pfrederi 19,969 #1 Posted March 15, 2020 (edited) The Wheel Horse designer who figured out the placement of the hydro pump on a D-series must have spent time on the GT-14 also.. specifically the location of and access to the tow valve especially when you have the 3 point hitch. I am getting ready to get my hole saw and drill a big hole in the inner fender plate (black x pic 2). Has anyone come up with a good solution??? Edited March 15, 2020 by pfrederi 1 1 1 Share this post Link to post Share on other sites
953 nut 64,332 #2 Posted March 15, 2020 One of many things on the GT-14 that wasn't thoroughly thought through. 1 1 Share this post Link to post Share on other sites
Pullstart 68,981 #3 Posted March 16, 2020 Is there anything structural to that section? If not, I say go for it! Share this post Link to post Share on other sites
gt14rider 1,055 #4 Posted March 16, 2020 I ended up removing rear fender ass'y, (8 or 10 bolts and nuts). I got big fat hands and was easier and less time . Plus that valve was rusted and painted tight, took a big box wrench and hammer. Be careful, fine threads don't want to strip them out 1 1 Share this post Link to post Share on other sites
pfrederi 19,969 #5 Posted March 16, 2020 My tow valve works just fine I had the whole hydro apart. issue is i want to be able to use the darn thing sometimes I want to be able to push the tractor a couple feet and do not want to start it for just a couple seconds use and I can't get my fat fingers in there. 2 Share this post Link to post Share on other sites
gt14rider 1,055 #6 Posted March 16, 2020 Now I'm tracking, you can make a tool.1/2" pipe cut a slot in one end , drill a hole in the other, put a cross bar. This way the hole in the fender can be small. Here you go, just made one for mine. 4 2 Share this post Link to post Share on other sites
pfrederi 19,969 #7 Posted March 16, 2020 Great idea. i was going bigger this will be much better.... Share this post Link to post Share on other sites
19richie66 17,820 #8 Posted March 16, 2020 My gt14 had these oval holes in the lower panel by the side of the seat. I was wondering what those were for. ? 2 Share this post Link to post Share on other sites
pfrederi 19,969 #9 Posted March 16, 2020 20 minutes ago, 19richie66 said: My gt14 had these oval holes in the lower panel by the side of the seat. I was wondering what those were for. ? AHA!! Mine is a 1969 I would imagine WH got complaints from dealers about this and they made changes.....Do you know the year of yours??? 1 Share this post Link to post Share on other sites
oldredrider 2,553 #10 Posted March 16, 2020 FWIW, mine is a 1970 and doesn't have the holes. 3 pt hitch on mine. Share this post Link to post Share on other sites
Aldon 4,832 #11 Posted March 16, 2020 That wrench by @gt14rider is great idea. Another project added to my to-do list. Share this post Link to post Share on other sites
19richie66 17,820 #12 Posted March 16, 2020 (edited) 1 hour ago, pfrederi said: AHA!! Mine is a 1969 I would imagine WH got complaints from dealers about this and they made changes.....Do you know the year of yours??? 1972. I like the wrench idea better than holes Edited March 16, 2020 by 19richie66 1 Share this post Link to post Share on other sites
gt14rider 1,055 #13 Posted March 16, 2020 Had to check out mine, oval hole on one side only 1970. Same,same on 1971. I couldn't in that oval, fat fingers. used long needle pliers before rebuild. Share this post Link to post Share on other sites
pfrederi 19,969 #14 Posted March 17, 2020 (edited) Made a tool like GT14riders. Had to make a somewhat bigger hole than I wanted as my tow valve sits under the heavy steel bar support. Have to insert the tool at an angle which required me to enlarge the access hole but it works great. Edited March 17, 2020 by pfrederi 1 Share this post Link to post Share on other sites
Teddy da Bear62 171 #15 Posted June 2, 2025 (edited) I forgot about tow valve....... I think I ruined one of my Gt's tranny towing it from barn. 😭 Edited June 2, 2025 by Teddy da Bear62 Share this post Link to post Share on other sites
