cpic1 0 #1 Posted November 29, 2019 Hi does anyone know how to clean and adjust a carb for a kt17qs Share this post Link to post Share on other sites
ZXT 2,401 #2 Posted November 29, 2019 1 hour ago, cpic1 said: Hi does anyone know how to clean and adjust a carb for a kt17qs Cleaning it is pretty easy. Pull it off, take all of the screws holding the two halves together, and if you're careful, you should be able to pull it apart without tearing the gasket. After that, take carb cleaner and possibly a rag and clean out the bowl. Blow carb cleaner through all of the passages to ensure they're clear. If any of them are clogged and the pressure of the carb cleaner isn't enough to remove the blockage, I've found that torch tip cleaners do an excellent job. Once everything is clear and the needle isn't stuck, it should go back together and run. Assuming you haven't messed with the adjustment screws, count the number of turns it takes to seat each of the screws and write it down. Be sure and only seat them lightly; if you tighten them too much you could damage them. I would then put the screws back in the same position they were in previously as a baseline and adjust them slightly if needed to achieve the best running conditions. Share this post Link to post Share on other sites
pfrederi 18,685 #3 Posted November 29, 2019 Section 4 of this manual you can download free here will tell you all you need to know... (click on the picture) Share this post Link to post Share on other sites
tunahead72 2,546 #4 Posted November 29, 2019 This is my go-to reference for cleaning Kohler carbs: http://www.mgonitzke.net/cubcadet/tools/carb_rebuild.pdf 1 Share this post Link to post Share on other sites
balconio 606 #5 Posted December 2, 2019 what do you guys like for carb cleaner? i've used a bunch of different brands but i think Berryman's B-12 chemtool works the best and it's what i've stuck with for years. my honda GX motors seem to have very finicky carbs- and usually a shot of this stuff will clear out what ails them... https://shop.advanceautoparts.com/p/berryman-b-12-chemtool-carburetor-choke-and-throttle-body-cleaner-16-fl.-oz.-not-voc-compliant-in-some-states-0117/11289459-p Share this post Link to post Share on other sites
