peter lena 9,575 #1 Posted October 10, 2019 my experience with w/h paint , is that it is very stout, and can be recovered. recently at the zagrey farm show in colchester , i was talking to other horse owners that had buffed out their paint , with similar results to mine. this recovery won,t obviously work on a tractor that is covered in rust. i use a 6" palm buffer with a mild paint cutter , in a series of steps, to steadily gain on finish. you cannot do this in one step, but with a small buffer its pretty easy . i like the meguiars paint products for easy work, and the instant wax detailer they have is very easy to use. the transition from grunge to vintage clean is what i like , retaining the character of the tractor in a matching original paint. this clean up is easy , and it works for me , jmoo , pete 3 Share this post Link to post Share on other sites
Mikey the Monkey 701 #2 Posted October 10, 2019 You should do a detailed step by step with pictures 2 Share this post Link to post Share on other sites
tom2p 2,394 #3 Posted October 10, 2019 (edited) For a quick and dirty method and decent results - I use Mother's mag and aluminum polish. This stuff is a fine compound that I've found many uses for. Sometimes if there is a lot of crud (mid, pine tree resin, bugs, whatever) - I will first clean the hood / fenders (and whatever) with a cloth / rag / paper towel wet with WD-40 - and then lightly buff with Mother's mag and aluminum polish. This polish can also bring shine to dull and/or orange-peel paint. Can then apply a coat of wax if desired. Edited October 10, 2019 by tom2p Share this post Link to post Share on other sites
peter lena 9,575 #4 Posted October 10, 2019 tom2p, thats interesting that i do the same thing to regularly feed and clean a painted metal , finish just to save it. i like the simple metal saving results on just about anything, like its feeding the paint. i like chain and cable fluid on my rag rub down. also terrific results to that regularly UNDER MY MOWER DECKS , ALONG WITH A SCRAPING AND SUN DRYING . ZERO DECK ROT. glad to hear that you are staying after your stuff , just the opposed of what i regularly see , pete Share this post Link to post Share on other sites
tom2p 2,394 #5 Posted October 10, 2019 (edited) 18 minutes ago, peter lena said: tom2p, thats interesting that i do the same thing to regularly feed and clean a painted metal , finish just to save it. i like the simple metal saving results on just about anything, like its feeding the paint. i like chain and cable fluid on my rag rub down. also terrific results to that regularly UNDER MY MOWER DECKS , ALONG WITH A SCRAPING AND SUN DRYING . ZERO DECK ROT. glad to hear that you are staying after your stuff , just the opposed of what i regularly see , pete Thanks - I'm just starting to up my game after too many years of neglect. Too easy to neglect a Wheel Horse because they will go a long time with little maintenance. I'm really bad (lazy) with mower decks - especially embarrassing because the decks can be removed with no tools. Found a prev post that mentioned Fluidfilm ? and or Lubriplate grease (Gear Shield Extra Heavy) - that might have been your post. I have the Lubriplate grease (not cheap !) - but my deck might be past stage where it is worthy of that stuff. I did scrape the deck - sprayed with penetrating oil and whatever else I could find laying around - and then let it sit in the sun. . Edited October 10, 2019 by tom2p Share this post Link to post Share on other sites
peter lena 9,575 #6 Posted October 10, 2019 yes that was my post on the decks, decks regularly need a check out, especially if you are cutting a poor surface, with possible impacts. like you said the decks are simple to drop and remount, i use the lighter chain lube ( lubriplate ) in the green can as the scrape down soaker lubricant, then after some sun time i go over it with the extra heavy gear shield on a sun hot deck. once that double soak sets in , it stains the deck black, varifying lubricant protection. i also use LUCAS RED AND TACKY GREASE on the spindles, 550 temp drop point ensures the bearings live. i also mothers mag polish , great stuff. stay after it pete Share this post Link to post Share on other sites
wfrpalm 218 #7 Posted October 10, 2019 How about some pictures of the finished product. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #8 Posted October 10, 2019 You may want to try Flitz... Flitz Polish - Paste - 5.29 oz. Boxed Tube https://www.amazon.com/dp/B00J4Y1O80/ref=cm_sw_r_cp_apa_i_ih8NDbX08AXWA Share this post Link to post Share on other sites
tom2p 2,394 #9 Posted October 11, 2019 (edited) The hoods on the tractors on the ends are original paint - and were not pampered. Wiped the hoods with WD-40 to remove any gunk - and then a quick application of Mother's mag wheel polish brought them back to life. Hood on the middle tractor was repainted. Looked good - but did have some orange peel. Used Mother's mag wheel polish to reduce the orange peel and improve the shine. Edited October 11, 2019 by tom2p 3 3 1 Share this post Link to post Share on other sites
troutbum70 858 #10 Posted October 11, 2019 Great looking herd Share this post Link to post Share on other sites
wfrpalm 218 #11 Posted October 11, 2019 Those are nice looking tractors. Share this post Link to post Share on other sites
