Mr Magoo 226 #1 Posted November 21, 2019 I have a C-120 I am working on and it has a dipstick where the rubber seal is falling apart. Am I correct to assume that this system needs to be under pressure and that is the reason for the rubber seal on the dipstick? I am worried that pieces of the seal are or have fallen down inside and may cause a blockage. Does anyone have a fix for this or know where to find a replacement? Ken Share this post Link to post Share on other sites
Mr Magoo 226 #2 Posted November 21, 2019 After doing some more digging, I did find a current part # for this dipstick that seems to be the correct one. It is Toro part #101847-03. Looks like these are available, but they are a bit pricey at around $32.00-$37.00. Still cheaper than having the tranny screwed up by debris I suppose. 1 Share this post Link to post Share on other sites
Pullstart 71,157 #3 Posted November 21, 2019 I assume the pipe size is 1/2” for the dipstick tube. This Charger 12 trans has a threaded dipstick similar to an engine’s. Maybe you could use that style as an easy replacement? Here is a picture of “Frank’s” toolbox area... 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #4 Posted November 21, 2019 26.67 plus 7.95 flat rate shipping. Need other items? http://www.psep.biz/index.htm Garry 1 Share this post Link to post Share on other sites
Achto 32,464 #5 Posted November 22, 2019 6 hours ago, gwest_ca said: 26.67 plus 7.95 flat rate shipping. Need other items? http://www.psep.biz/index.htm They have a lot of stuff for 's as well as a lot of other motorized equipment & toys. Shipping is $7.95 no matter how big or small the order, I usually try to load up when I order from here. 2 Share this post Link to post Share on other sites
daveoman1966 3,884 #6 Posted November 22, 2019 The transaxle is simply a reservoir for the trans fluid...and isn't pressurized. The dipstick has a rubber grommet to exclude debris as the internals of the Sundstrand pump are HIGHLY sensitive to any contaminant. I have a C-160..same trans... and a few Dipsticks....will have a look-C if I have one for you. If so, $20 bux ...shipped. 2 Share this post Link to post Share on other sites
Mr Magoo 226 #7 Posted November 22, 2019 (edited) On 11/21/2019 at 11:18 PM, daveoman1966 said: The transaxle is simply a reservoir for the trans fluid...and isn't pressurized. The dipstick has a rubber grommet to exclude debris as the internals of the Sundstrand pump are HIGHLY sensitive to any contaminant. I have a C-160..same trans... and a few Dipsticks....will have a look-C if I have one for you. If so, $20 bux ...shipped. I did go ahead and order a new one. So my plan is to try ad suck the oil out using an extractor rig I made up with a shop vac. It is based on this design except I'm using a larger hose to try and get the bigger chunks if there are any. https://www.youtube.com/watch?v=Uk46vCOGTFI&list=FLUz5qaVJ0DlC0wJBAbYQmaw&index=14&t=0s I will also open the drain plug on the bottom. I want to do all of this before I ever start if for the first time since I think that the pieces may have just come off and are hopefully sitting right below the dipstick tube. Not sure if I should try and flush it with anything too. Any other suggestions @daveoman1966 ? Edited November 23, 2019 by Mr Magoo 1 Share this post Link to post Share on other sites
