toroman04 20 #1 Posted February 22, 2020 Hi all, I picked-up a 72 (was told it was a 74) after doing some research on it, anyway I need some help on a picture/part # for the choke cable. I have a Charger 10 automatic with a Kohler K241-46636 Any help would be appreciated! I have never owned a Wheel Horse before so I am new to this! I traded a snowmobile trailer for it.... It did not run, but did come with extra parts like: carb, ign. switch, starter, coil, front rims and tires, rear fender and a weight box. No mower deck but does have a plow. I seem to think I got the better end of the deal! 3 1 Share this post Link to post Share on other sites
ebinmaine 80,612 #2 Posted February 22, 2020 (edited) Welcome aboard! You should have a slide style cable. You got a great deal.... But I'm not much for snowmobiles.... Get that Charger up and cooking and you'll have a great little plow rig!! Edited February 22, 2020 by ebinmaine Corrected cable type 1 Share this post Link to post Share on other sites
Achto 32,632 #3 Posted February 22, 2020 (edited) 20 minutes ago, toroman04 said: I need some help on a picture/part # for the choke cable Here is one link for a choke cable. http://www.psep.biz/store/toro_mower_cables.htm Edited February 22, 2020 by Achto 1 Share this post Link to post Share on other sites
953 nut 69,142 #6 Posted February 22, 2020 (edited) Your choke cable should run under the shroud that covers the flywheel. The spiral sheath of the cable will attach to a fixture on the front of the shroud and the cable itself will have a "Z" bendin the end of it attaching to the choke. Edited February 22, 2020 by 953 nut fat finger Share this post Link to post Share on other sites
toroman04 20 #7 Posted February 22, 2020 here are a few pictures, what's throwing me off is what you see here (dash pic) Looks like same as throttle cable .... but is it actually a pull/push as there is a spot there or just a screw missing. Share this post Link to post Share on other sites
rjg854 13,341 #8 Posted February 22, 2020 That choke lever is the same style as the throttle Share this post Link to post Share on other sites
Oldskool 6,678 #9 Posted February 22, 2020 Welcome. I think you ended up with the better half of the trade. 1 Share this post Link to post Share on other sites
toroman04 20 #10 Posted February 22, 2020 I sure think i did get the better deal! lol though it has no spark and didn't run.... not a problem for me! I need to get a few more things for it yet.... air filter, fuel filter, new plug, drive belt and choke cable. 2 Share this post Link to post Share on other sites
ebinmaine 80,612 #11 Posted February 22, 2020 1 hour ago, rjg854 said: That choke lever is the same style as the throttle Share this post Link to post Share on other sites
stevasaurus 23,846 #12 Posted February 22, 2020 Here is a 1972 Raider 10...yours should be the same. You can see the choke handle in this picture. Contact A-Z Tractors...one of our vendors in the vendor section. He should be able to help with the choke cable and more. Welcome to Red Square 3 Share this post Link to post Share on other sites
toroman04 20 #13 Posted February 22, 2020 (edited) Thanks All! i'll contact them! Now I need to get a drive belt and figure out the part # for the trans filter.... all I can red is 79-52??? lol Edited February 22, 2020 by toroman04 Share this post Link to post Share on other sites
ebinmaine 80,612 #14 Posted February 22, 2020 Hydraulic transmission filter is likely a Napa 1410. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #15 Posted February 23, 2020 toroman04 As you can see lots of help here. Enjoy the site. 1 Share this post Link to post Share on other sites
toroman04 20 #16 Posted March 1, 2020 Thanks for all the help so far! I got a number to contact tomorrow for the part! Got a new plug, air & pre-filter along with a drive belt put on, now time to drain the transmission change filter and re-fill 1 Share this post Link to post Share on other sites
C_hasbeen 249 #17 Posted March 3, 2020 On 3/1/2020 at 3:24 PM, toroman04 said: Thanks for all the help so far! I got a number to contact tomorrow for the part! Got a new plug, air & pre-filter along with a drive belt put on, now time to drain the transmission change filter and re-fill Well you have a busy schedule once you get your parts in hand. 1 Share this post Link to post Share on other sites
peter lena 10,047 #18 Posted March 3, 2020 toroman04, in addition to your cable mounting / routing , make sure that you , hang and oil drip that cable , before use, ensuring its smooth function. another thing is to add more cable clamps to its routing tracking , that will insure its solid movement for use. just because clamps were not there , does not mean that you cannot add more for , smooth movement , pete 1 Share this post Link to post Share on other sites
peter lena 10,047 #19 Posted March 4, 2020 toroman04, see that you are going to change that trans fluid, good idea to cut off the shift boot with a razor blade and replace it , usually the cause of water getting in the trans. when you replace the boot lubricate the shifter shaft with grease for ease of installation. pete Share this post Link to post Share on other sites
toroman04 20 #20 Posted March 4, 2020 Hi Peter lena, It is a hydro, so is that/there a boot on that? I haven't seen one under there. Share this post Link to post Share on other sites
toroman04 20 #21 Posted March 10, 2020 Engine oil along with trans fluid & filter done! Time to run thru the wash and clean frame! Share this post Link to post Share on other sites
