Daron1965 644 #1 Posted March 2, 2020 (edited) Im thinking about reinforcing my bagger mount after removing the plastic top. Then placing a small harbour freight winch on top. I would like the ease of lifting my tiller or bottom plow. I have seen a few on here. What are your thought? Suggestions? Thank you. Edited March 2, 2020 by Daron1965 Share this post Link to post Share on other sites
ebinmaine 79,107 #2 Posted March 2, 2020 I don't really have any specific suggestions as far as the mount itself. The one thing I'd like to put into your head is that the pull of the winch is quite often stronger than the end of the cable. Be sure that you can see the end of travel so you stopp in time or maybe put a heavy duty spring as kind of a cushion, at the end of the cable. 1 Share this post Link to post Share on other sites
Daron1965 644 #3 Posted March 2, 2020 2 minutes ago, ebinmaine said: I don't really have any specific suggestions as far as the mount itself. The one thing I'd like to put into your head is that the pull of the winch is quite often stronger than the end of the cable. Be sure that you can see the end of travel so you stopp in time or maybe put a heavy duty spring as kind of a cushion, at the end of the cable. Great idea. 1 Share this post Link to post Share on other sites
ebinmaine 79,107 #4 Posted March 2, 2020 14 minutes ago, Daron1965 said: Great idea. I wish I could remember where I've seen that over the years. May have been in crane training at some point. Share this post Link to post Share on other sites
Stormin 9,988 #5 Posted March 2, 2020 I've been thinking of some similar arrangement for lifting my plough. Toying with mounting a small ATV winch on the front, running the cable underneath. 1 Share this post Link to post Share on other sites
Daron1965 644 #6 Posted March 2, 2020 (edited) Ingore the tractor. Found a quick pic. Edited March 2, 2020 by Daron1965 2 Share this post Link to post Share on other sites
Stormin 9,988 #7 Posted March 2, 2020 That's a neat little winch. Smaller than what I had in mind. I'll have to see if I can get something similar over here. Share this post Link to post Share on other sites
