Prater 77 #1 Posted April 21, 2009 I am rebuilding a 36" tiller for my 416 and need some reference pics. Can anyone take a pic of their tiller attached to the mower. I need some close ups of the bracket that attaches to the lift cable. I also need to know how long the belt is so I can get a replacement. The TORO one is a bit $$ Share this post Link to post Share on other sites
emerichsales 0 #2 Posted April 21, 2009 I advise getting the Toro belt. It is coated in a special solution to eliminate slipping. Aftermarket belts that are close are not. You will just cause yourself a world of headaches. Sorry i cant help with pictures of the tiller for you... Share this post Link to post Share on other sites
kpinnc 17,182 #3 Posted April 21, 2009 Steven- check the image gallery HERE and see if it has what you need. If not, let me know and I'll get some pics for you. I'm about 90% done with a rebuild myself. Kevin Share this post Link to post Share on other sites
kpinnc 17,182 #4 Posted April 22, 2009 Here are a few "borrowed" pics Steven: This is a friend's machine that has the gas tank removed, so you can see the linkage setup. Your bell crank may be slightly different, but this is how it mounts up: Kevin Share this post Link to post Share on other sites
ARiley15 0 #5 Posted April 22, 2009 Does anyone have a pictures of how the belt drive is supposed to be hooked to the PTO? I have the older (1980 I think) tiller, model number 07-36TL01. The mount that goes in the mid-mount does not have the fork that stabilizes it. I can't seem to figure out the routing for the belt without running into the PTO guard. Looked at the parts explosion on Toro's website but that was no help either. Thank in advance for any help you can provide. Share this post Link to post Share on other sites
ARiley15 0 #7 Posted April 22, 2009 Solves the mystery. Thank you 4StarCstms!!!! Share this post Link to post Share on other sites
