formariz 12,381 #1 Posted April 24, 2009 Reading different publications from Kohler on governor adjustment I get a little confused since they don't all state the same facts. Reading one last one leads me to think that I have them all adjusted incorrectly. Unlike other publications this one states that with the engine at rest (stopped I presume) the governor should hold the throttle in the fully open position. With the exception of a brand new k91 I just got never fired before none of the others I have do that, whether adjusted by me or someone else. This new engine got me thinking that all others may be wrong. Any help greatly appreciated as always. Share this post Link to post Share on other sites
CasualObserver 3,416 #2 Posted April 24, 2009 Governor adjustment is about 2/3 of the way down in the FAQ section. I have never seen one hold the throttle wide open at rest. You say the new engine does? do you have or can you take pics? Share this post Link to post Share on other sites
formariz 12,381 #3 Posted April 24, 2009 If you look in the Wheelhorsemanualsgroup in the file indicated below under governor systems that is what it states it should do. Engine Kohler K91 K141 K161 K181 K241 K301 K321 SM 1972.pdf I will take a photo of governor and post it a little later. I have never started this engine. I removed the electrical parts since I am fitting it to an RJ so I cannot start it for a while.I am wondering if when started the governor will then go into a "normal" position. The engine is a Battery ignition system K91S that I posted a few days ago. Share this post Link to post Share on other sites
formariz 12,381 #4 Posted April 29, 2009 I finally started new engine.Like I mentioned before governor holds throttle wide open with engine stopped. Once engine starts governor lets engine idle normally.When shut down it again opens throttle fully. I believe then that all the others are incorrect.Only one publication I know of from Kohler states it should be this way. Share this post Link to post Share on other sites
