Too much red 65 #1 Posted September 26, 2019 I found a snow plow on craigslist but I'm not sure it'll fit so I figured I'd ask the guys in the know. The guy sent me a pic of the Id tag but it doesnt match anything on my 1964 implement sheet I downloaded off of here. I just want to make sure the model numbers didn't changed as the years went on and it is compatible I just don't know it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted September 26, 2019 It should fit. This 96-42BC01 is designed to fit long and short frame tractors by moving the rear crossbar ahead to fit your short-frame 854. Garry 1 Share this post Link to post Share on other sites
Too much red 65 #3 Posted September 27, 2019 Thats great news. Thank you sir. Share this post Link to post Share on other sites
Too much red 65 #4 Posted October 7, 2019 Ok, so I bought the plow and got it home. Looks like I'm missing a way to mount it to the rear. Is this what I need? https://www.ebay.com/itm/Wheel-Horse-953-1054-Snow-Plow-Blade-Mount-Hitch-For-Rear-Axel/323710309427 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #5 Posted October 7, 2019 I do not know for sure if it will work but it is not the correct one you need. If you look at the 2nd picture in your link that is what you would see if you were at the front of the tractor looking back at the transmission. This one for the 953/1054 mounts on the front of the cast axle housings. The proper one you need mounts under the axle housings. What you need is the most popular design so should be many available. Post a Wanted add in our classifieds. Garry Share this post Link to post Share on other sites
