Countdown To Christmas!
Bill D
M10 muffler on an M16
Bill D
I have a muffler and elbow from a M10 that I would like to install on an M16.  Will it fit, and do all Kohler K/M series engines have the same 1 1/2" exhaust port?  Also, does anyone have any tricks for changing the crankshaft seals on these motors?  Thanks. Bill.
Stepney
Crank seals? Honestly never seen a K or Magnum with that issue. You sure your crankcase breather is good?
As for the muffler. I seem to think my 16hp K series has a reducer in the factory exhaust. 1 3/4-1 1/2" maybe? I know it's not the same as my 12hp. Haven't had a 10 in a while so I cant answer that one.
Bill D
There was 25' of rope wrapped around the crank between the pulley and the seal.  The seal appears to be damaged.  The breather seems fine.
pfrederi
16 hp K series have 1-1/4" NPT There is a reduction bushing installed taking it down to 1"NPT
gwest_ca
1" steel pipe has an outside diameter of 1-5/16".
Garry
The Tuul Crib
Here's a good tool  that is helpful to remove the crank shaft seals .
