TurboDiesel 2 #1 Posted March 7, 2020 I have a B-112 with a 3 speed transmission. I have never changed the fluid in one of these before. I saw that there were 2 different drain holes on the transmission. Am I supposed to drain out of the bottom one and then fill it back up until it starts coming out of the top one? Also I believe I am supposed to use sae 90 gear oil. Is this correct? Thank you Share this post Link to post Share on other sites
Pullstart 70,849 #2 Posted March 7, 2020 @stevasaurus? Is this the Peerless or Foote? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,387 #3 Posted March 7, 2020 The info is here. Click on the picture to get more including the lube chart Garry 1 Share this post Link to post Share on other sites
