RetroMower 350 #1 Posted March 21, 2020 My efforts removing the steering wheel from my C100 have proven fruitless. After soaking the area in PB blaster for many days while under pressure from a puller and bearing separator I am unable to budge the bugger off the shaft. I know a hydraulic press would most likely solve this but right now I'm not keen on spending much more on this restoration. That said I still want to get it apart to sandblast and paint the dash correctly. I made this item the other day and yes its if I decide to cut the shaft but I figure I'd get some opinions before doing this. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,465 #2 Posted March 21, 2020 We've done 2 full restorations and didn't remove the steering wheel from either one. Trina just sands/paints around the wheel and "bags" it when priming and painting. 5 Share this post Link to post Share on other sites
Ed Kennell 47,120 #3 Posted March 21, 2020 I've resorted to cutting the shaft on a couple and reassembled with a similar shaft connector. I feel this is a better option than risking damage to a steering wheel. 6 Share this post Link to post Share on other sites
RetroMower 350 #4 Posted March 21, 2020 Well that's one vote to leave it and one for cutting it. I'd be much more reluctant to cut it but it's not an irreversible solution. I think even with a press that I could mushroom the shaft over or crack the otherwise ok steering wheel. Share this post Link to post Share on other sites
rjg854 13,330 #5 Posted March 21, 2020 I've been lucky enough on most of my tractors to be able to get the steering wheels off, except for the 877. When I repainted I ended up just leaving it in place then dropping the collar down and painting the cowl. Came out fine, I didn't want to have to cut the shaft. 2 Share this post Link to post Share on other sites
squonk 47,998 #6 Posted March 21, 2020 I have cut a shaft to raise the steering wheel so it doesn't hit the hood when opening. welded a 3" extension in it. Do what you gotta do. Share this post Link to post Share on other sites
pfrederi 21,097 #7 Posted March 21, 2020 Pull the steering wheel shaft and instrument panel as a unit Then you can clamp it in a vice support the shaft next to the wheel and drive out even recalcitrant roll pins. Then use emery cloth to clean the shaft 2-3" below the wheel. Now stand the whole unit up in your vice with the Gear end down against the vice body. Climb up on a step stool with a deep wheel socket that will fit over the shaft yet rest on the steering wheel hub. Then wail away with a BFH and drive the wheel down on to the cleaned up portion of the shaft. Then clean up the end of the shaft and you can slide the wheel off. done this on several stuck wheels. 2 4 Share this post Link to post Share on other sites
RetroMower 350 #8 Posted March 21, 2020 5 hours ago, pfrederi said: Pull the steering wheel shaft and instrument panel as a unit Then you can clamp it in a vice support the shaft next to the wheel and drive out even recalcitrant roll pins. Then use emery cloth to clean the shaft 2-3" below the wheel. Now stand the whole unit up in your vice with the Gear end down against the vice body. Climb up on a step stool with a deep wheel socket that will fit over the shaft yet rest on the steering wheel hub. Then wail away with a BFH and drive the wheel down on to the cleaned up portion of the shaft. Then clean up the end of the shaft and you can slide the wheel off. done this on several stuck wheels. I think I will give this a try before cutting the shaft. Thank you for a great suggestion. I don't know why I haven't thought of this 🤣 Share this post Link to post Share on other sites
pfrederi 21,097 #9 Posted March 21, 2020 1 hour ago, RetroMower said: I think I will give this a try before cutting the shaft. Thank you for a great suggestion. I don't know why I haven't thought of this 🤣 3 1 Share this post Link to post Share on other sites
edgro 680 #10 Posted March 21, 2020 When I cut mine. , I cut it at an angle, so it would self align, I put a sleeve over it and welded it back together 2 Share this post Link to post Share on other sites
RetroMower 350 #11 Posted March 23, 2020 On 3/21/2020 at 4:02 PM, pfrederi said: As far as I'm concerned there is no other way to remove a stuck WH steering wheel. Thank you thank you thank you 1000 times. This made an otherwise daunting task easy as pie. My restoration can now continue. Anyone wanna buy my shaft coupler I made? Lol 1 3 Share this post Link to post Share on other sites
