FAST 87 #26 Posted October 3, 2019 Never mind I figured out it’s a 79. Thanks for the help pointing me in the right direction. Share this post Link to post Share on other sites
ebinmaine 81,149 #27 Posted October 3, 2019 6 hours ago, FAST said: I really want to add a front end loader and possible a backhoe to this tractor. Any input either good or bad from any here? I want to move some dirt and do some digging projects all around my property. And I want to move away from shovels and wheelbarrowing. FEL can be bought or built. Backhoe can be built. There are blueprints available with parts lists. Lots of folks have the FEL on a garden tractor. Backhoes are rare. @wallfish could chime in on the backhoe. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,535 #28 Posted October 3, 2019 The 8186 on the ID plate is the Julian build date - 1978 8186 July 05 Wednesday If it is readable could you post the serial number that follows the model number on the top line? Should be something less than 4930 that has a build date of July 18. Garry Share this post Link to post Share on other sites
FAST 87 #29 Posted October 3, 2019 5 hours ago, ebinmaine said: FEL can be bought or built. Backhoe can be built. There are blueprints available with parts lists. Lots of folks have the FEL on a garden tractor. Backhoes are rare. @wallfish could chime in on the backhoe. What blueprints with parts list would you guys recommend? I would love to not have to pay for them but I will if that’s what it takes. Share this post Link to post Share on other sites
wallfish 20,733 #30 Posted October 3, 2019 (edited) 9 hours ago, FAST said: What blueprints with parts list would you guys recommend? I would love to not have to pay for them but I will if that’s what it takes. Trust me, spend the money on a set of good plans. It's money well spent on a proven design and not that much compared to the overall cost to build one. I used pfengineering.com for back hoe plans. His plans are pretty good but they're just that, plans. There's no step by step instructions with them but you can get plenty of help from him (Paul) or right here on RedSquare. If you are good with engineering your own stuff check out these free FEL plans. I have some free basic Back hoe plans somewhere too Edited October 3, 2019 by wallfish 1 2 2 Share this post Link to post Share on other sites
wallfish 20,733 #31 Posted October 3, 2019 This works good for no more shovels or wheel barrows. 3 2 1 1 Share this post Link to post Share on other sites
JCM 11,451 #32 Posted October 3, 2019 @FAST This is just my opinion on an FEL. I have used a Kwik-Way on 3 of my WH Tractors a C-165, 417-8 and a 520 H with the forward swept axle and reduction steering. The 520 - H was by far the most stable and easiest to steer, the 417-8 was stable but the steering was very hard and the least stable was the C-165 which I feel really needed Rear Dual Wheel Adapters and would highly recommend them. I found that it was a very handy attachment for many things but do not expect it to work like a much larger machine than what it is. It is great for moving firewood, bark mulch,and loading different things into a Pickup Bed and not so good trying to get a full bucket of material from a pile, it seems the Bucket cylinders do not curl as much as I would have liked them to do. Overall a very well engineered and well built attachment and a heck of a lot more fun than a wheelbarrow. I hope this helps and as I said earlier JMO. 2 Share this post Link to post Share on other sites
953 nut 70,347 #33 Posted October 3, 2019 With a FEL the most important thing for stability is rear weight. Filling the tires with RTV antifreeze, wheel weights and a weight box will compensate for the added front weight. 1 Share this post Link to post Share on other sites
wallfish 20,733 #34 Posted October 4, 2019 Found them. Gives the basic idea for building a hoe but of coarse it will need to be modified a little to go on the back of a tractor. backhoe1.pdf backhoe2.pdf 1 1 Share this post Link to post Share on other sites
JCM 11,451 #35 Posted October 4, 2019 I forgot to mention that I did use the factory Kwik-Way weight box with roughly 150 Lbs. KW recommends a minimum of 280 lbs counter weight. Share this post Link to post Share on other sites
FAST 87 #36 Posted October 4, 2019 Very nice, thanks a lot for all the suggestions. Exactly what kind of information and opinions I was looking for. 1 1 Share this post Link to post Share on other sites
FAST 87 #37 Posted October 4, 2019 3 hours ago, wallfish said: This works good for no more shovels or wheel barrows. That’s exactly what I want my tractor to be like. Very nice. Thanks for posting the picture. 2 Share this post Link to post Share on other sites
