JoeM
Removing Rusted Exhaust Nipple in Kohler
JoeM
I was working on an old Kohler and the PO installed a pipe nipple and sprinkler head muffler. Wanting to change the configuration, I set out to remove the old nipple and found mother natures Loctite, (rust), was used. I have had these in the past and most come out with a big pipe wrench, but this one was not go. It was so tight the nipple was distorted.
I removed the last one like this by cutting the nipple off within a 1/4" of the block and used a loose hacksaw blade to cut through the side wall of the nipple, in two places, until I nicked the threads. If you have a good blade, it cuts fairly easy. Then bump in the piece and removed the nipple, Tapped the thread and it worked out okay.
I figure there are others that had this issue and I am sure there are other ways, possibly easer.
It is just simply amazing how that rust can hold on and make metal stick.
I included a few pics.
SawBladeCut1.jpg.206e2e0a36efbbd167255b0d53646bef.jpgRemovingWithChiesel2.jpg.68cadaf5ffc4d1fdae15a6bb449abf24.jpg
RemovingWithChiesel1.jpg.f22cef569f40b7b7de9eec1f29aa2ccf.jpgAfterRemovalBeforeTap1.jpg.fdc8dc5b496edbb5897e2c7776727028.jpg
  • Like 7
  • Thanks 2
Digger 66
I would  suggest a left handed tap slightly larger than the I.D. of the nipple material .
Before I tried anything though , I would tip the engine ( or the whole tractor if need be ) toward the piston and soak it with some concoction for a few days .
But it looks like you did a fine job !
Edited by Digger 66
Mikey the Monkey
nice way to do it...what is the tap i need when searching online for one?
ebinmaine
I've used a similar method on the 16 in Cinnamon Horse and a 12.
Time consuming and requires patience but works well.
adsm08
When replacing the muffler on my K181S earlier this year I ran into a similar issue. Not only did I distort the pipe (but not the threads) I managed to lift the whole front end of the tractor off the ground by that pipe.
Then I tried to tighten it, and it moved in just fine. Came out really nicely after that too.
gwest_ca
Pipe sizes can be deceiving
1/2" pipe is .840" OD (approx 27/32")
3/4" pipe is 1.050" OD (approx 1-3/64")
1" pipe is 1.315" OD (approx 1-5/16")
1-1/4" pipe is 1.660" OD (approx 1-21/32")
Pipe taps can be expensive. Places like Harbor Freight may have a set reasonably priced and good enough for cleaning up rusty blocks.
A trick I learned from a servicing dealer 60 years ago. Clean up the threads. Apply Never Seize to the male and female threads. Add an electrical conduit lock nut to the male threads as far as it will go by hand.
Insert the male threads in the block by hand as far as it will go. Back it off 1/2 turn. Now tap the lock nut with hammer and punch to tighten the assembly to the block and maintaining that 1/2 turn out.
This procedure was repeated spring and/or fall as they were servicing equipment for the next season. It works - they never have a chance to seize.
Garry
JoeM
Yep Gary it, It is 1 inch NPT, home cheap o
squonk
That's a heck of a price for a 1"tap. They are usually $100!!!
ebinmaine
Here in the road salted Northeast and especially near the ocean... We have huge and constant issues with rust.
I learned a neat trick from a tech awhile back.
You can almost always TIGHTEN something but you CAN'T always LOOSEN that same thing.
One of his most simple and best ways to defeat corrosion was to tighten a bolt just a few degrees, then loosen. Repeat.
ebinmaine
They're cheap for sure.
And they actually work pretty well...
Maybe not for constant shop usage but great for occasional help.
Cutting oil is a must.
I've found the hard way that they're a bit brittle.
  • Sad 1
JCM
Removing that nipple reminds me of removing rotted nipples on Steam Boilers , Supply and Return Headers etc. That process has always worked for me, although glad I don't do much of that anymore. I have a set of Ridgid Taps from  1/8''  to  2'' that i bought  38 years ago, can't remember the cost but they were very pricey, but I still have all of them and they have never failed me.
peter lena
agree with members on this issue, my experience working with a pipe-fitter, taught me to use a solid leverage point to move just about anything. using the existing exhaust nipple as your starting point , you must detail and enhance the  initial impact drive. i use an  18 or 24" pipe wrench tightly secured at nipple to engine block area angled up to enhance your down ward impact with a 3 lb hammer. there should be  NO HAMMER BOUNCE ,  JUST A SOLID IMPACT DRIVE, that will start the movement. penetrating oil helps , but its the solid , no bounce impact that will move that nipple, pete
pacer
I'm having a hard time seeing how a tap helps in this situation -- adding threads to the nipple does what??
I just grab my variable speed jig saw with a metal blade and cut through the threads at 2 points and the nipple will almost fall out.
  • Confused 1
Digger 66
They're using the tap to chase the existing threads after the nipple material has been removed .
  • Excellent 3
stevasaurus
I just cut the nipple so about 1/4" was sticking out, then, with a cold chisel collapsed what was left of the nipple in the block.  It collapsed easily and then pulled out.  Re-tapped the threads with a sacrificial nipple.  I'm frugal.  :occasion-xmas:
squonk
Back in the day when I could actually see, I used a cutting torch to slice the inside of the nipple.
Achto
Another trick that has worked well for me. Before you try to loosen the pipe smack it a few good times with a hammer. Not so hard as to crack the engine casting but some good whacks. This jars the rust & will help the threads break loose from years of brown weld. I learned this trick from a pipe fitter & it has worked every time for me.
  • Like 4
cafoose
Maybe use something like this on an air hammer?
  • Excellent 2
Achto
This does work most excellently and I do use it. But not all have the luxury of air tools. Figured every one would have a hammer though.:)
  • Haha 1
adsm08
There is a surplus store around me where I can buy taps 3/4"-2" for $18/lb.
Mudrig150
I got mine out by totally intentionally breaking it off almost flush with the block. Soaked it for 2 weeks and with only a tiny bit of force it just let go (and not in the way I wanted). I then used a pry bar like a chisel and chiseled the 2 cuts out, knocked out the cut, and used the hammer to knock the rest out.
Kelsey
After following this thread's instructions, our K241's threaded nipple came out in less than 12 minutes.
Thanks to all !!
Kelsey
Epayne85
Local mechanic here said to try and break it free using the heat of the engine when finished working the tractor. Not sure if that’s the easier method but will be giving it a try in a day or two.
ebinmaine
In principle I like the idea but I don't see it helping much. Cast iron head with a black iron/steel pipe. Just not much differential in temperature and expansion rates there.
Epayne85
That’s what I was thinking as well. He assured me it should work 🤷🏻‍♂️
