SPINJIM 1,996 #1 Posted February 27, 2020 I have a model 1257 with the combined starter & charger, and need a belt for it. I did a search here on RS, and found a WH number 1593, but that didn't fit. It's about 2 inches short and doesn't allow the belt guard to line up. Also puts extra pressure on the charger bearings. Looks like it would fit the 8hp, but not the 12hp. Anyone have a different number for the 12hp ? Thanks, Jim Share this post Link to post Share on other sites
WHX?? 54,535 #2 Posted February 27, 2020 (edited) Either a 34 or 35 Jim 3/8 or 3L width...CRS … I got it somewhere here hang tight.. Found it ...shows a 1593 = 35" tho?? WH LENGTH and WIDTH BELT LIST.txt SG belts.pdf Edited February 27, 2020 by WHX24 Share this post Link to post Share on other sites
SPINJIM 1,996 #3 Posted February 27, 2020 14 minutes ago, WHX24 said: Found it ...shows a 1593 = 35" tho?? I tried the 1593, and it is 35" long, but it's too short. It causes the charger pulley to hit the belt guard because it doesn't line up. Don't know whether to go with a generic 36" or 37" belt. Jim Share this post Link to post Share on other sites
WHX?? 54,535 #4 Posted February 27, 2020 That's bizarre ...pretty sure all mine are a 35". get a 36 and 37 and take back the one that don't fit. Would think a 37 would be way too long. 10 minutes ago, SPINJIM said: it doesn't line up. Sure you don't have something else funky going on there? Pics might be in order here Jim. Share this post Link to post Share on other sites
SPINJIM 1,996 #5 Posted February 28, 2020 I tried a 36" belt from Tractor Supply, and it was way to big. I'm beginning to think that the WH belt is labeled wrong. I bought it on ebay, and think that the PO had the same problem. I'm going to NAPA tomorrow to try their 35" belt. Share this post Link to post Share on other sites
WHX?? 54,535 #6 Posted February 28, 2020 Take the fleabay belt to Napa Jim and have them put it on the belt measuring thingy. They'll help you out as long as @squonk ain't behind the counter.....Does the fleabay belt have numbers on it? A 35 should work fine last a long time... 1 Share this post Link to post Share on other sites
squonk 45,378 #7 Posted February 28, 2020 @Sparky where’s your thread on these Genny belts? Share this post Link to post Share on other sites
953 nut 63,975 #8 Posted February 28, 2020 I don't remember where I copied this from, but it should help. 232613 Kohler belt nla Use 231605 232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree 231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree 1964 model 854 1965 model 855 1965 model 875 Starter/generator belt Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree) Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree) 1964 model 1045 1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree 1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree 1965 model 1055 1965 model 1075 1 Share this post Link to post Share on other sites
SPINJIM 1,996 #9 Posted February 28, 2020 I put the #1593 belt on a belt gauge, and it measured a little less that 34". It was just too short on a K301. Either mis-labeled, or poor QC from WH. Bought a NAPA 3L350w belt (35" long), and it fit perfectly. 1 Share this post Link to post Share on other sites
squonk 45,378 #10 Posted February 28, 2020 I have been using the Napa 25 series belts for these. They are notched, a little thinner width wise and seem to fit better. of course they are more expensive than say a 3l series belt. Time to get those numbers off of my tractors and write them down! 2 Share this post Link to post Share on other sites
squonk 45,378 #11 Posted February 28, 2020 Ok on Big Block engine’s it’s a NAPA 25-7345 which is a .41” width x 35” Small blocks use a 25-7320 which is .41” width x 32.5” 1 Share this post Link to post Share on other sites
WHX?? 54,535 #12 Posted February 28, 2020 Is the belt labeled as a 1593? Save it for a 161 or 181. Share this post Link to post Share on other sites
squonk 45,378 #13 Posted February 28, 2020 22 hours ago, WHX24 said: Take the fleabay belt to Napa Jim and have them put it on the belt measuring thingy. They'll help you out as long as @squonk ain't behind the counter.....Does the fleabay belt have numbers on it? A 35 should work fine last a long time... @WHX24 never mess with a counterman. Or ex counterman for that matter. We have (had) buttons. My favorite one for the wise guys was L+10. (List plus 10%) 1 Share this post Link to post Share on other sites
