The Tuul Crib 7,339 #1 Posted November 25, 2019 So I've got this 16 horse setting on lRV And Saturday finally got everything hooked up with some gas in it and it started right up after a few cranks of course. The motor sounded good at first but I did detect a little tappet noise and didn't give it much thought. So went ahead and adjusted the governor and hooked up the linkage get it already to go and Sunday morning went to crank it and it turned over and shot gas out the carb . Now it acts like there is too much compression with the plug in it And can't get it to crank over. So I went back and checked the valve adjustments and reset them correctly with only the same thing . Any ldeas? Share this post Link to post Share on other sites
coldbear 29 #2 Posted November 25, 2019 Haven't got it hydro- locked have you? Take the plug out and crank it over for a few seconds. If it's locked up , most the time it's too much fuel in the cylinder . 4 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #3 Posted November 25, 2019 9 minutes ago, coldbear said: Haven't got it hydro- locked have you? Take the plug out and crank it over for a few seconds. If it's locked up , most the time it's too much fuel in the cylinder . No hydro on this one. There has been some battery discussion amongst some others I have talked to and I may not have paid attention to the CCA on the battery. I went through the engine lapped the valves replaced the rings. It may be a little tight. I just went back and checked the valve adjustments and they are correct. I did look at the battery and it said 150 CCA. Share this post Link to post Share on other sites
ZXT 2,401 #4 Posted November 26, 2019 2 hours ago, The Tool Crib said: No hydro on this one. There has been some battery discussion amongst some others I have talked to and I may not have paid attention to the CCA on the battery. I went through the engine lapped the valves replaced the rings. It may be a little tight. I just went back and checked the valve adjustments and they are correct. I did look at the battery and it said 150 CCA. The K341 on my CC 1650 also cranks stupidly hard. From what I've been told, there is a tab that can break off of the cam that will cause the ACR not to function, and there is also a spring in there that can get weak and cause the same symptom. I can only get it started with an extremely hot battery and jumper cables to another battery. You may have the same issue. What CCA is your battery? Share this post Link to post Share on other sites
Achto 29,550 #5 Posted November 26, 2019 2 hours ago, The Tool Crib said: No hydro on this one. @coldbear was referring to having too much fuel in the cylinder, this will cause the engine to turn over hard. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #6 Posted November 26, 2019 10 minutes ago, ZXT said: The K341 on my CC 1650 also cranks stupidly hard. From what I've been told, there is a tab that can break off of the cam that will cause the ACR not to function, and there is also a spring in there that can get weak and cause the same symptom. I can only get it started with an extremely hot battery and jumper cables to another battery. You may have the same issue. What CCA is your battery? The battery is at 150 CCA i'm going back to AutoZone and get one with at least 350 I guess I wasn't paying attention the day I picked it up the price was good but the battery enough git up and go. I just think there's lots of compression here since I put new rings in it and it was bored 20 over . If the battery doesn't do it then I may have to tear the motor back down and see what's going on with the camshaft Definitely a set back 1 Share this post Link to post Share on other sites
ZXT 2,401 #7 Posted November 26, 2019 1 minute ago, The Tool Crib said: The battery is at 150 CCA i'm going back to AutoZone and get one with at least 350 I guess I wasn't paying attention the day I picked it up the price was good but the battery enough git up and go. I just think there's lots of compression here since I put new rings in it and it was bored 20 over . If the battery doesn't do it then I may have to tear the motor back down and see what's going on with the camshaft Definitely a set back Hopefully not too much of a set back. I put a 150CCA battery on my dad's C-141 and it cranked it over about 10 revolutions before it gave out. The battery is probably your issue. It's definitely worth the extra $20 for the big battery. My C-120 has an Exide car-style battery on it. I think it's around 550 CCA. It is excellent and fits the battery tray perfect. It was on the tractor when I got it and I hope it lasts a long time. It'll cost a bit more than a mower battery when it comes time to replace. 1 1 Share this post Link to post Share on other sites
Pullstart 67,424 #8 Posted November 26, 2019 In standard troubleshooting, the first thing I’d ask a water heater customer is “what did you last do to it”? Well..... what did you do to it? 5 Share this post Link to post Share on other sites
WildmanC120 613 #9 Posted November 26, 2019 Check your timing too. My c-160 is a hard cranker. It would also kick back when starting. I adjusted the points gap to .18-.19 and it made a huge difference. 2 Share this post Link to post Share on other sites
oldredrider 2,553 #10 Posted November 26, 2019 16hp Kohlers need a LOT of amps at the starter turn over a fresh rebuild. 150 cca ain't gonna cut it! Hopefully, that's the problem and not in the acr. 3 Share this post Link to post Share on other sites
tom2p 2,394 #11 Posted November 26, 2019 (edited) agree - regardless (of other potential issues) 150 CCA not sufficient ; certainly not for a 16HP garden tractor my Diehard is 340 CCA Duracell 350 CCA ( 550 CCA can be common in a car battery ) Edited November 26, 2019 by tom2p Share this post Link to post Share on other sites
wfrpalm 218 #12 Posted November 26, 2019 Did you check if there is gas in the cylinder yet? Hydro lock sounds likely if gas is flowing out of the carb. Share this post Link to post Share on other sites
The Tuul Crib 7,339 #13 Posted November 26, 2019 8 hours ago, pullstart said: In standard troubleshooting, the first thing I’d ask a water heater customer is “what did you last do to it”? Well..... what did you do to it? She needs more powa captain ! lm not givin er enuf!! 1 1 Share this post Link to post Share on other sites
Achto 29,550 #14 Posted November 26, 2019 2 hours ago, The Tool Crib said: She needs more powa captain ! lm not givin er enuf!! Try firing a phaser into the Dilithium crystals to recharge them. 1 2 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #16 Posted November 26, 2019 Damit Jim lm a doctor not a captain! 1 Share this post Link to post Share on other sites
Achto 29,550 #17 Posted November 27, 2019 I may not be a Captain but I'm well acquainted with one. 2 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #18 Posted November 28, 2019 (edited) Well I thought about starting a new thread for this one but I figured the heading was fine because now it's the end exclamation! Well at least for now. I had a catastrophic event yesterday with the motor running. Sounded good for the longest time then all of a sudden I heard a big clunk followed by slow slow turning of the fly wheel. I knew right away what had happened! But lo and behold I do believe the block is OK Pictures are worth 1000 words ! Or should I say 1000 pieces ! Edited November 28, 2019 by The Tool Crib 1 4 Share this post Link to post Share on other sites
tom2p 2,394 #19 Posted November 28, 2019 oh my not good 1 Share this post Link to post Share on other sites
WildmanC120 613 #20 Posted November 28, 2019 52 minutes ago, The Tool Crib said: Well I thought about starting a new thread for this one but I figured the heading was fine because now it's the end exclamation! Well at least for now. I had a catastrophic event yesterday with the motor running. Sounded good for the longest time then all of a sudden I heard a big clunk followed by slow slow turning of the fly wheel. I knew right away what had happened! But lo and behold I do believe the block is OK Pictures are worth 1000 words ! Or should I say 1000 pieces ! Oh man that's awful. How the heck did it happen??? Share this post Link to post Share on other sites
Razorback 1,136 #21 Posted November 28, 2019 Ouch!!! Share this post Link to post Share on other sites
The Tuul Crib 7,339 #22 Posted November 28, 2019 Not really sure I was told maybe the rod Was on backwards or in proper torque on the rod cap. Oil starvation. I did put the crank on the lathe and cleaned it up . Probably have to put a mic on it to see If it is still within spec. 2 Share this post Link to post Share on other sites
richmondred01 2,309 #23 Posted November 28, 2019 (edited) At minimum that will need to be polished. Most likely turned. hole in rod cap faces the cam. How does the cylinder apron look. Many times when the rod breaks like that it cracks or chips the apron. Edited November 28, 2019 by richmondred01 2 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #24 Posted November 28, 2019 At a glance l havent found any damage. I might have gotten lucky on this one . I think the ghost of lRV is with me for sure! 1 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #25 Posted November 29, 2019 Sorry to hear and see that,I guess you will start to rebuild.Is this something you use as a worker or do you have time on this.I hope their is no further damage 1 Share this post Link to post Share on other sites
