AHS 1,674 #1 Posted November 26, 2019 There otta be be a “seat” section! IMO! The seat on my 2000 is too far forward... and it’s not like the wheel horse original seat (like the late 70s seat) with the seat springs (c shaped). The photos are of my Dads C101 and 1of my 2000 WH. I ordered off eBay the old WH seat bracket and springs. Next i need to order a seat.... they don’t a make seats like they used to!! 3 Share this post Link to post Share on other sites
ebinmaine 78,162 #2 Posted November 26, 2019 I put the Cinnamon Horse seat on long brackets. Moved it back a couple extra inches. 2 Share this post Link to post Share on other sites
peter lena 9,833 #3 Posted November 26, 2019 AHS , this is the seat i have on my three horses, https://www.agrisupply.com/universal-tractor-seat/p/14119/ , exact w/h bolt pattern for easy bolt on , agree with ebinmaine on the long seat brackets, i also picked up some nice craftsman / murry seat springs which really helped on the very end of the mount. look at your options to remount that seat frame, probably picking up some 5/16 or 3/8 steel flat stock for bolt mount strength . you might remove the seat/ fender pan to give you a better look at your seat mounting possibilities. once you find a go to, under fender frame possibility , use the steel flat stock to bridge the area. drill a few holes and remount your much better fitting seat, pete 2 Share this post Link to post Share on other sites
AHS 1,674 #4 Posted November 26, 2019 1 hour ago, peter lena said: AHS , this is the seat i have on my three horses, https://www.agrisupply.com/universal-tractor-seat/p/14119/ , exact w/h bolt pattern for easy bolt on , agree with ebinmaine on the long seat brackets, i also picked up some nice craftsman / murry seat springs which really helped on the very end of the mount. look at your options to remount that seat frame, probably picking up some 5/16 or 3/8 steel flat stock for bolt mount strength . you might remove the seat/ fender pan to give you a better look at your seat mounting possibilities. once you find a go to, under fender frame possibility , use the steel flat stock to bridge the area. drill a few holes and remount your much better fitting seat, pete I ordered it! Come to find out 7” x 7.5” is a popular size. My dad is tall, 6’2”,I will try his C101 and figure out where I want it. I’m not that tall, only 5’10”. I imagine my dad has got his the furthest away from his pedals! Thanks!! 1 Share this post Link to post Share on other sites
ebinmaine 78,162 #5 Posted November 26, 2019 34 minutes ago, AHS said: I ordered it! Come to find out 7” x 7.5” is a popular size. My dad is tall, 6’2”,I will try his C101 and figure out where I want it. I’m not that tall, only 5’10”. I imagine my dad has got his the furthest away from his pedals! Thanks!! I'm 6'-1" and not exactly small...... I can use the stock rear most seat bolts but it isn't super comfy. You'll be fine with it. On a side note of the same subject.... Colossus will have a 7" extension between the frame and transmission. Leg room should be good. 1 Share this post Link to post Share on other sites
AHS 1,674 #6 Posted November 26, 2019 1 hour ago, ebinmaine said: I'm 6'-1" and not exactly small...... I can use the stock rear most seat bolts but it isn't super comfy. You'll be fine with it. On a side note of the same subject.... Colossus will have a 7" extension between the frame and transmission. Leg room should be good. Pictures please!? A 7” extension between the frame and transmission? You mean a looong tractor!?😄 1 Share this post Link to post Share on other sites
ebinmaine 78,162 #7 Posted November 26, 2019 19 minutes ago, AHS said: Pictures please!? A 7” extension between the frame and transmission? You mean a looong tractor!?😄 Yepp And wider. And taller. There's some description in the thread. Share this post Link to post Share on other sites
skrusins 128 #8 Posted November 27, 2019 Be careful how far you mount your seat. You'll shift more weight to the rear. 2 Share this post Link to post Share on other sites
ebinmaine 78,162 #9 Posted November 27, 2019 1 minute ago, skrusins said: Be careful how far you mount your seat. You'll shift more weight to the rear. It would be difficult at best to move it back far enough to effect anything. I'm uhhh.... Large.... And the balance of the tractor hasn't been changed. The seat pans that flip open can be bolted down... or like mine .. I put a deeper notch in the lock. If anything it's favorable to have a little more drive traction. 1 Share this post Link to post Share on other sites
tom2p 2,394 #10 Posted November 27, 2019 1 hour ago, ebinmaine said: It would be difficult at best to move it back far enough to effect anything. I'm uhhh.... Large.... And the balance of the tractor hasn't been changed. The seat pans that flip open can be bolted down... or like mine .. I put a deeper notch in the lock. If anything it's favorable to have a little more drive traction. wheelie like pullstart ! 2 1 1 Share this post Link to post Share on other sites
Pullstart 69,582 #11 Posted November 27, 2019 25 minutes ago, tom2p said: wheelie like pullstart ! Huh what? 1 Share this post Link to post Share on other sites
953 nut 65,072 #12 Posted November 27, 2019 (edited) 9 hours ago, tom2p said: wheelie like pullstart ! That would be @WHX24 not @pullstart. Edited November 27, 2019 by 953 nut 2 1 1 Share this post Link to post Share on other sites
Pullstart 69,582 #13 Posted November 27, 2019 Jane’s been known to be a little light in the front end too.. 1 Share this post Link to post Share on other sites
tom2p 2,394 #14 Posted November 27, 2019 4 hours ago, pullstart said: Jane’s been known to be a little light in the front end too.. thatswhatimtalkinabout ! 1 Share this post Link to post Share on other sites
AHS 1,674 #15 Posted November 27, 2019 That some torque! 💪👍 a craftsmen would break in half at that torque!! Share this post Link to post Share on other sites
AHS 1,674 #16 Posted November 27, 2019 Wait a minute... how did we go to talkin about seats to tractors pulling wheelies?... I’m not complaining!!😄 Share this post Link to post Share on other sites
ebinmaine 78,162 #17 Posted November 27, 2019 2 hours ago, AHS said: That some torque! 💪👍 a craftsmen would break in half at that torque!! if you can get the tires to stick to the ground it's amazing how well something small like a seven or eight horse engine will pull. 2 hours ago, AHS said: Wait a minute... how did we go to talkin about seats to tractors pulling wheelies?... I’m not complaining!!😄 Us and our tangents..... 1 Share this post Link to post Share on other sites
