CountryRock 199 #1 Posted November 11, 2019 (edited) I found a 79355 snowplow locally. It was on a 522xi. Will this fit other wheel horse models? I'd like to start picking up a few implements for my stable. Edited November 11, 2019 by CountryRock Share this post Link to post Share on other sites
troutbum70 858 #2 Posted November 11, 2019 I believe the attach a matic system stayed the same to the end, except on the D series tractors. But wait for others input. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #3 Posted November 11, 2019 NO... The xi series (as well as the 260 series) are entirely different beasts same principle but again different the classic series long frame blades were built from 1973-2007 shouldn't be to difficult to find exactly what you need... Also the 520H needed a frame extension kit because of the swept forward front axle... @gwest_ca can you help out with what blades fit what tractors again. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #4 Posted November 11, 2019 Here are the blades that fit the long frame tractors. The 48" blades are better suited for the wider rear tires. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following 1990 model 06-48BC02 1991-1993 model 06-48BC03 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) I do not know if the 5xi blade frame can be modified to fit the shorter long frame tractors. I am using a 5xi grader blade on a long frame model but moved the rear 3/4" cross bar 5" ahead. Long frame are the C-Series except C-195 and 300, 400 and 500-Series tractors. Garry Share this post Link to post Share on other sites
Ben Frenette 1 #5 Posted November 11, 2019 I have this one that I would trade to have one that fits on my 1999 lxi. 1 Share this post Link to post Share on other sites
boss427@live.com 9 #6 Posted December 23, 2022 not like it sets it will need a idler arm or sabilizer that fits in the pully box mounting front braket and the angle plow ajusting arm will hit the foot board 1 Share this post Link to post Share on other sites
