Horse Play 393 #1 Posted December 15, 2019 I am getting ready to assemble my RJ gas tank and sediment bowl along with the brass fittings. Should I use a thread sealant on the NPT fittings? Thank you! 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #2 Posted December 15, 2019 Yes Garry 4 Share this post Link to post Share on other sites
JoeM 10,310 #3 Posted December 16, 2019 (edited) This stuff works pretty good, Rector Seal #5 available at Lowe's $6 ish. If you get some Knead the tube before opening to keep it mixed, sometime there is a slight separation. RectorSeal No. 5 - RectorSeal.pdf Edited December 16, 2019 by MrOiluj52 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #4 Posted December 16, 2019 Apply the sealer to the male threads only. That way none of it ends up in the system. Garry 1 Share this post Link to post Share on other sites
bottjernat1 2,197 #5 Posted December 16, 2019 I used gas line thread tape on my rj. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #6 Posted December 16, 2019 Teflon tape 3 Share this post Link to post Share on other sites
WHNJ701 4,173 #7 Posted December 16, 2019 1 hour ago, The Tool Crib said: Teflon tape i dont think its fuel safe??? I never sealed any of the threads on about 12 or so I own and don't have issues. I don't keep much fuel in them and keep them dry in the winter Share this post Link to post Share on other sites
953 nut 69,558 #8 Posted December 17, 2019 Ultra Copper is the ony sealer I have ever used on fuel lines, others may work as well. Share this post Link to post Share on other sites
formariz 12,381 #9 Posted December 17, 2019 Here you go https://www.gsasupplyco.com/products/gasoila-e-seal-thread-sealant-with-ptfe Share this post Link to post Share on other sites
ZXT 2,402 #10 Posted December 17, 2019 (edited) 21 hours ago, The Tool Crib said: Teflon tape I don't typically use thread sealant on fuel fittings unless they leak, since pipe threads are designed to not leak in the first place. If they do, it's typically only a small drip, and I've used Teflon tape on tractors and cars with no issues. I had a drip at the inlet of the sediment bowl on my dad's 57 Chevy when I put the 350 in it. I put Teflon on the threads to stop it. 8 years and about 10,000 miles later, still no drip. Just make sure you wrap the tape in the right direction! Edited December 17, 2019 by ZXT 1 1 Share this post Link to post Share on other sites
Horse Play 393 #11 Posted December 21, 2019 Thank you, all very much! Share this post Link to post Share on other sites
rmaynard 17,589 #12 Posted December 21, 2019 I know I'm a little late to the party here, but if your fittings are the type with the rubber ring in them, you shouldn't need any sealant on the threads since the rubber is the seal, not the threads. If they leak, replace the rubber seal. As far as Teflon tape or Teflon paste, anything other than the yellow is not safe for fuel. Petroleum will dissolve it. 1 Share this post Link to post Share on other sites
WildmanC120 615 #13 Posted December 21, 2019 1 hour ago, rmaynard said: I know I'm a little late to the party here, but if your fittings are the type with the rubber ring in them, you shouldn't need any sealant on the threads since the rubber is the seal, not the threads. If they leak, replace the rubber seal. As far as Teflon tape or Teflon paste, anything other than the yellow is not safe for fuel. Petroleum will dissolve it. Truth. Use the yellow Teflon tape made for gas and you will be fine. I use it all the time. You can even get it at Lowe's or Home Depot 1 Share this post Link to post Share on other sites
