grinchsr 674 #1 Posted February 8, 2020 Is there another source for part number 6397 which is the bronze bushing installed in the support block? $17.00 is getting a little steep for a bushing. Share this post Link to post Share on other sites
Lee1977 7,766 #2 Posted February 8, 2020 (edited) It should not be hard to fine a bushing that size. You need to measure it. The id is 3/4" and I'm guessing the od is 7/8" You might need to saw it off to get the right length. Edited February 8, 2020 by Lee1977 2 Share this post Link to post Share on other sites
balconio 606 #3 Posted February 9, 2020 The hard part for me was getting the darn steering wheel off. I gave up and ended up boxing the original bushing in with some plate steel that I cut up. Welded that in place and my steering wheel is not sloppy anymore. Share this post Link to post Share on other sites
briankd 833 #4 Posted February 9, 2020 7 hours ago, grinchsr said: Is there another source for part number 6397 which is the bronze bushing installed in the support block? $17.00 is getting a little steep for a bushing. i done mine on my c-120 went to local menards or if you don't have one of them lowes might they sell bronze bushings just about 2 bucks 1 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #5 Posted February 9, 2020 Like others here have said,measure the inside and outside diameter and length.Check with Graingers or MSC.They're sure to have something that will work for less than 17 bucks.Good luck. Share this post Link to post Share on other sites
dalez 148 #6 Posted February 9, 2020 If it is the lower bushing it's a thin wall bushing and I was unable to find it at any of the supply houses. Share this post Link to post Share on other sites
cleat 9,324 #7 Posted February 9, 2020 I drill the block out to 7/8 then press in bushings. This gets done for both upper and lower steering shaft locations. For the upper I then drill a small hole in the bushing for grease to pass through from fitting. I would add a grease fitting for the lower shaft but there is not enough metal there and it would weaken it too much. 4 Share this post Link to post Share on other sites
richmondred01 2,392 #8 Posted February 9, 2020 Cleat does outstanding work...... Share this post Link to post Share on other sites
pfrederi 21,145 #9 Posted February 9, 2020 (edited) Drilling out to 7/8" is an excellent plan. However not everyone has a 7/8" drill and press. If you do not consider using a nylon sleeve bearing. Will it last as long?? NO but at $2.99 you can replace it after a couple years... Edited February 9, 2020 by pfrederi 1 Share this post Link to post Share on other sites
Lee1977 7,766 #10 Posted February 9, 2020 I went and look at a steering support bearing I had and found it to be 13/16" od. Added that to the post that it could be drilled out to 7/8" Don't know where that went It's not there now. Share this post Link to post Share on other sites
cleat 9,324 #11 Posted February 9, 2020 1 hour ago, pfrederi said: Drilling out to 7/8" is an excellent plan. However not everyone has a 7/8" drill and press. If you do not consider using a nylon sleeve bearing. Will it last as long?? NO but at $2.99 you can replace it after a couple years... That would work great I believe. These are used quite a bit throughout the tractor for motion control and PTO pivot points. Share this post Link to post Share on other sites
grinchsr 674 #12 Posted February 9, 2020 Great responses and great ideas as always. Thanks Share this post Link to post Share on other sites
briankd 833 #13 Posted February 10, 2020 11 hours ago, cleat said: I drill the block out to 7/8 then press in bushings. This gets done for both upper and lower steering shaft locations. For the upper I then drill a small hole in the bushing for grease to pass through from fitting. thanks cleat for your help awhile back this is how i did mine worked great 1 Share this post Link to post Share on other sites
123Go 6 #14 Posted March 15, 2025 One of my old Horses steering block had a tab busted off & was half arse welded back together (crooked as chit) by the P.O. so be careful re-installing your block. Blocks can break if your front wheels hit objects too hard, fatty's like me holding the steering wheel getting on/off our tractors. May bust the block by over tightening or if the blocks not fully flush before you go to tightening one side too much etc.? Just listing the few ways I read it happens as a warning to folks who may be unaware their WH block is a delicate little jewel. This sites link on blocks may help members see the changes WH made on their tabs. Some folks have welded their own steel plate on their thin block so its thicker & drilled for Zerk fittings too: https://www.wheelhorseforum.com/topic/95841-steering-supports-are-they-all-the-same/ Share this post Link to post Share on other sites
