Pullstart 71,521 #101 Posted December 3, 2019 Joyce has pain no longer. I’m sorry for your loss Mick, you are a good man being there for your neighbors and community. Share this post Link to post Share on other sites
Tractorhead 9,218 #102 Posted December 3, 2019 That is one of the rare traits you have Mick, especial in our fast paced World. It is good to hear, there are more persons who cares to others. sorry to hear from your loss and condolences from my side. Share this post Link to post Share on other sites
Mickwhitt 5,259 #103 Posted December 4, 2019 Again many thanks for all the messages of support, certainly appreciated. First day in the shop today and I'm moving towards finishing touches. Got the grip paper on the foot boards and fitted the side guards. Full set of decals on the way so I best paint the hood. Mick 2 Share this post Link to post Share on other sites
Stormin 9,988 #104 Posted December 5, 2019 Looking better all the time, Mick. Just something to think of doing with regards to the gripper tape. I put a patch either side where your heel can catch. Saves the paint. 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #105 Posted December 5, 2019 To the rear of the tape that's on the foot board or at the side of it on the belt cover/ implement lever cover. Mick Share this post Link to post Share on other sites
ebinmaine 81,150 #106 Posted December 5, 2019 1 minute ago, Mickwhitt said: To the rear of the tape that's on the foot board or at the side of it on the belt cover/ implement lever cover. Mick I had never even thought about putting it to the side. BOTH of those locations are a good idea if you know your pattern of we're on the paint. That prompts me to look at the Cinnamon now that it's been in use for a few months. Share this post Link to post Share on other sites
Stormin 9,988 #107 Posted December 5, 2019 To the rear of the foot board. See photo. I don't think the side panels will get damaged. Though might depend on the size of your feet. The back of the foot board can get hit with your heel as you remove your feet from the pedals. 2 Share this post Link to post Share on other sites
Mickwhitt 5,259 #108 Posted December 6, 2019 Yes that looks good Norm, good thinking. I will fit mine out the same. Coming close to finishing now, soon be rolling up the door and driving her out. 1 Share this post Link to post Share on other sites
Lee1977 7,809 #109 Posted December 8, 2019 On 10/23/2019 at 12:47 PM, Mickwhitt said: Gear lever gaiter? Missing from my machine so what are the chances of getting hold of one? Or something that will serve the purpose. Mick The shifter plate are the same for all 8 speed rear gas tank tractors from the 80's to the last ones made. The only difference is most 300 series don't have the notch out for the height adjuster as it was an option. Share this post Link to post Share on other sites
Blackhood Bill 728 #110 Posted December 8, 2019 On 11/24/2019 at 11:55 AM, Mickwhitt said: So, carb set to the initial settings as per the manual. Fuelled up, primed, choke on, press the starter....... Cranks over, float chamber fills..... She fires, she runs! Bit lumpy, bit of back firing but she runs. I can move on to finishing the details and making Fred looking good. I had a strip of edging strip left over and put it on the bonnet closure lip, looks neat and the bonnet closes beautifully. What size panel edging do you use that looks great. I search panel edging and it comes in different sizes Share this post Link to post Share on other sites
peter lena 10,109 #111 Posted December 8, 2019 mickwhitt ,nice job on that ! question on your muffler vertical fitting , were you just experimenting ? or was it like that ? , looks like you could add a exhaust pipe extension and cut down on noise and fumes ? by the way looking at your continuing work and reading the comments back and forth , makes it feel like we are there talking back and forth , good stuff, pete Share this post Link to post Share on other sites
Mickwhitt 5,259 #112 Posted December 10, 2019 Peter, The muffler is exactly as fitted when I bought her. But the head is tapped with threads for a silencer pipe rather than a flange and gasket as is fitted now. I'd like to have a better silencer made and mount it below the chassis perhaps. I will look at clearances. Bill the edging strip was from ebay, its half inch wide and says it will take from 1mm to 2mm thick metal. It's quite pliable and grips well. Mick 2 Share this post Link to post Share on other sites
Mickwhitt 5,259 #113 Posted December 13, 2019 Finished painting the hood, just the decals to fit when its hardened off. 3 2 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #114 Posted December 14, 2019 So she starts, she runs, but I cant get her to idle properly. Keep using the choke to keep her going, but if I lower the throttle too far she dies out. Need to play with carb settings I hope. I have not disturbed the governor so I hope that's ok. Did the decals this afternoon. 4 2 1 Share this post Link to post Share on other sites
Pullstart 71,521 #115 Posted December 15, 2019 Looks great Mick! Share this post Link to post Share on other sites
Tractorhead 9,218 #116 Posted December 15, 2019 7 minutes ago, pullstart said: Looks great Mick! Share this post Link to post Share on other sites
lynnmor 9,073 #117 Posted December 15, 2019 19 hours ago, Mickwhitt said: So she starts, she runs, but I cant get her to idle properly. Keep using the choke to keep her going, but if I lower the throttle too far she dies out. Need to play with carb settings I hope. Classic sign of the idle circuit in the carburetor being plugged. Share this post Link to post Share on other sites
Mickwhitt 5,259 #118 Posted December 15, 2019 Thanks for all the positive comments. I'm really proud i managed to make something of her. With all your help and advice of course. From the basic settings I managed to get her to idle quite smoothly. Warmed up she seems to run fine. I will wait for a decent day and wheel her out into the drive for a test run. Exhaust is pretty loud, i think it's just a cylinder with a very short baffle tube inside. I will make some enquiries about getting a new one made. Mick 1 1 Share this post Link to post Share on other sites
Stormin 9,988 #119 Posted December 15, 2019 Well done, Mick. Just don't set the idle too low. Don't forget the bottom end is splash lubricated. About 1200 revs. Share this post Link to post Share on other sites
Mickwhitt 5,259 #120 Posted December 16, 2019 Thanks Norm, I will break out the rev counter and check what its tick over speed is. Same with running speed. It may be I have some tuning to.do when I get her outdoors and driving. The idle speed is controlled by the stop screw on the throttle lever I believe? Does adjusting the mixture screws just get it running smoothly? Mick Share this post Link to post Share on other sites
Stormin 9,988 #121 Posted December 16, 2019 The screw on the side adjusts the idle mixture. The one on the top does the running mixture. Set the idle mixture first. Set running mixture with the throttle wide open. There's instructions in the manuals. I can get a nice idle on both the Black Horse and the C-81. The C-125 is not quite as good. Share this post Link to post Share on other sites
Mickwhitt 5,259 #122 Posted December 18, 2019 I managed to get her idling at 1200 rpm. A few little pop backs as she tucks over, not sure if I can resolve that. Not done the max speed yet as I'm still indoors and I will gas myself lol. Mick 1 Share this post Link to post Share on other sites
WHX?? 58,347 #123 Posted December 18, 2019 When making those carb adjustments Mick make sure the motor is good and warm. Turn both screws per the manual. Turn the screw in till it starts to sputter then back out to where she sputters and then somewhere in-between. Like Norm said idle screw first. I go by feel as to where she runs the best. 2 Share this post Link to post Share on other sites
MikMacMike 494 #124 Posted December 19, 2019 On 9/26/2019 at 6:11 AM, The Tool Crib said: Funny how father time can change our Appearance im definitely one for that !! But after all it's all about the wisdom that we gain along the way! Especially when it comes to the color red ! Nice looking tractor can't wait to see more pictures ! Aint that the truth! Share this post Link to post Share on other sites
MikMacMike 494 #125 Posted December 19, 2019 10 hours ago, WHX24 said: When making those carb adjustments Mick make sure the motor is good and warm. Turn both screws per the manual. Turn the screw in till it starts to sputter then back out to where she sputters and then somewhere in-between. Like Norm said idle screw first. I go by feel as to where she runs the best. Me too I love the ear and how shes singing.....but I do love a vac gauge amungst many other tools that can correct the song I hear! Share this post Link to post Share on other sites
