DBlackston 323 #1 Posted December 2, 2019 Hello, My 854 has the entire area where the hood bolts attach broken out. My other tractor is a 704 so it does not have the same tankbto compare. Can someone post a vouple views of how the tank looks where the hood bolts to? Im thinking I can weld in a patch plate if I know what it looks like. Thanks! Share this post Link to post Share on other sites
WHNJ701 4,169 #2 Posted December 2, 2019 I did this on mine https://www.wheelhorseforum.com/topic/81947-simple-fix-for-854-broken-hood-mounts-2-part-gas-tank/ Share this post Link to post Share on other sites
Pullstart 68,882 #3 Posted December 3, 2019 The links above have some detail showing the pocket that has the tinnerman clip. @AMC RULES once suggested similar to @jabelman‘s fix, but to PC-7 a nut into that area. Either way, make sure you use a short bolt when re-assembling everything! 1 Share this post Link to post Share on other sites
