Sarthurs01 1,024 #1 Posted October 4, 2019 recently bought a 22 hp motor for my puller and was wondering what your guys input on what pulley sizes to use. thanks! 1 Share this post Link to post Share on other sites
Spareparts 89 #2 Posted October 6, 2019 Need more info. tire size, rpm you will be running and in what gear. On my grandson's puller we have a 18hp V twin B@S running in 2nd gear hi side with a 5091 peerless, tire size is 23X10:50X12, RPM is 3200 and it's speed is 3.4 MPH. That is with a 4" 5/8 pulley. That MPH is the limit for his weight class and is very strict of DQ'ed. 1 Share this post Link to post Share on other sites
Sarthurs01 1,024 #3 Posted October 6, 2019 Tire size is 23x10.50x2 have to check on the rpms tho. Right now it has a 8hp brigs with a 2.5 inch pulley and I’m pulling 2nd low. I’ll have to look in to a mph rule to make sure too. THANKS! Share this post Link to post Share on other sites
TonyToro 1,135 #4 Posted November 21, 2019 I am still very new to pulling. I have been gathering information over the past few years from this group and my pulling club. Us Wheel Horse guys run an unpopular tractor. Most guys are running the Cub Cadet but I like to be different. We run a 4” on the engine at 3600rpm 2 gear high. We are limited in this class to 2.5 mph so we play with the throttle during the pull to watch our speed. is this stone boat or transfer sled? Share this post Link to post Share on other sites
WHNJ701 4,168 #5 Posted November 21, 2019 when I got my 854 wheelhorse it was setup as a puller or something, it had like a 4" pulley on the engine and a 1" on the transaxle. was told it did wheel stands and had a set of bars on it. I put the the tractor back to stock and put a mower deck on it and used it. 1 Share this post Link to post Share on other sites
fast88pu 3,372 #6 Posted January 27, 2020 I'm running stock 8 speed rear pulley and stock 8 speed front pulley at 4500 rpms in 3rd high. Hang on lol 1 2 Share this post Link to post Share on other sites
TonyToro 1,135 #7 Posted January 28, 2020 1 hour ago, fast88pu said: I'm running stock 8 speed rear pulley and stock 8 speed front pulley at 4500 rpms in 3rd high. Hang on lol Nice!! What are you running for an engine? Share this post Link to post Share on other sites
fast88pu 3,372 #8 Posted January 28, 2020 43 minutes ago, TonyToro said: Nice!! What are you running for an engine? A built 670 predator 2 Share this post Link to post Share on other sites
TonyToro 1,135 #9 Posted January 28, 2020 38 minutes ago, fast88pu said: A built 670 predator That will work! Lol I really like the sounds of those twins. What class is that one in? Share this post Link to post Share on other sites
TonyToro 1,135 #10 Posted January 28, 2020 On 10/4/2019 at 2:44 PM, Sarthurs01 said: recently bought a 22 hp motor for my puller and was wondering what your guys input on what pulley sizes to use. thanks! How are you doing with your tractor? Share this post Link to post Share on other sites
fast88pu 3,372 #11 Posted January 28, 2020 5 hours ago, TonyToro said: That will work! Lol I really like the sounds of those twins. What class is that one in? Stock altered 1050 lb 1 Share this post Link to post Share on other sites
Sarthurs01 1,024 #12 Posted January 28, 2020 11 hours ago, TonyToro said: How are you doing with your tractor? I haven't pulled it yet with the 670 yet but just about have it all built, few more weeks and it should be just about done. 2 Share this post Link to post Share on other sites
ebinmaine 76,778 #13 Posted January 28, 2020 17 hours ago, fast88pu said: I'm running stock 8 speed rear pulley and stock 8 speed front pulley at 4500 rpms in 3rd high. Hang on lol Any idea roughly how fast that is? Not like screaming. Must be eight or nine? Share this post Link to post Share on other sites
ebinmaine 76,778 #14 Posted January 28, 2020 3 hours ago, Sarthurs01 said: I haven't pulled it yet with the 670 yet but just about have it all built, few more weeks and it should be just about done. Got any pics? Share this post Link to post Share on other sites
fast88pu 3,372 #15 Posted January 28, 2020 36 minutes ago, ebinmaine said: Any idea roughly how fast that is? Not like screaming. Must be eight or nine? Probably around that. Feels like your moving 1 Share this post Link to post Share on other sites
TonyToro 1,135 #16 Posted January 28, 2020 8 hours ago, Sarthurs01 said: I haven't pulled it yet with the 670 yet but just about have it all built, few more weeks and it should be just about done. Great...keep us posted. Pictures help! Lol 1 Share this post Link to post Share on other sites
TonyToro 1,135 #17 Posted January 28, 2020 15 hours ago, fast88pu said: Stock altered 1050 lb Cool. We run the same weight but call it B stock. Share this post Link to post Share on other sites
Sarthurs01 1,024 #18 Posted January 29, 2020 Here’s my progress so far. Have the tank mounted fuel line ran, belt on and just about to run wires from the battery back to the motor. Hoping to fire it up this weekend! 2 1 Share this post Link to post Share on other sites
Sarthurs01 1,024 #19 Posted February 2, 2020 IMG_5287.MP4 1 2 Share this post Link to post Share on other sites
Sarthurs01 1,024 #20 Posted February 2, 2020 Still have make the wiring permanent but I got her started up! Share this post Link to post Share on other sites
fast88pu 3,372 #21 Posted February 2, 2020 On January 29, 2020 at 8:26 AM, Sarthurs01 said: Here’s my progress so far. Have the tank mounted fuel line ran, belt on and just about to run wires from the battery back to the motor. Hoping to fire it up this weekend! If you are pulling with it most clubs will want the battery mounted in a box. You could use a tank under the fender and put battery under hood is an idea. 1 Share this post Link to post Share on other sites
Sarthurs01 1,024 #22 Posted February 2, 2020 5 minutes ago, fast88pu said: If you are pulling with it most clubs will want the battery mounted in a box. You could use a tank under the fender and put battery under hood is an idea. There’s nothing in our clubs rules but I thought about other places so I’m placing on making a cover to go over it for that purpose and look cleaner too. Share this post Link to post Share on other sites
fast88pu 3,372 #23 Posted February 2, 2020 28 minutes ago, Sarthurs01 said: There’s nothing in our clubs rules but I thought about other places so I’m placing on making a cover to go over it for that purpose and look cleaner too. Could use a boat battery box 3 Share this post Link to post Share on other sites
Sarthurs01 1,024 #24 Posted February 16, 2020 Little bit more done this weekend 1 2 Share this post Link to post Share on other sites
Redneckdavis 308 #25 Posted August 5, 2020 So I looked into this for my local club. It says pulley size changes are allowed. And they definitely do not have a mph limit. baxleyminipullers.net Sooo. If you didn't have a rule. And you were pulling a 850# tractor. What mph would you? 12.5 Briggs stock. Vertical shaft, true gear box, not variable pulley or hydro. Stock baby tires 18 or so. More tech specs will not do you guys much good. It's not a WH. I don't even know what brand. I'd guess a Rally. Share this post Link to post Share on other sites
