tallen4392 71 #1 Posted November 6, 2019 Does anyone know if Napa carries front wheel bearings for a c-81 and would anyone know there part # Share this post Link to post Share on other sites
Pullstart 68,882 #2 Posted November 6, 2019 @squonk? 1 Share this post Link to post Share on other sites
Guest 88vic #4 Posted November 6, 2019 You can get these Stens brand bearings for half th price and the quality is just as good. Share this post Link to post Share on other sites
953 nut 64,115 #5 Posted November 6, 2019 Set of four good quality sealed bearings for under $ 15.00 shipped! https://www.ebay.com/itm/4-WHEEL-BEARINGS-TORO-WHEEL-HORSE-11-0513-25-1210-110513-and-251-3-4-x-1-3-8/281473149545 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #6 Posted November 6, 2019 The better bearings with ground races in the last post can be obtained in 2 styles. Some have one seal and require greasing. Some have two seals and can not be greased. If you use these replace the grease fitting with a set screw Loctited in. If these get greased the bearing seal will not allow the grease into the bearing and the high pressure forces the bearing out of the hub. Garry 1 Share this post Link to post Share on other sites
tallen4392 71 #7 Posted November 7, 2019 THANKS FOR THE INFO Share this post Link to post Share on other sites
