The Tuul Crib 7,340 #1 Posted January 27, 2020 So I've been soaking the steering wheel for the past two weeks and pounding on it and pounding on it with no progress. So today I started to get a little more aggressive and drill several holes in the end of the shaft and ended up cutting the shaft on the other end ! I saved the wheel!! The steering wheel shaft is only an inch and a half shorter but I can weld a new piece on the end of it. 4 Share this post Link to post Share on other sites
Lee1977 7,502 #2 Posted January 27, 2020 I cheated never got it off. I sawed the shaft into added a section and raised the wheel 3 more inches. 4 Share this post Link to post Share on other sites
SylvanLakeWH 30,142 #3 Posted January 27, 2020 Two broken drill bits. Several hours of grinding, drilling, grinding, drilling...small bit to larger to larger...big whacks on punch with a hammer...repeat... Numerous rounds of pb blaster, wd 40, unidentifiable “penetrating oil”, some torching, some adult beverages, some :($&@“!?$&bhfgfhfhhhhcffvhdu@&$@&$ words, some more adult beverages...and tada!!! It came off... More adult beverages... New one went on in about 30 seconds...! 2 3 Share this post Link to post Share on other sites
Ed Kennell 44,093 #4 Posted January 27, 2020 If the reason for removing the wheel is to replace the bushing, I cut the shafts between the the bushing and the fan gear then reconnect it with a shaft connector sleeve. 4 1 Share this post Link to post Share on other sites
Achto 30,460 #5 Posted January 28, 2020 Worst one that I had, SO FAR. I had to drill the roll pin out, BTW if your not using a carbide bit to do this your wasting your time & just wrecking drill bits. Then lube, hammer, etc, until I finally went to a friends shop and used his press to push the two a part. 4 Share this post Link to post Share on other sites
SylvanLakeWH 30,142 #6 Posted January 28, 2020 (edited) 5 minutes ago, Achto said: BTW if your not using a carbide bit to do this your wasting your time & just wrecking drill bits. Uhm, don’t ask why I now know that... Edited January 28, 2020 by SylvanLakeWH 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #7 Posted January 28, 2020 (edited) Well l broke 3 bits , hit my hand several times! Had a few words ahhh little loud wife was concerned.. slam dunk SAVED !!! Yes!! Edited January 28, 2020 by The Tool Crib 1 Share this post Link to post Share on other sites
pfrederi 19,471 #8 Posted January 28, 2020 If they are really bad pull the whole unit with instrument panel. Then you can clamp it a vice with blocking under it and drive out the roll pin (use a real roll pin pin punch and soaking with your favorite bug juice). Never had to drill one.,. Then with emery cloth clean up the shaft below the steering wheel. Now stand it up in the vice with the gear end of the shaft against the vice throat. climb up on a step stool and use an deep well impact socket the clears the shaft put in on an wail away with a sledge hammer the steering wheel will eventually slide down the shaft. then clean up the end and pull it back off. 3 Share this post Link to post Share on other sites
briankd 833 #9 Posted January 28, 2020 i beet and beet on roll pin won't move didn't want to destroy it was wanting it off to paint tractor but just used masking tape and taped it all up Share this post Link to post Share on other sites
WHX?? 53,735 #10 Posted January 28, 2020 Did you not see my thread Cribs on modified HF press to get the whole dash in it? . Half the battle here like Dan said is getting the pin out. Particularly on the soft touch wheels. Difficult steering wheel removal is a thing of the past in my shop... on to hubs and hitch pins! 2 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #11 Posted January 28, 2020 19 minutes ago, WHX24 said: Did you not see my thread Cribs on modified HF press to get the whole dash in it? . Half the battle here like Dan said is getting the pin out. Particularly on the soft touch wheels. Difficult steering wheel removal is a thing of the past in my shop... on to hubs and hitch pins! Yes I did see this thread and I do remember. Kind of curious what did it end up costing you? I just picked up a 12 ton jack from one of these Prevost buses. they come with every bus that we build and they just pitch em . I could've used it on the steering wheel but maybe next time I'll have it set up! 1 Share this post Link to post Share on other sites
WHX?? 53,735 #12 Posted January 28, 2020 The press was heck I don't even remember but way less than 200 with coupon in hand....20 ton bottle jack...... the mod not a dang thing. Way best the thing I got for my shop in years considering wheels, hubs, pins, broaching, bearings.... don't know how I got along without it.... oh yeah I do pounding on stuff with Paul's BFH and ruining it somemore.... 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,142 #13 Posted January 28, 2020 16 hours ago, The Tool Crib said: they come with every bus that we build and they just pitch em . That is wrong on so so many levels...glad you snagged one but what a waste... maybe a market idea for you... Share this post Link to post Share on other sites
tom2p 2,394 #14 Posted January 28, 2020 (edited) 21 hours ago, Lee1977 said: I cheated never got it off. I sawed the shaft into added a section and raised the wheel 3 more inches. I also cheated ... years and years ago - back in the 70's when I was a kid could not remove the steering wheel so I could remove the hood - so I cut the hood look closely and can see where hood was cut - instead of a hole there is now a slot (that extends to the bottom portion of the hood below the opening for the steering wheel column/shaft) Edited January 28, 2020 by tom2p Share this post Link to post Share on other sites
squonk 45,074 #15 Posted January 28, 2020 Wish I had pics. The roll pin would not budge. I took a small HF bearing separator behind the wheel, A large separator behind the little one. A gear puller that weighs over 25 lbs. from work onto the large separator and a 24" Cresent wrench. I sheared off the roll pin and bent the bolts on the small separator but got the wheel off. I extended the shaft as the wheel hit the hood on Skonk. Share this post Link to post Share on other sites
Rod Addicott 2 #16 Posted January 7, 2021 I put a large crescent wrench on the shaft below the steering wheel after i removed the roll pin and beat the wrench with a big hammer until i got it off! Share this post Link to post Share on other sites
953 nut 63,556 #17 Posted January 7, 2021 @Rod Addicott, please tell us a little more about your interest in by doing an introduction. https://www.wheelhorseforum.com/forum/47-introductions/?do=add Share this post Link to post Share on other sites
WHNJ701 4,168 #18 Posted January 7, 2021 Sometimes you got to pick and choose your battles, the david bradley, the bolens both steering wheels were frozen to the shafts bad. I could have fought them for weeks and who knows might have caused more damage. Both those wheels I restored "in place" on the shaft, dremeling/jb weld the cracks. As for roll pins you can't just hammer them out with a punch, you need a metal block behind the pin to remove Share this post Link to post Share on other sites
peter lena 9,642 #19 Posted January 7, 2021 I can relate, to my initial attempts at wheel removal , the best thing you can do , ( my opinion ) is to solidly side brace the wheel against a wall with a solid wood 4x4 ,when your impacts directly drive into the roll pin of the wheel , ( without bouncing ) that is what will move the pin. anything you do must be solidly centered to move your issue , I also clean up any related contact points and use never seize in the refit. having done this on my 3 horses , I know it works and has made a real problem , a non issue, pete 1 Share this post Link to post Share on other sites
Handy Don 15,610 #20 Posted January 7, 2021 3 hours ago, peter lena said: I can relate, to my initial attempts at wheel removal , the best thing you can do , ( my opinion ) is to solidly side brace the wheel against a wall with a solid wood 4x4 ,when your impacts directly drive into the roll pin of the wheel , ( without bouncing ) that is what will move the pin. anything you do must be solidly centered to move your issue , I also clean up any related contact points and use never seize in the refit. having done this on my 3 horses , I know it works and has made a real problem , a non issue, pete Can relate to the "roll pin challenge" and will definitely keep the "4x4" trick in mind for both removals and installs in the future. Fortunately the last time I did this I had the wheel and shaft off the tractor so used a bench vise to hold it. Also used anti-seize (boy that stuff is messy, though!) Share this post Link to post Share on other sites
peter lena 9,642 #21 Posted January 7, 2021 HANDY DON , yes that hammer bounce is telling you that you are not going any where, when that wheel is solid to the wall ,when your first 3 lb hammer strike stays solid , that pin is moving. agree with you on the never seize mess, but it insures that next time it will be much easier. after fighting my way in , I also got after related issues , started using a 2 bolt flange bearing on my shaft /thru consul area , stops shaft play . too often thinking that you are fixing one thing , it opens up to the opportunity to fix something else. started doing that on my 82 frakenhorse, experimenting , and testing , till it worked , then duplicated it on my other 2 horses. now they all work the same , with no issues , pete Share this post Link to post Share on other sites
Handy Don 15,610 #22 Posted January 7, 2021 16 minutes ago, peter lena said: started using a 2 bolt flange bearing on my shaft /thru consul area , stops shaft play Thought about this. Replaces the "flatted side" bushing and bolted to the tilted bracket? Still need the grub-screwed collar to keep the shaft down, right? There are so many connections in the reduction steering that add tiny bits of play that I just live with it--not like a sports car, after all Share this post Link to post Share on other sites
peter lena 9,642 #23 Posted January 7, 2021 don , this is the bearing I use ,https://www.vxb.com/3-4-UCFL204-12-2-Bolts-Flanged-Housing-Mounted-p/Kit7334.htm?gclid=CjwKCAiA_9r_BRBZEiwAHZ_v18CNkifnENP2glzvSExwLobk-wmGFvxkVAjSZFZ1lotFOVTXOewthxoCzEUQAvD_BwE , if you have a bolt thru area that the shaft goes thru , once you slide in place , you can see your mounting spots . much stronger than the original set up , just an idea, pete 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #24 Posted January 8, 2021 Wow, guess I was lucky with mine. I got mine off with one of those big 2-jaw pulley pullers (like the one below). Took a lot of PB Blaster, heat, and a big breaker bar on the puller, but it came off. 1 Share this post Link to post Share on other sites
Damien Walker 297 #25 Posted January 18, 2021 After much fighting, I managed to get the roll pin out, but the shaft steadfastly refused to budge. As the centre cap was missing from the wheel, that gave me the idea of pushing it out in a press.... Drill through the plastic in the centre of the wheel, put in the press, supporting the boss from underneath and press out using a drift. There is no way it would have come out with any other method save for drilling out as The Tuul Crib describes. Using a puller is likely to damage the underside of the boss. 3 Share this post Link to post Share on other sites
