WildmanC120 613 #1 Posted November 17, 2019 I bought this set of rims and tires last year from ME Miller not realizing that the hub was not the correct length. I cobbed something together last year but wanted to make it much cleaner. Found this set of bushings online. Paired it with 1 of these washers and it was literally a perfect fit. The only thing I need now is to find a center grease cap to fit these wheels. Anyone have any ideas? 1 Share this post Link to post Share on other sites
Pullstart 70,102 #2 Posted November 17, 2019 Try Tractor Supply or a store similar in their trailer section... you might be able to find some steel caps that’ll fit over. Seems @Lane Ranger uses a certain coffee creamer cap? Share this post Link to post Share on other sites
ronhatch 410 #3 Posted November 17, 2019 (edited) Look in the plumbing section of your local hardware/Home Depot store and find a PVC plastic water pipe caps that will fit. I found caps that fit my stock rims, but I did have to wrap a lay or two of 3/4" wide or so of duck tape around the hub so the cap fit tight. Don't forget to drill a 1/16" or 3/32" hole in the cap to let out the pressure under the cap when you grease the wheel hub. Did I mention they are cheap? If you can find a couple of caps that will fit from something in your kitchen or bathroom, all the better! Edited November 17, 2019 by ronhatch Share this post Link to post Share on other sites
