krohs nest
gt-14 No spark
krohs nest
The trigger is bad. Replacement is costly.
Looking at Brian Miller's replacement kit. Any comments.
pfrederi
Just did the swap on my GT14.  easy enough to do.  not familiar with his kit.  you need points, points cover and gasket, plunger 4741104-s, coil and condenser.  will need to get a new ignition switch.
ebinmaine
:text-welcomeconfetti:
All the above parts in Paul's list can be purchased separately or you could call one of our vendors. A - Z Tractor.
cafoose
Read through this thread and click on my links in post #6 for more info:
953 nut
:WRS:
Brian has some great stuff on his web site and the convenience of one stop shopping can't be beat. The GT-14 is a great machine,    :wwp:
krohs nest
6 hours ago, 953 nut said:
:WRS:
Great, thank you for your reply. Would like to keep the machine as close to original as possible,that is breakerless and solid stare.
pfrederi
Did you test the trigger?  If you want to stay original it will cost you....
Pullstart
@krohs nest welcome from the other side of the mitten!
krohs nest
krohs nest
Finally got a chance to recheck the trigger. Still checked  bad. Checked the coil it is OK. You are right it would be costly to keep original.
Will probably use Brian's equipment,
Going to rewire the machine. What size wire, 14 or 16 or a combination.
Thanks for your help.
953 nut
You will find that 14 gauge wire works well for everything. The connectors on your wiring system are Delphi-Packard GM 56 Series. Yuo can find them at a GOOD auto parts store or on :techie-ebay:        Don't use the junk connectors you find at the hardware store, they will come apart on you while you are driving.
Howie
:text-yeahthat:     Those are what I use and I bought a good crimp tool also.
  • Similar Content
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • johnnymag3
      By johnnymag3
      416-8  clean machine, one owner, M16 Kohler...............no smoke, knocks, etc. Only 771 Hours.
      42" Rear Discharge deck   NO RUST    blades used 1 season
      48" plow very nice condition,
      Wheel Horse weights, on tractor already
      AG Tires on rear,used one season, front tires great condition. Rears are filled with beet juice, done at a Dealer professionally,  ....non toxic, non corrosive.  Traction Galore !!!
      Machine is fully serviced, ready to work. NEEDS nothing....Look below for pictures
      JOHN   845 797 5716 cell
