like his tranny fluid... a little on the trashy side! Thanks Don now I got that song stuck in my head! 1 Share this post Link to post Share on other sites
