C_hasbeen 249 #1 Posted February 22, 2020 Cleaning up my plow that came with my 656 is this a brinley? It looks like it has some hitch modifying go on at one time. I hope previous owners had it set up close. It has Kentucky stamped on it. Share this post Link to post Share on other sites
WHX?? 55,232 #2 Posted February 23, 2020 Definitely not a Brinley.. @PeacemakerJack??? 1 Share this post Link to post Share on other sites
peter lena 9,781 #3 Posted February 23, 2020 definitely from back in the day, everything was overbuilt and designed to last forever , lucky you , pete Share this post Link to post Share on other sites
oliver2-44 11,272 #4 Posted February 24, 2020 Looking at that plows cast steel top main beam, I wonder if it isn't from something like an old one row Case, John Deere, or International. It sure looks like it's been modified to fit a slot hitch and I suspect the rubber gage wheel has been added. With that said, it should still turn the earth, heavy weight is good! Share this post Link to post Share on other sites
Stormin 9,987 #5 Posted February 24, 2020 On 2/22/2020 at 11:27 PM, C_hasbeen said: I don't think that weld is factory. Very interesting plough all the same. I googled Kentucky plow and plough. Couldn't come up with anything. 1 Share this post Link to post Share on other sites
C_hasbeen 249 #6 Posted February 25, 2020 19 hours ago, Stormin said: I don't think that weld is factory. Very interesting plough all the same. I googled Kentucky plow and plough. Couldn't come up with anything. Yea, a lot of welding on the plow looks like my welding does, I tried searching on Kentucky plow and came across one that was horse drawn and was cast iron beam. This one is heavier than a dead Minister. The culter arm was cut and welded to be used on this plow. Share this post Link to post Share on other sites
