arrkerr 54 #1 Posted January 19, 2020 I've moved the coil on my C-145 to the other side of the block and have a longer spark plug wire thanks to someone on this forum but I also need to extend the wire from my points back to the coil. I imagine a new wire instead of splicing in a bit is the right way to go. Before I go and just try and match it at the local hardware store, any recommendations or pointers on the wire, material, etc for the best result? Thanks! Share this post Link to post Share on other sites
Mike'sHorseBarn 3,350 #2 Posted January 19, 2020 I just use 14 gauge wire on every points wire I ever replaced. Doesn't have to be anything fancy. You can get wire in rolls at lowes, home depot, tractor supply, a local hardware store etc. 3 Share this post Link to post Share on other sites
arrkerr 54 #3 Posted January 19, 2020 Great, thanks for the reply. 55 minutes ago, Mike'sHorseBarn said: I just use 14 gauge wire on every points wire I ever replaced. Doesn't have to be anything fancy. You can get wire in rolls at lowes, home depot, tractor supply, a local hardware store etc. Great, thanks for the reply! 1 Share this post Link to post Share on other sites
