2&only 0 #1 Posted January 20, 2020 Is there anything that can be done to make manual lifting of plow easier? getting older I guess Share this post Link to post Share on other sites
The Tuul Crib 7,332 #2 Posted January 20, 2020 to some of us here have used electric wenches. Do you have a hydro tractor or manual? Share this post Link to post Share on other sites
bottjernat1 2,189 #3 Posted January 20, 2020 Welcome. Might try a small electric winch from like harbor freight. They also sell a bracket kit for there winches https://www.harborfreight.com/2500-lb-atvutility-electric-winch-with-wireless-remote-control-61840.html might be a bit extreme but would work. Or a simple thing try greasing on the pivot points real good use a real good grease and some pb blaster! Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #4 Posted January 20, 2020 Add some springs from the front frame/attach-a-matic to the snow plow frame much like a helper spring for tiller or snow throwers. 4 Share this post Link to post Share on other sites
ebinmaine 63,218 #5 Posted January 20, 2020 49 minutes ago, WVHillbilly520H said: Add some springs from the front frame/attach-a-matic to the snow plow frame much like a helper spring for tiller or snow throwers. I've thought about doing that for both Trina and I. Any thoughts on what type of spring? Size? Whatever? Share this post Link to post Share on other sites
stevasaurus 22,234 #6 Posted January 20, 2020 Wheel Horse had a spring assist kit. Might check the Manual Section. I know we've some threads on this subject. The Misc. section has quite a few manuals about springs and spring assist...check Manuals/Misc section. Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #7 Posted January 20, 2020 6 hours ago, ebinmaine said: I've thought about doing that for both Trina and I. Any thoughts on what type of spring? Size? Whatever? Something along these lines/specs ...https://www.grainger.com/product/GRAINGER-APPROVED-6-High-Carbon-Steel-Utility-1NAF8. 1 Share this post Link to post Share on other sites
Pullstart 59,753 #8 Posted January 22, 2020 Is this overkill? They’re about 15” long. I have two used ones from my plow truck! 1 Share this post Link to post Share on other sites
